Blink Programme for 16F876
Results 1 to 12 of 12
    Post your code that's not working with a note on your config fuse settings.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    banjaxxed's Avatar
    banjaxxed Guest
    Thumbs up 16F876 PicBasic Pro Program Fault Corrected For Blink
    <thanks to all for any advice>
    After a long hair pulling session, figured out the 16F876 starts with the A/D running. I wanted digital out Pin 22 (RB1). This is turned off by command 'ADCON1=7' line.
    Working code below to save someone else fustration:
    ' Ricky V
    ' 28 March 2005
    ' Blink Program
    ' MCU PIC16F876
    ' Rev 56,098,345
    ADCON1=7 'disable analogue to digital converter
    TRISB = 0 'set all pins on Port B to outputs
    LED VAR PORTB.1 'Sets which PIN the LED is on, Pin 22 +5V
    loop:
    High LED ' Turn on LED connected to PORTB.1 as Set in VAR LED
    Pause 500 ' Delay for .5 seconds
    Low LED ' Turn off LED connected to PORTB.1 as Set in VAR LED
    Goto loop ' Go back to loop and blink LED forever
    I'm glad to hear you got it working, but ADCON1 has no affect on PORTB.
    PORTA is the 16F876 A/D port.
    AN4 = RA5
    AN3 = RA3
    AN2 = RA2
    AN1 = RA1
    AN0 = RA0
    -Bruce
    tech at rentron.com
    4Lewis's Avatar
    4Lewis Guest
    Default Same Code for blink 16F876A and "not working"
    I used your exact code (which I know works just from looking at it) and I get this error "Code Programming error at 0000" - any suggestions, help?
    loop:
    Your device programmer should have a help file listing several possible causes
    for this particular error message. Lots of things can cause this one. Have you
    worked through the list in the help file?
    -Bruce
    tech at rentron.com
    4Lewis's Avatar
    4Lewis Guest
    Default solution is simple
    The problem was simple (once I got the installation documentation)
    My Zif programmer is screwed down to a board, so I couldn't turn it around. NOW, I know what was happening and why.
    I didn't just put my chip in a different direction, I had to turn aroud the Zif programmer and move the cable connector to the other side as well. So my school gave me a new programmer that was't screwed down so I could do that. It was simple, so I feel silly but all ends well.
  1. Trouble with most basic BLINK on PIC 16F819
    By confusedperson in forum mel PIC BASIC Pro
    Last Post: - 16th April 2009, 21:46
  2. Simple Blink program doesnt work.
    By sccoupe in forum mel PIC BASIC Pro
    Last Post: - 1st March 2009, 20:30
  3. Can't get blink circuit to work :(
    By Techbuilder in forum mel PIC BASIC Pro
    Last Post: - 31st January 2008, 13:00
  4. Execution time in programme
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 16th November 2007, 22:29
  5. I Just Can't Get it to Blink - 16F628
    By Spindle in forum mel PIC BASIC Pro
    Last Post: - 31st May 2005, 15:54
