Tibbo Ethernet shield
Results 1 to 22 of 22
Threaded View
    Dec 2005
    Default Tibbo Ethernet shield
    If, as Tibbo's web site says about other EMxxxx modules and the GA1000, the EM500 GPIO pins are mappable for the SPI connection, this shield is ready.
    The module utilizes SPI interace and only requires five I/O line to control. Flexible mapping allows your application to use any five available I/O pins.
    Click image for larger version
ID:	5604Click image for larger version
    The three lines which connect to the Amicus18/Xino/Auduino/Zardino/xxxx are easily rerouted by cutting the PCB traces and soldering wires to the appropriate pads.
