PIC USB to VB.NET
Results 1 to 40 of 54
    Feb 2004
    Michigan, USA
    Default Re: PIC USB to VB.NET
    I used the code in this thread on the VB side, and used parts of and incorporated it into my own code on the PIC side. I can communicate and send data perfectly to VB but I cannot get data out of VB into the PIC.
    I need to change a slider and have that value (0-255) sent to the PIC so it can save it to EEPROM and later use it. My code on the PIC side works perfectly if I increase or decrease that value with push buttons but I cannot get the byte into the PIC.
    Lets say I want to send that value out to the PIC and store it in byte IOUT. What is the program structure in VB?
    I am using VB 2010, pbp 2.60 and a 18F2550.
    What info do I need to post next to make this easier to figure out?
    Aug 2008
    Portugal
    Quote Originally Posted by jmgelba View Post
    Hi;
    have you tried with the code for the PIC post here. Since the code published here works well, i think there is something wrong with your code, so you should try with the pic code of this thread, or you should post your code to see what is wrong.
    Thanks and Regards;
    Gadelhas
    Feb 2004
    Michigan, USA
    Hmm. Ok, seem to have some data coming out but its when I press buttons and not when I move the slider bar Its all wrong lol!
    I'll post code later.
    Feb 2004
    Michigan, USA
    Ok so I stripped out some of the stuff I dont need and with the addition of a few things this is the VB side:
    Public Class Form1
        ' vendor and product IDs
        Private Const VendorID As Short = 6017   'Replace with your device's
        Private Const ProductID As Short = 2000  'product and vendor IDs
        ' read and write buffers
        Private Const BufferInSize As Short = 16  'Size of the data buffer coming IN to the PC
        Private Const BufferOutSize As Short = 16 'Size of the data buffer going OUT from the PC
        Dim BufferIn(BufferInSize) As Byte       'Received data will be stored here - the first byte in the array is unused
        Dim BufferOut(BufferOutSize) As Byte     'Transmitted data is stored here - the first item in the array must be 0
        Dim PORTC(8) As Integer
        Dim IOUT1 As Byte
        ' when the form loads, connect to the HID controller - pass
        ' the form window handle so that you can receive notification
        ' events...
        Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
            ' do not remove!
            ConnectToHID(Me)
            Pictureoff.Visible = True
            Pictureon.Visible = False
            Label8.Text = "PCB Temp COUNT"
            Label8.Text = "AN1"
            CheckBox1.Enabled = False
            CheckBox2.Enabled = False
            StatusLB2.Text = "USB DEVICE DISCONNECTED"
        End Sub
        ' disconnect from the HID controller...
        Private Sub Form1_FormClosed(ByVal sender As Object, ByVal e As System.Windows.Forms.FormClosedEventArgs) Handles Me.FormClosed
            Splash.Close()
            DisconnectFromHID()
        End Sub
        ' a HID device has been plugged in...
        Public Sub OnPlugged(ByVal pHandle As Integer)
            Dim VendorName As String = "00000000000000000000"
            Dim serial As String = "00000000000000000000"
            If hidGetVendorID(pHandle) = VendorID And hidGetProductID(pHandle) = ProductID Then
                ' ** YOUR CODE HERE **)
                hidGetVendorName(pHandle, VendorName, 20)
                hidGetSerialNumber(pHandle, serial, 20)
                Label1.Text = "Vendor Name: " & VendorName
                Label2.Text = "Product Name: " & ProductName
                Label3.Text = "Vendor ID: " & VendorID
                Label4.Text = "Product ID: " & ProductID
                Label5.Text = "Serial: " & serial
                Pictureoff.Visible = False
                Pictureon.Visible = True
                Label8.Text = Val(BufferIn(1))
                Label8.Text = Val(BufferIn(2))
                CheckBox1.Enabled = True
                CheckBox2.Enabled = True
                StatusLB2.Text = "USB DEVICE CONNECTED"
            End If
        End Sub
        ' a HID device has been unplugged...
        Public Sub OnUnplugged(ByVal pHandle As Integer)
                hidSetReadNotify(hidGetHandle(VendorID, ProductID), False)
                Label8.Text = "DEG C"
                Label8.Text = "AN1"
                CheckBox4.Enabled = False
            End If
        End Sub
        ' controller changed notification - called
        ' after ALL HID devices are plugged or unplugged
        Public Sub OnChanged()
            ' get the handle of the device we are interested in, then set
            ' its read notify flag to true - this ensures you get a read
            ' notification message when there is some data to read...
            Dim pHandle As Integer
            pHandle = hidGetHandle(VendorID, ProductID)
            hidSetReadNotify(hidGetHandle(VendorID, ProductID), True)
        End Sub
        ' on read event...
        Public Sub OnRead(ByVal pHandle As Integer)
            ' read the data (don't forget, pass the whole array)...
            Dim index As Byte
            If hidRead(pHandle, BufferIn(0)) Then
                ' first byte is the report ID, e.g. BufferIn(0)
                ' the other bytes are the data from the microcontroller...
                If BufferIn(7) = 0 And BufferIn(8) = 0 Then
                    '   incomming ADC reading and PORTA status
                    ProgressBar1.Value = BufferIn(1) 'Display ADC results to
                    ProgressBar2.Value = BufferIn(2) 'the progress bars
                    ProgressBar3.Value = BufferIn(1) 'Display ADC results to
                    ProgressBar4.Value = BufferIn(3) 'the progress bars
                    Label8.Text = Val(BufferIn(1)) 'Display  Progress bars
                    Label9.Text = Val(BufferIn(2))  'Values
                    Label18.Text = Val(BufferIn(3))  'Value
                    Else
                    '   Incomming data is a text string
                    For index = 1 To BufferInSize   ' pass the whole array but skip (0)
                        If BufferIn(index) <> 0 Then ' valid data?
                            txtreception.AppendText(Chr(BufferIn(index)))
                        End If
                    Next
                    txtreception.Text += vbNewLine
                    txtreception.Select(txtreception.Text.Length - 1, 0)
                    txtreception.ScrollToCaret()
                End If
            End If
        End Sub
        Public Sub WriteSomeData()
            '   Use to send data to the USB bus.
            '   data must be store in BufferOut array
            '   Actual structure:
            '       BufferOut(0) = Report id => always 0
            '       BufferOut(1) = PORTB  ' first data item, etc etc
            '       BufferOut(2) = HPWM slider1 MSB
            '       BufferOut(3) = IOUT
            '       BufferOut(4) = HPWM slider2 MSB
            '       BufferOut(5) = HPWM slider2 LSB
            '       BufferOut(6) = n/a = 0
            '       BufferOut(7) = n/a = 0
            '       BufferOut(8) = n/a = 0
            BufferOut(0) = 0   ' first by is always the report ID
            BufferOut(6) = 0
            BufferOut(7) = 0
            BufferOut(8) = 0
            hidWriteEx(VendorID, ProductID, BufferOut(0)) ' send it
        End Sub
        Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
            txtreception.Clear()
        End Sub
        Public Sub ActualizaPORTC()
            Dim i As Integer
            BufferOut(1) = 0
            If CheckBox1.Checked = True Then
                PORTC(6) = 1
            Else
                PORTC(6) = 0
            End If
            If CheckBox2.Checked = True Then
                PORTC(1) = 1
            Else
                PORTC(1) = 0
            End If
                    For i = 0 To 1
                BufferOut(1) = BufferOut(1) + (PORTC(i) * (2 ^ i))
            Next
            WriteSomeData()
        End Sub
        Private Sub CheckBox1_CheckedChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles CheckBox1.CheckedChanged
            ActualizaPORTAB()
        End Sub
        Private Sub CheckBox2_CheckedChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles CheckBox2.CheckedChanged
            ActualizaPORTAB()
        End Sub
        'Private Sub CheckBox3_CheckedChanged(ByVal sender As System.Object, ByVal e As System.EventArgs)
        '   ActualizaPORTAB()
        'End Sub
        'Private Sub CheckBox4_CheckedChanged(ByVal sender As System.Object, ByVal e As System.EventArgs)
        '   ActualizaPORTAB()
        'End Sub
        'Private Sub CheckBox5_CheckedChanged(ByVal sender As System.Object, ByVal e As System.EventArgs)
        '   ActualizaPORTAB()
        'End Sub
        'Private Sub CheckBox6_CheckedChanged(ByVal sender As System.Object, ByVal e As System.EventArgs)
        '   ActualizaPORTAB()
        'End Sub
        'Private Sub CheckBox7_CheckedChanged(ByVal sender As System.Object, ByVal e As System.EventArgs)
        '   ActualizaPORTAB()
        'End Sub
        'Private Sub CheckBox8_CheckedChanged(ByVal sender As System.Object, ByVal e As System.EventArgs)
        '   ActualizaPORTAB()
        'End Sub
        Private Sub Timer1_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer1.Tick
            StatusLB3.Text = DateAndTime.Now.ToString
        End Sub
        Private Sub StatusLB1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles StatusLB1.Click
        End Sub
        Private Sub ProgressBar1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ProgressBar1.Click
        End Sub
        Private Sub GroupBox3_Enter(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles GroupBox3.Enter
        End Sub
        Private Sub Label7_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Label7.Click
        End Sub
        Private Sub GroupBox2_Enter(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles GroupBox2.Enter
        End Sub
        Private Sub Label10_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Label10.Click
        End Sub
        Private Sub Label12_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Label12.Click
        End Sub
    End Class
    And this is the PIC side:
    CLEAR
    include "modedefs.bas"
    Define OSC 48
    DEFINE LCD_DREG	PORTB       ' Set LCD Data port
    DEFINE LCD_DBIT	4           ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTB   ' Set LCD Register Select port
    DEFINE LCD_RSBIT 3     	' Set LCD Register Select bit
    DEFINE LCD_EREG	PORTB       ' Set LCD Enable port
    DEFINE LCD_EBIT	2           ' Set LCD Enable bit
    DEFINE LCD_BITS	4           ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 2       ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2000' Set command delay time in us
    DEFINE LCD_DATAUS 50      ' Set data delay time in us
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50
    ;--- Setup Interrupts ------------------------------------------------------
    INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
    INT_LIST  macro    ; IntSource,          Label,  Type, ResetFlag?
            INT_Handler   USB_Handler
    endasm
    ;--- Setup USB -------------------------------------------------------------
    INCLUDE "DT_HID260.pbp"
    DEFINE USB_VENDORID    6017
    DEFINE USB_PRODUCTID   2000
    DEFINE USB_VERSION     1
    DEFINE USB_VENDORNAME  "Regal Electronics"
    DEFINE USB_PRODUCTNAME "Light Lynk - USB"
    DEFINE USB_SERIAL      "0001"
    DEFINE USB_INSIZE      16    ;  IN report is PIC to PC (8,16,32,64)
    DEFINE USB_OUTSIZE     16    ; OUT report is PC to PIC
    DEFINE USB_POLLIN      10   ; Polling times in mS, MIN=1 MAX=10
    DEFINE USB_POLLOUT     10
    ; --- Each USB status LED is optional, comment them if not used ------------
    ; --- They can be assigned to any pin, and no further action is required ---
    DEFINE USB_LEDPOLARITY 1       ; LED ON State [0 or 1]  (default = 1)
    ;DEFINE USB_PLUGGEDLED  PORTB,7 ; LED indicates if USB is connected
    'DEFINE USB_TXLED       PORTC,6 ;  "      "     data being sent to PC
    DEFINE USB_RXLED       PORTB,6 ;  "      "     data being received from PC
    ;--- Variables -------------------------------------------------------------
    Old_PORTC   VAR  BYTE
    New_PORTC   VAR  BYTE
    ADCON1 = %00001011
    ADCON2 = %10000111
    TRISA = %00001111
    TRISB = %00000000
    TRISC = %00000111
    CMCON = 7
    PORTA.5 = 0
    LEDTEMP var word
    PCBTEMP var word
    LEDVOLT var word
    LEDCOUNT var word
    CURRENT var word
    LEDCURRENT var word
    LCUR0 var word
    LCUR1 var word
    ADJUST var word
    tb0 VAR WORD
    tb1 VAR WORD
    tb2 VAR WORD
    LED0 var word
    LED1 var word
    LED2 var word
    LEDV0 var word
    LEDV1 var word
    IOUT VAR byte
    IOUT1 VAR BYTE
    IOUT1 = 5
    JMG VAR WORD
    JMG1 VAR WORD
    JMG2 VAR WORD
    JMG3 VAR WORD
    JMG4 VAR WORD
    POT0 var word
    SCK     var     PORTB.0     ' Alias PORTB.0 to SCK (serial data clock)
    SDO     var     PORTC.7     ' Alias PORTC.7 to SDO (serial data out)
    CS      var     PORTB.1     ' Alias PORTB.1 to C_EN (chip enable)
    HIGH    CS                 'Chip enable high to start
    high    sck                'Mode 1,1 SCK idles high
    pot0.Highbyte = %00000000    'POT0 address in hex - easier for me to see which pot selected
    pot0.lowbyte = 0             'POT0 value in DEC - initialize pot - can be any value
    READ 10, pot0.lowbyte
    low     CS                          ' Make chip active
            pause   1                           ' Delay after making chip active per data sheet - only need 60nS
            shiftout    sdo,sck,5,[pot0\16]     ' Mode 1,1 in MCP4261 DS / Mode 5 PBP - clock idles high, MSB shift out first
            high    CS                          ' MCP4261 DS recommends toggling /CS between commands
            pause   1                           ' Delay keeps from banging CS pin
    ADJUST = 0
    PORTC.6 = 0
    Pause 1500
    LCDOUT $FE,$C0, " YJ5 LED DRIVER "
    pause 2000
    ;--- The Main Loop ---------------------------------------------------------
    ARRAYWRITE USBTXBuffer, ["Random text here"]
    gosub WaitToSend
        FOR X = 0 to 1000           ; Check for incomming USB data while waiting
    @       ON_USBRX_GOSUB  _HandleRX
            PAUSE 1
            New_PORTC = PORTC                ; Check PORTC pins
            IF New_PORTC != Old_PORTC THEN
                Old_PORTC = New_PORTC
                ARRAYWRITE USBTXBuffer, ["Text Here!"]
                GOSUB WaitToSend
                ARRAYWRITE USBTXBuffer, [PCBTEMP, LEDTEMP, IOUT1, _
                                         PORTC.6, PORTA.4, PORTA.5,0,0]
                GOSUB WaitToSend
        NEXT X
        'ADCIN 3, PCBTEMP            ; Send A/D about once/sec
        'ADCIN 2, LEDTEMP
        ARRAYWRITE USBTXBuffer, [tb0, LEDTEMP, IOUT1, _
        GOSUB SendIfReady
    If PORTE.3 = 1 THEN MENU
    if PORTC.0 = 1 then SELEC
    if PORTC.1 = 1 then UP
    if PORTC.2 = 1 then DOWN
    ADCIN 3,PCBTEMP
    tb0 = PCBTEMP * 33 /92
    tb1 = tb0*721
    tb2 = Div32 255
    tb2 = tb2 - 300
    tb0 = tb2/10
    tb1 = tb2//10
    ADCIN 2,LEDTEMP
    LED0 = LEDTEMP * 33 /92
    LED1 = LED0*721
    LED2 = Div32 255
    LED2 = LED2 - 264
    LED0 = LED2/10
    LED1 = LED2//10
    PAUSE 200
    LCDOUT $FE,1,"PCB ",DEC2 tb0,".",DEC1 tb1,"C ",DEC4 IOUT1
    LCDOUT $FE,$C0,"LED ",DEC2 LED0,".",DEC1 LED1,"C ", DEC4 LEDTEMP
    ADCIN 1, LEDCOUNT
    LEDVOLT = LEDCOUNT * 49 /100
    LEDV0 = LEDVOLT/10
    LEDV1 = LEDVOLT//100
    ADCIN 0, CURRENT
    LEDCURRENT = CURRENT * 50 /10
    LCUR0 = LEDCURRENT/10
    LCUR1 = LEDCURRENT//100
    PAUSE 2000
    LCDOUT $FE,1, "LED V ", DEC2 LEDV0, ".", DEC1 LEDV1,"V ", DEC4 LEDCOUNT
    LCDOUT $FE,$C0,"LED C ", DEC2 LCUR0, ".", DEC1 LCUR1,"A ", DEC4 CURRENT
    pause 2000
    MENU:
    'LCDOUT $FE, 1, "MENU" : LCDOUT $FE, $C0,"PRESSED"
    PORTC.6 = 1
    pause 300
    PORTC.6 = 0
    'LCDOUT $fe,1
    goto setup
    SELEC:
    LCDOUT $FE, 1, "SELECT" : LCDOUT $FE, $C0,"PRESSED"
    PORTC.6 = 1
    pause 300
    PORTC.6 = 0
    LCDOUT $fe,1
    UP:
    LCDOUT $FE, 1, "UP" : LCDOUT $FE, $C0,"PRESSED"
    PORTC.6 = 1
    pause 300
    PORTC.6 = 0
    LCDOUT $fe,1
    DOWN:
    LCDOUT $FE, 1, "DOWN" : LCDOUT $FE, $C0,"PRESSED"
    PORTC.6 = 1
    pause 300
    PORTC.6 = 0
    LCDOUT $fe,1
    SETUP:
    LCDOUT $FE, 1, "SET LED CURRENT"
    LCDOUT $FE, $C0, DEC3 IOUT
    gosub HandleRX
    IF PORTC.1 = 1 THEN
    IOUT = IOUT + 1
    PAUSE 75
    IF PORTC.2 = 1 THEN
    IOUT = IOUT - 1
    PAUSE 100
    pot0.lowbyte = IOUT
    WRITE 10, IOUT
    IF PORTC.0 = 1 THEN main
    PAUSE 75
    'IF PORTE.3 = 1 THEN VERSION
    GOTO SETUP
    VERSION:
    LCDOUT  $FE, 1, "FIRMWARE 1.0"
    LCDOUT  $FE, $C0, "PCBA 1.0 SN 0001"
    If PORTC.0 = 1 THEN SETUP
    Goto VERSION
    GOTO Main
    ;--- Send Data if Plugged and ready, otherwise discard ---------------------
    SendIfReady:
        IF Plugged AND TX_READY THEN DoUSBOut
    ;--- Wait till Ready to send of until unplugged ----------------------------
    WaitToSend:
        WHILE Plugged and !TX_READY : WEND
        IF TX_READY THEN GOSUB DoUSBOut
    ;---- Receive incoming data PORTB LEDS and CCP PWM dutycycle ---------------
    HandleRX:
        ARRAYREAD  USBRXBuffer,[JMG, JMG1, IOUT1, PORTC.6, JMG3, JMG4]
        IOUT1 = USBRXBuffer(3)
    All I want to do is send some AD values and a couple of Bytes containing temperatures to the PC, and set a slider in VB and send the 0 - 255 value back to IOUT1 byte in PBP and also turn on or off portc.6 in VB.
    Feb 2004
    Michigan, USA
    The rx LED lights up as I click on buttons on the pc, so data must be getting to the pic, but I dont see it turning on or off the port pin as it should. So not sure what data is being sent or whats happening to it once it gets tot he PIC.
    Also, I dont see the rx LED lighting when I move the slider bar so there has to be an issue on the VB side.
    Can anyone help me out please? I'm a learn by example guy. I've figured out a few errors and got my self from some problems but I'm stuck now.
    Feb 2004
    Michigan, USA
    It looks like there are 8 bytes. The first byte has to be 0 as to the last 2. So theroetically i should be able to just do something like this:
    BufferOut(0) = 0
    BufferOut(1) = 100
    BufferOut(2) = 200
    BufferOut(3) = 300
    BufferOut(4) = 400
    BufferOut(5) = 500
    BufferOut(6) = 600
    BufferOut(7) = 0
    BufferOut(8) = 0
    On the PIC end I should be able to use ARRAYWRITE [byte1, byte2, byte3, byte4, byte5, byte6, byte7, byte8]
    Should this work?
    Aug 2008
    Portugal
    HI;
    To send data from PIC to PC, you must do something like this ( Allready posted in the code of the post #1 )
    ARRAYWRITE USBTXBuffer, [Value0, Value1, PORTA.2,PORTA.3, PORTA.4, PORTA.5,0,0]
    You don't have to worry about the first byte be equal to 0, only ont the PC to PIC side.
    If you want to send from PC to PIC, you must do something like this ( Allready posted in the code of the post #1 )
    PublicSub WriteSomeData()
    ' Actual structure:
    BufferOut(1) = 127 ' value from 1º slider
    BufferOut(2) = 255 ' value from 2º slider
    BufferOut(3) = 10
    BufferOut(4) = 100
    BufferOut(5) = 178
    BufferOut(6) = 0
    BufferOut(7) = 0
    BufferOut(8) = 0
    EndSub
    Thanks and Regards;
    Gadelhas
