VB Help
Results 1 to 36 of 36
Thread: VB Help
    Aug 2010
    Maryland, USA
    Default Re: VB Help
    Ok, different question. How do I put 2 received bytes back together to make 1 word?
    -Bert
    Aug 2008
    Portugal
    Default Re: VB Help
    Tell me one thing first, what is the type of you variable where you receive the data from PIC, Integer, String....
    Thanks and Regards;
    Gadelhas
    Default Re: VB Help
    Like you did have to be fine.
    WordOut=(MSByte*256)+LSByte
    Aug 2008
    Portugal
    Default Re: VB Help
    That should work;
    But if you are showing this result to a textbox you should do
    this:
    czhb.Text=WordOut.ToString
    Maybe it is not your problem, but you should do this!
    Thanks and Regards;
    Gadelhas
    Aug 2010
    Maryland, USA
    Default Re: VB Help
    Well not saying its is the best way by any means, but this seems to work:
    Dim i AsInteger
    Dim t AsUShort
    Dim datain AsByte
    Dim data(20) AsByte
    Dim sign AsString
    t = (data(0) * 256) + data(1)
    If t > 32767 Then
      t = (Not t) + 1
      sign = "-"
    Else : sign = " "
    EndIf
    gxhb.Text = sign & t.ToString
    Thanks for the help guys, for now this will cover my needs
    -Bert
    Aug 2008
    Portugal
    Default Re: VB Help
    Dim i AsInteger
    Dim t AsUShort
    Dim datain AsByte
    Dim data(20) AsByte
    Dim sign AsString
    If t > 32767 Then
    t = (Not t) + 1
    sign = "-"
    Else : sign = " "
    EndIf
    Yeh, that works, and if it works...GooD
    Thanks and Regards;
    Gadelhas
    Aug 2010
    Maryland, USA
    Default Re: VB Help
    Seems like it should be much easier.
    -Bert
    Default Re: VB Help
    yeah but where would be the fun
    Aug 2010
    Maryland, USA
    Default Re: VB Help
    Well I guess it would be a little better if that snippet was a sub routine, or function, or module, or object. See, I don't even know what it should be.
    To me a sub-routine. I want to call it with values in data1 and data2. it should return with a string in wordout.
    But that is just a little above my pay grade right now.
    -Bert
    Default Re: VB Help
    Once you feel you're ready, have a look at this
    http://msdn.microsoft.com/en-us/libr...=vs.80%29.aspx
    Then you could use something like
    txtResult.txt = ConvertWordToSignedString (WordVariable)
