VB Help
Results 1 to 36 of 36
Thread: VB Help
    Dec 2005
    Default Re: VB Help
    Anybody know and want to help me through som VB express issues?
    I don't have time to help with coding but my advice is to pay $100 for PureBasic which runs on Windows, Linux & OSX and creates small, fast, standalone executables.
    Aug 2010
    Maryland, USA
    Default Re: VB Help
    Are you sure?
    awaiting the long-promised Tibbo EM500/GA1000 firmware) and need something to do this afternoon
    Looked at it, also real basic and liberty basic. Nothing wrong with any of them and I have no issue paying for the software. But to get started in windoze apps, I figured I may as well use windoze software. For this adventure I have no need for cross platform deployment.
    -Bert
    Aug 2010
    Maryland, USA
    Default Re: VB Help
    You could use the timer
    Well no really I can't just yet. Haven't figured out how - LOL
    @Walter, what you suggest makes the Pic the master and the PC the slave. I guess that works just fine. Although I suppose if I put some code in the pic to be on continusely or to be polled, that would still let the PC be in charge. Then the pic can just watch for the "stop sending data" command.
    -Bert
    Dec 2005
    Default Re: VB Help
    Are you sure?.
    Yeah - while patiently waiting for the long-promised Tibbo EM500/GA1000 firmware, I'm filling the time adding one more ConnectOne WiFi module to the Amicus18/Arduino/Xino shield. Any of three modules - 2 WiFi, 1 NoFi can be plugged into it. (I hope I have room for the EEPROM mackrackit's going to fill with AT codes.)
    Aug 2010
    Maryland, USA
    Default Re: VB Help
    Dave, did you check your spam folder? Sometimes when I am long awaiting stuff, I find it went there. Hahahaha.
    Group- I feel like my interpretation of Walters post is prolly the best overall solution, but my root problem remains.
    How to setup a timer trigger? Maybe it is in the control toolbox? I will check there next.
    -Bert
    May 2007
    Default Re: VB Help
    ....How to setup a timer trigger? Maybe it is in the control toolbox? I will check there next.
    Select the TIMER control from the toolbox and drag it into your project. Click on the control to display its properties. Enable the TIMER and set its interval to whatever you want (in mS) - see below.
    Then code whatever you want to happen whenever a trigger occurs as in the example below.
        Private Sub Timer1_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer1.Tick
            count = Val(Label1.Text) * 100
            count = count + 1
            HScrollBar1.Value = count
            Label1.Text = Format$(count / 100, "#0.00")
            NumericUpDown1.Value = count / 100
            count = Val(Label3.Text) * 100
            count = count + 1
            HScrollBar2.Value = count
            Label3.Text = Format$(count / 100, "#0.00")
        End Sub
    Aug 2010
    Maryland, USA
    Default Re: VB Help
    Oh thank you rmteo! I had just found the timer, but didn't get the interval part. That works awesome!!
    Ok, now to convert those 2's complimented numbers to show negative values instead of 65533 and such.
    -Bert
    Aug 2008
    Portugal
    Default Re: VB Help
    Hi cncmachineguy;
    To receive data from the serial port you should always use SerialPort Event Trigger like the one i posted.
    Private Sub DataReceived(ByVal sender As Object, ByVal e As System.IO.Ports.SerialDataReceivedEventArgs) Handles SerialPort1.DataReceived
            Dim recepcao As String
            recepcao = SerialPort1.ReadExisting
            If recepcao = "%TE" Then
                GetCursorPos(rect)
                SetCursorPos(rect.X - 1, rect.Y)
            End IF
    End Sub
    Don't use timers to poll the serial port, it is not very efficient!!
    If you want to send data to PIC, like a press of a button, then you can use the timer. just put the code that you have inside the button, inside of the timer, and choose the interval!
    I wrote this post in a little hurry, later i have more time and i came back here!
    Thanks and Regards;
    Gadelhas
