VB Help
Results 1 to 36 of 36
Thread: VB Help
    Aug 2010
    Maryland, USA
    Default Re: VB Help
    I assume this is all of it. If not I don't know where to find it.
    PublicClass Form1
    Dim getdata AsByte
    PrivateSub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
    Dim namearray() AsString
    namearray = IO.Ports.SerialPort.GetPortNames
    If namearray(0) = ""Then
    TextBox1.Text = "none found!"
    Else
    'ComboBox1.Text = namearray(0)
    SerialPort1.PortName = namearray(0)
    TextBox1.Text = SerialPort1.PortName
    EndIf
    EndSub
    PrivateSub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
    Dim i AsInteger
    Dim datain AsByte
    Dim data(20) AsShort
    If getdata = 0 Then
    SerialPort1.Open()
    getdata = 1
    EndIf
    'Do While getdata <> 0
    SerialPort1.Write("k")
    For i = 0 To 17
    datain = SerialPort1.ReadByte()
    data(i) = datain
    Next
    gxhb.Text = (data(0) * 256) + data(1)
    'gxlb.Text = Hex(data(1))
    gyhb.Text = (data(2) * 256) + data(3)
    'gylb.Text = Hex(data(3))
    gzhb.Text = (data(4) * 256) + data(5)
    'gzlb.Text = Hex(data(5))
    axhb.Text = (data(6) * 256) + data(7)
    'axlb.Text = Hex(data(7))
    ayhb.Text = (data(8) * 256) + data(9)
    'aylb.Text = Hex(data(9))
    azhb.Text = (data(10) * 256) + data(11)
    'azlb.Text = Hex(data(11))
    cxhb.Text = (data(12) * 256) + data(13)
    'cxlb.Text = Hex(data(13))
    cyhb.Text = (data(14) * 256) + data(15)
    'cylb.Text = Hex(data(15))
    czhb.Text = (data(16) * 256) + data(17)
    'czlb.Text = (data(17))
    'Loop
    EndSub
    PrivateSub Panel2_Paint(ByVal sender As System.Object, ByVal e As System.Windows.Forms.PaintEventArgs)
    EndSub
    PrivateSub czlb_TextChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles czlb.TextChanged
    EndSub
    PrivateSub Button3_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button3.Click
    getdata = 0
    SerialPort1.Close()
    EndSub
    PrivateSub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) HandlesMyBase.Load
    'Do While 0 < 1
    If getdata = 1 Then
    TextBox1.Text = "sub ran"
    Else
    TextBox1.Text = "sub else ran"
    EndIf
    'Loop
    EndSub
    EndClass
    -Bert
    Aug 2010
    Maryland, USA
    Default Re: VB Help
    Having just read walters post, it seems to me I need a timer, that when it fires it runs the code now in the button_2 press. It would run the code everytime the timer condition is met? Then the button code needs a check for if getdata is 1 or 0. so really the code is inside an if_then.
    Then the timer is my event.
    BTW, if the code I posted makes no sense, my appalogies.
    How to setup the timer for every 50 ms?
    -Bert
    Oct 2009
    Utah, USA
    Default How did you post code WITH color??
    Hey Bert (cncmachineguy),
    How did you post code with the color formatting?
    I would like to be able to do that... (I think everyone should) as it makes code much more readable.'
    Is it the type of editor you copied the code from?? I notice that other posts in this thread do not have color formatting.
    thanks
    Dwight
    Aug 2010
    Maryland, USA
    Default Re: VB Help
    This code was copied from VB express IDE. The color came with it. Would have been nice if the spacing had also followed along.
    I have NO idea why, normally I would have had to highlight and change color for all things not black.
    I think the other posts were prolly just typed up on the spot
    -Bert
