Give this a try...
MiscEL
Give this a try...
MiscEL
Got It!
Thought it was a ! and not an l - old eyes no glasses. Often get told I need them - maybe I do
aajgss
I'm sure in the same boat... without mine I can't even say if it's an elephant ... or a supermarket![]()
Ok,
Lets forget I said the first bits easy!!!
Instead of converting to mmH2O and then converting that to Knots, I decided to go straight from ADC counts to Knots.
So the equation comes out to be (SQR(ADC Counts))* ( 484/79).
Excel comes up with the correct answer. for 1 ADC count the result comes out at 6.1266 knots. Doing the same calculation in a PIC the result is 6 knots. It appears that the result is the integer part only.
The numbers I am trying to get is in the table
mmH2O ________Knots
15_____________ 30
26.5 ___________40
41.5 ___________50
60 _____________60
81.5 ___________70
106.5 __________80
134.5 __________90
166.5 _________100
201 ___________110
239.5 _________120
How do I calculate the correct value and still heed Steves advice to be careful of Math Overflow?
aajgss
Hello aajgss,
What level of resolution are wanting to display, I mean how many decimal places ?
You could multiply up by 10, 100, 1000 and display using DEC modifier and "." .
I didn't notice which PIC you are using but 18Fs can use long variables which if I am not mistaken are 32 bit vars.
Hi Archangel
Resolution I would like is to 1 decimal place. The project I am working on is an electronic manometer to check calibration of the Air Speed Indicator for gliders.
The limits are critical at 30 knots. The ASI must be within +/- 1.5 knots at 30 knots.
I am using an 18F14K50. I did try a LONG variable and multiplied the counts by 10000, but still got the same results. I looked like I was getting a 16 bit math overflow. Most likely cause was me not knowing what I am doing. Is it just a case of using a LONG identifier or is there something else I need to do. There is an option in MCS to use PBPL. Is PBPL another part of PBP, a different program all together or some type of addin? I find the documentation for this kind of simple info a bit difficult to locate.
aajgss
Your answer is here :
you have to use a signal amplifier to get more ADC counts for the same outputted voltage ...Excel comes up with the correct answer. for 1 ADC count the result comes out at 6.1266 knots
A logarithmic amplifier could be a nice idea to get a linear ADC input voltage Vs Speed.
I remember some really good work had been done here for Vu-meters ... ( a greek project ...)
CA3089 or NE 604 could be some interesting keywords to try ...
have fun
I see it at least in section 3 (pages 17 and on), and in section 4 on Variables (page 23) and Division (page 37). It could be in other places; no fast way to use SEARCH in a book besides the table of contents (no index that I can see).
(I really need to reread the manual, they've added important information in there)
