I have a tentative arrangement with someone to produce the ConnectOne ethernet shield as well as the Tibbo EM500/GA1000 shield (in the event Tibbo releases the long-promised firmware which I have been patiently awaiting for over a year).
They also can modify a bootloader to support the use of the PIC16F88 and PIC16F886/887 comparators to invert TX & RX eliminating the need for RS232 line driver and caps, further reducing the cost of the XINO and XINO Basic use as a simple development system. (I don't know whether this cheat will work at 3.3V.)
that would have read that FRAM can be treated like RAM with billions of erase/write cycles which might be an advantage - or not. A 64KB SPI EEPROM is cheap. Even bigger I2C EEPROMs are even cheaper. I'll leave it to the volunteer programmer to advise on this.
