How to use internal oscilator of PIC16F628A?
Results 1 to 8 of 8
    Mar 2011
    cape town, south africa
    Default Re: How to use internal oscilator of PIC16F628A?
    Quote Originally Posted by fratello View Post
    I used something like this :
    @ DEVICE pic16F628A, INTRC_OSC, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_ON, LVP_OFF
    DEFINE  OSC 4
    I'm stuck on a very similar (i think!) problem;
    Using a PIC16F777 for the first time, which has an internal Osc. I'd like to get it running at 4MHz, but using fratello's DEFINE code modified to:
     @ DEVICE pic16F777, INTRC_OSC
    DEFINE  OSC 4
    ....as does not work. the 4MHz, seems much more like 4Hz.
    Any help?! thanx!
    Open the datasheet under OSCCON register, and see the default setting., from there change it.
    Mar 2011
    Thank you Steve - got it working... but i do not understand all the bits in that register;
    IOFS: INTOSC Frequency Stable bit ?
    SCS<1:0>: Oscillator Mode Select bits ?
