Same with DT_INT...
Edit:Code:INCLUDE "DT_INTS-18.bas" ; Base Interrupt System INCLUDE "ReEnterPBP-18.bas" ; Include if using PBP interrupts ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler TMR1_INT, _RTC, PBP, yes INT_Handler TMR3_INT, _CNT, PBP, yes endm INT_CREATE ; Creates the interrupt processor ENDASM DEFINE OSC 4 ' We're using a 10MHz oscillator 'Define INTHAND myint ' Define interrupt handler DEFINE HSER_BAUD 2400 OSCCON=%01010110 OSCCON2.2=0 OSCTUNE.7=1 OSCTUNE.6=1 REFCON0=0 REFCON1=0 ADCON1=0 ADCON2=0 ANSEL =0 ANSELH=0 CM1CON0=0 CM2CON0=0 SRCON0=0 SRCON1=0 WPUA=0 WPUB=0 WDTCON=0 SLRCON=0 RCON.7=0 RCON.6=0 UCON=0 IOCA=0 IOCB=0 T0CON=0 T1CON=%00001111 T2CON=0 T3CON=%00000110 INTCON=192 INTCON2=0 INTCON3=0 PIR1=0 PIR2=0 PIE1=1 PIE2=2 IPR1=0 IPR2=0 porta=0 portb=0 portc=0 trisa=255 trisb=255 trisc=255 'RTC_________________________ Seconds VAR BYTE bankA ' variables within myint must be in bank 0. Minutes VAR Byte bankA ' Elapsed minutes Hours var byte bankA Day var byte bankA Month var byte bankA Year var byte bankA Ticks var byte bankA DMonth var byte bankA 'IO________________ SYMBOL Ul1 =PORTB.5 SYMBOL Ul2 =PORTB.6 SYMBOL Pull =PORTC.4 SYMBOL UWp =PORTC.3 'TRIS______________ INPUT Ul1 INPUT Ul2 OUTPUT Pull INPUT uwp 'Brojaci___________ Brojac VAR LONG[3] bankA PomBroj VAR WORD[2] bankA Mtp1 VAR BYTE[2] bankA Mtp2 VAR BYTE[2] bankA Add VAR BYTE[2] bankA Xn VAR BYTE bankA Xs VAR BYTE bankA Wp VAR BIT bankA Trf VAR BIT bankA Smpl VAR BIT bankA year=0 month=0 day=0 hours = 4 minutes = 0 ' Pre Set time here then add seconds to clock using button seconds = 0 ticks=0 smpl=0 PomBroj[0]=0 PomBroj[1]=0 Brojac[0]=0 Brojac[1]=0 mtp1[0]=1 mtp1[1]=1 mtp2[0]=1 mtp2[1]=1 add[0]=1 add[1]=1 Trf=0 @ INT_ENABLE TMR3_INT @ INT_ENABLE TMR1_INT GoTo mainloop ' jump over the interrupt handler and sub RTC: TMR1H=252 @ INCF _Ticks,F if ticks=32 then @ INCF _Seconds,F @ CLRF _Ticks if seconds > 59 then @ CLRF _Seconds @ INCF _Minutes,F if minutes > 59 then @ CLRF _Minutes @ INCF _Hours,F if hours > 23 then @ CLRF _Hours @ INCF _Day,F If month=2 then If year//4<>0 then DMonth=29 else DMonth=28 endif else Dmonth=30+month.0 endif If day>Dmonth then @ CLRF _Day @ INCF _Month,F If month>12 then @ CLRF _Month @ INCF _Year,F if year>99 then year=0 endif endif endif endif endif endif Pull=1 TMR3H=255 IF Smpl=1 then TMR3L=207 else TMR3L=240 endif T3CON=%00000111 @ INT_RETURN CNT: T3CON=%00000110 Wp= Wp & uwp Xn.0=ul1 Xn.1=ul2 Pull=0 IF (Xn.0<Xs.0 AND Trf=0) OR (Xn.0<Xs.0 AND Xn.1=1 AND Trf=1) THEN @ INCF _PomBroj,F 'PomBroj[0] = PomBroj[0] + 1 IF PomBroj[0] = Mtp2[0] OR (PomBroj=256 AND Mtp2[0]=0)THEN Brojac[0]=Brojac[0] + Add[0] @ CLRF _PomBroj'PomBroj[0]=0 ENDIF ENDIF IF (Xn.1<Xs.1 AND Trf=0) OR (Xn.0<Xs.0 AND Trf=1 AND Xn.1=0) THEN PomBroj[1] = PomBroj[1] + 1 ' @ INCF _PomBroj+1,F ' IF PomBroj[1] = Mtp2[1] OR (PomBroj[1]=256 AND Mtp2[1]=0)THEN Brojac[1]=Brojac[1]+Add[1] @ CLRF _PomBroj+1 'PomBroj[1]=0 ENDIF ENDIF Xs=Xn @ INT_RETURN mainloop: if ticks = 0 then trisb.7=0 ' 2 portb.7,84, hserout ["B1: ",dec9 brojac[0]," B2: ",dec9 brojac[1],13,10]'["Time: ",DEC hours, ":", DEC2 minutes, ":", DEC2 seconds,13,10] endif GoTo mainloop ' Repeat main loop End
With the DT_INT code is twice bigger than it was. Maybe I could try to get rid of arrays.
But it complicates the rest of my code... But on the other hand we will slightly extend the battery life...
