PBP array in ASM statements
Results 1 to 20 of 20
    Sep 2009
    Default Re: PBP array in ASM statements
    Hm...
    I did not know ...
    I've seen in the example for the RTC, so I assume...
    I will try dt_int...
    By the way banksel isn't help either.
    Thank you very much
    BANKSEL is an MPASM directive, and PBP compiler doesn't keep track of it.
    CHK?RP is an equivalent Macro to use with PBP.
    Sep 2009
    I tried, but problem stays....
    Maybe with DT_int will work.
    I will test now, and come back with the results.
    Sep 2009
    Same with DT_INT...
    INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
            INT_Handler    TMR1_INT,  _RTC,   PBP,  yes
            INT_Handler    TMR3_INT,  _CNT,   PBP,  yes
    DEFINE        OSC 4         ' We're using a 10MHz oscillator
    'Define        INTHAND myint    ' Define interrupt handler
    DEFINE HSER_BAUD 2400
            OSCCON=%01010110
            OSCCON2.2=0
            OSCTUNE.7=1
            OSCTUNE.6=1
            REFCON0=0
            REFCON1=0
            ADCON1=0
            ADCON2=0
            ANSEL =0
            ANSELH=0
            CM1CON0=0
            CM2CON0=0
            SRCON0=0
            SRCON1=0
            WPUA=0
            WPUB=0
            WDTCON=0
            SLRCON=0
            RCON.7=0
            RCON.6=0
            UCON=0
            IOCA=0
            IOCB=0
            T0CON=0
            T1CON=%00001111
            T2CON=0
            T3CON=%00000110
            INTCON=192
            INTCON2=0
            INTCON3=0
            PIR1=0
            PIR2=0
            PIE1=1
            PIE2=2
            IPR1=0
            IPR2=0
            porta=0
            portb=0
            portc=0
            trisa=255
            trisb=255
            trisc=255
    'RTC_________________________
    Seconds        VAR BYTE bankA  ' variables within myint must be in bank 0.
    Minutes        VAR Byte bankA       ' Elapsed minutes
    Hours          var byte bankA
    Day            var byte bankA
    Month          var byte bankA
    Year           var byte bankA
    Ticks          var byte bankA
    DMonth         var byte bankA
    'IO________________
    SYMBOL Ul1  =PORTB.5
    SYMBOL Ul2  =PORTB.6
    SYMBOL Pull =PORTC.4
    SYMBOL UWp  =PORTC.3
    'TRIS______________
    INPUT  Ul1
    INPUT  Ul2
    OUTPUT Pull
    INPUT  uwp
    'Brojaci___________
    Brojac  VAR LONG[3] bankA
    PomBroj VAR WORD[2] bankA
    Mtp1    VAR BYTE[2] bankA
    Mtp2    VAR BYTE[2] bankA
    Add     VAR BYTE[2] bankA
    Xn      VAR BYTE    bankA
    Xs      VAR BYTE    bankA
    Wp      VAR BIT     bankA
    Trf     VAR BIT     bankA
    Smpl    VAR BIT     bankA
        year=0
        month=0
        day=0
        hours = 4
        minutes = 0       ' Pre Set time here then add seconds to clock using button
        seconds = 0
        ticks=0
        smpl=0
        PomBroj[0]=0
        PomBroj[1]=0
        Brojac[0]=0
        Brojac[1]=0
        mtp1[0]=1
        mtp1[1]=1
        mtp2[0]=1
        mtp2[1]=1
        add[0]=1
        add[1]=1
        Trf=0
    @    INT_ENABLE  TMR3_INT
    @    INT_ENABLE  TMR1_INT
    GoTo mainloop          ' jump over the interrupt handler and sub
    RTC:
       TMR1H=252
    @  INCF _Ticks,F
       if ticks=32 then
    @     INCF _Seconds,F
    @     CLRF _Ticks
          if seconds > 59 then
    @        CLRF _Seconds
    @        INCF _Minutes,F
             if minutes > 59 then
    @          CLRF _Minutes
    @          INCF _Hours,F
               if hours > 23 then
    @             CLRF _Hours
    @             INCF _Day,F
                  If month=2 then
                     If year//4<>0 then
                        DMonth=29
                        DMonth=28
                  Dmonth=30+month.0
                  If day>Dmonth then
    @                CLRF _Day
    @                INCF _Month,F
                     If month>12 then
    @                   CLRF _Month
    @                   INCF _Year,F
                        if year>99 then year=0
       Pull=1
       TMR3H=255
       IF Smpl=1 then
          TMR3L=207
          TMR3L=240
       T3CON=%00000111
    @ INT_RETURN
    CNT:
       T3CON=%00000110
       Wp= Wp & uwp
       Xn.0=ul1
       Xn.1=ul2
       Pull=0
       IF (Xn.0<Xs.0 AND Trf=0) OR  (Xn.0<Xs.0 AND Xn.1=1 AND Trf=1) THEN
    @     INCF _PomBroj,F 'PomBroj[0] = PomBroj[0] + 1
          IF PomBroj[0] = Mtp2[0] OR (PomBroj=256 AND Mtp2[0]=0)THEN
           Brojac[0]=Brojac[0] + Add[0]
    @      CLRF _PomBroj'PomBroj[0]=0
       IF (Xn.1<Xs.1 AND Trf=0) OR (Xn.0<Xs.0 AND Trf=1 AND Xn.1=0) THEN
          PomBroj[1] = PomBroj[1] + 1    '  @     INCF _PomBroj+1,F '
          IF PomBroj[1] = Mtp2[1] OR (PomBroj[1]=256 AND Mtp2[1]=0)THEN
           Brojac[1]=Brojac[1]+Add[1]
    @      CLRF _PomBroj+1         'PomBroj[1]=0
       Xs=Xn
    @ INT_RETURN
    mainloop:
    if ticks = 0 then
     trisb.7=0
      ' 2 portb.7,84,
     hserout ["B1: ",dec9 brojac[0]," B2: ",dec9 brojac[1],13,10]'["Time: ",DEC hours, ":", DEC2 minutes, ":", DEC2 seconds,13,10]
    GoTo mainloop       ' Repeat main loop
    Edit:
    With the DT_INT code is twice bigger than it was. Maybe I could try to get rid of arrays.
    But it complicates the rest of my code... But on the other hand we will slightly extend the battery life...
    Aug 2010
    Maryland, USA
    It is likely when you enter your ISR, BSR is not 0. You can use PBP stuff in your ASM interrupt as long as you don't use any PBP stuff that uses system variables. These are things like serin/out, adcin, debug etc.
    The thing you MUST do when you first enter is BSR =0. Doesn't matter if you have all ASM or a mix. PBP assumes it is set to bank 0, when it needs a different bank, it will change to it, then change back when done that command. When your interrupt occurs, you may be in a different bank. Then none of you interrupt stuff will work correct. In fact, you may not even be able to clear the interrupt flag.
    This MAY not be the problem right now, but it will be. I spent 2 weeks trying to figure this out. Since then my interrupts work great! Give this a try.
    Now no need to worry if using on interrupt or DT_INT.
    -Bert
    Sep 2009
    I know that I can't use any PBP stuff that uses system variables. In myint I'm only using PBP If's and basic math function...
    Now I'm back to Define INTHAND. And I added BSR = 0 after @myint
    I didn't know how pbp handle banks. Thank you for your notification
    Is there need to return to the bank where he was?
    eg:
    @myint
    BSR_Save=BSR
    BSR=0
    ISR routine
    BSR=BSR_Save
    Aug 2010
    Maryland, USA
    If you are using 1 of the cool autocontex saving chips (interrupt section of the datasheet) BSR should be one of the registers saved and restored. If not, add it in to where you save w, status, and pcl. Then restore it with them.
    -Bert
