PBP array in ASM statements
Results 1 to 20 of 20
    Default Re: PBP array in ASM statements
    Since we don't have the full code, or .LST file, I'll leave the more in deep & technical explanation of Access Ram, BSR and plah plah plah of section 3.3.3 to better guys (I hope I'm right though ).
    Again, the compiler keep track of everything for you, hence why the PBP lines will always works.
    add
    @ CHK?RP _Counter
    just before your INCF, DECF and or CLRF to see what happen
    Are all of your variables in the same bank?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Sep 2009
    Same thing...
    Here it's complite code
    DEFINE        OSC 4         ' We're using a 10MHz oscillator
    Define        INTHAND myint    ' Define interrupt handler
    DEFINE HSER_BAUD 2400
            OSCCON=%01010110
            OSCCON2.2=0
            OSCTUNE.7=1
            OSCTUNE.6=1
            REFCON0=0
            REFCON1=0
            ADCON1=0
            ADCON2=0
            ANSEL =0
            ANSELH=0
            CM1CON0=0
            CM2CON0=0
            SRCON0=0
            SRCON1=0
            WPUA=0
            WPUB=0
            WDTCON=0
            SLRCON=0
            RCON.7=0
            RCON.6=0
            UCON=0
            IOCA=0
            IOCB=0
            T0CON=0
            T1CON=%00001111
            T2CON=0
            T3CON=%00000110
            INTCON=192
            INTCON2=0
            INTCON3=0
            PIR1=0
            PIR2=0
            PIE1=1
            PIE2=2
            IPR1=0
            IPR2=0
            porta=0
            portb=0
            portc=0
            trisa=255
            trisb=255
            trisc=255
    'RTC_________________________
    Seconds        VAR BYTE bankA  ' variables within myint must be in bank 0.
    Minutes        VAR Byte bankA       ' Elapsed minutes
    Hours          var byte bankA
    Day            var byte bankA
    Month          var byte bankA
    Year           var byte bankA
    Ticks          var byte bankA
    DMonth         var byte bankA
    'IO________________
    SYMBOL Ul1  =PORTB.5
    SYMBOL Ul2  =PORTB.6
    SYMBOL Pull =PORTC.4
    SYMBOL UWp  =PORTC.3
    'TRIS______________
    INPUT  Ul1
    INPUT  Ul2
    OUTPUT Pull
    INPUT  uwp
    'Brojaci___________
    Brojac  VAR LONG[3] bankA
    PomBroj VAR WORD[2] bankA
    Mtp1    VAR BYTE[2] bankA
    Mtp2    VAR BYTE[2] bankA
    Add     VAR BYTE[2] bankA
    Xn      VAR BYTE    bankA
    Xs      VAR BYTE    bankA
    Wp      VAR BIT     bankA
    Trf     var byte    bankA
        year=0
        month=0
        day=0
        hours = 4
        minutes = 0       ' Pre Set time here then add seconds to clock using button
        seconds = 0
        ticks=0
        PomBroj[0]=0
        PomBroj[1]=0
        Brojac[0]=0
        Brojac[1]=0
        mtp1[0]=1
        mtp1[1]=1
        mtp2[0]=1
        mtp2[1]=1
        add[0]=1
        add[1]=1
        Trf=0
       GoTo mainloop
    @myint
    If PIR1.0 =1 then
       TMR1H=252
    @  INCF _Ticks,F
       if ticks=32 then
    @     INCF _Seconds,F
    @     CLRF _Ticks
          if seconds > 59 then
    @        CLRF _Seconds
    @        INCF _Minutes,F
             if minutes > 59 then
    @          CLRF _Minutes
    @          INCF _Hours,F
               if hours > 23 then
    @             CLRF _Hours
    @             INCF _Day,F
                  If month=2 then
                     If year//4<>0 then
                        DMonth=29
                        DMonth=28
                  Dmonth=30+month.0
                  If day>Dmonth then
    @                CLRF _Day
    @                INCF _Month,F
                     If month>12 then
    @                   CLRF _Month
    @                   INCF _Year,F
                        if year>99 then year=0
       Pull=1
       TMR3H=255
       TMR3L=207
       T3CON=%00000111
    @  CLRF PIR1
    if PIR2.1=1 then
       T3CON=%00000110
       Wp= Wp & uwp
       Xn.0=ul1
       Xn.1=ul2
       Pull=0
       IF (Xn.0<Xs.0 AND Trf=0) OR  (Xn.0<Xs.0 AND Xn.1=1 AND Trf=1) THEN
    @     INCF _PomBroj,F 'PomBroj[0] = PomBroj[0] + 1
          IF PomBroj[0] = Mtp2[0] OR (PomBroj=256 AND Mtp2[0]=0)THEN
           Brojac[0]=Brojac[0] + Add[0]
    @      CLRF _PomBroj'PomBroj[0]=0
       IF (Xn.1<Xs.1 AND Trf=0) OR (Xn.0<Xs.0 AND Trf=1 AND Xn.1=0) THEN
          PomBroj[1] = PomBroj[1] + 1  '  @     INCF _PomBroj+1,F '
          IF PomBroj[1] = Mtp2[1] OR (PomBroj[1]=256 AND Mtp2[1]=0)THEN
           Brojac[1]=Brojac[1]+Add[1]
           @ CHK?RP _PomBroj
    @      CLRF _PomBroj+1'PomBroj[1]=0'
       Xs=Xn
    @  CLRF PIR2
    @ retfie  FAST
    mainloop:
    if ticks = 0 then
     trisb.7=0
     hserout ["B1: ",dec9 brojac[0]," B2: ",dec9 brojac[1],13,10]'["Time: ",DEC hours, ":", DEC2 minutes, ":", DEC2 seconds,13,10]
    GoTo mainloop
    If i don't use PBP for clearing and increment variable here
           @ CHK?RP _PomBroj
    Counter(Brojac) Is incremented only on first falling edge. If I use PBP, everything work fine, but code is larger for 6 bytes. I need 4 counter. Becouse device have cr3203 batery, I'm trying to make smallest possible code. Maybe I can save on space by removing or's from IF's.
    STOP THE PRESS! your problem is right here
    In theory, this is valid only for 100% Assembler ISR.
    Check for ON INTERRUPT or Darrel Taylor's INST interrupts (http://www.pbpgroup.com/modules/wfse...p?articleid=19)
    Sep 2009
    Hm...
    I did not know ...
    I've seen in the example for the RTC, so I assume...
    I will try dt_int...
    By the way banksel isn't help either.
    Thank you very much
    BANKSEL is an MPASM directive, and PBP compiler doesn't keep track of it.
    CHK?RP is an equivalent Macro to use with PBP.
    Sep 2009
    I tried, but problem stays....
    Maybe with DT_int will work.
    I will test now, and come back with the results.
    Sep 2009
    Same with DT_INT...
    INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
            INT_Handler    TMR1_INT,  _RTC,   PBP,  yes
            INT_Handler    TMR3_INT,  _CNT,   PBP,  yes
    'Define        INTHAND myint    ' Define interrupt handler
            OSCCON=%01010110
            OSCCON2.2=0
            OSCTUNE.7=1
            OSCTUNE.6=1
            REFCON0=0
            REFCON1=0
            ADCON1=0
            ADCON2=0
            ANSEL =0
            ANSELH=0
            CM1CON0=0
            CM2CON0=0
            SRCON0=0
            SRCON1=0
            WPUA=0
            WPUB=0
            WDTCON=0
            SLRCON=0
            RCON.7=0
            RCON.6=0
            UCON=0
            IOCA=0
            IOCB=0
            T0CON=0
            T1CON=%00001111
            T2CON=0
            T3CON=%00000110
            INTCON=192
            INTCON2=0
            INTCON3=0
            PIR1=0
            PIR2=0
            PIE1=1
            PIE2=2
            IPR1=0
            IPR2=0
            porta=0
            portb=0
            portc=0
            trisa=255
            trisb=255
            trisc=255
    Day            var byte bankA
    Year           var byte bankA
    'IO________________
    SYMBOL Ul1  =PORTB.5
    SYMBOL Ul2  =PORTB.6
    SYMBOL UWp  =PORTC.3
    'TRIS______________
    INPUT  Ul1
    INPUT  Ul2
    OUTPUT Pull
    INPUT  uwp
    'Brojaci___________
    Xn      VAR BYTE    bankA
    Xs      VAR BYTE    bankA
    Wp      VAR BIT     bankA
    Trf     VAR BIT     bankA
    Smpl    VAR BIT     bankA
        year=0
        month=0
        day=0
        hours = 4
        seconds = 0
        ticks=0
        smpl=0
        PomBroj[0]=0
        PomBroj[1]=0
        Brojac[0]=0
        Brojac[1]=0
        mtp1[0]=1
        mtp1[1]=1
        mtp2[0]=1
        mtp2[1]=1
        add[0]=1
        add[1]=1
        Trf=0
    @    INT_ENABLE  TMR3_INT
    @    INT_ENABLE  TMR1_INT
    GoTo mainloop          ' jump over the interrupt handler and sub
    RTC:
       TMR1H=252
    @  INCF _Ticks,F
       if ticks=32 then
    @     INCF _Seconds,F
    @     CLRF _Ticks
    @        CLRF _Seconds
    @        INCF _Minutes,F
    @          CLRF _Minutes
    @          INCF _Hours,F
               if hours > 23 then
    @             CLRF _Hours
    @             INCF _Day,F
                  If month=2 then
                     If year//4<>0 then
                        DMonth=29
                        DMonth=28
                  Dmonth=30+month.0
                  If day>Dmonth then
    @                CLRF _Day
    @                INCF _Month,F
                     If month>12 then
    @                   CLRF _Month
    @                   INCF _Year,F
       Pull=1
       TMR3H=255
       IF Smpl=1 then
          TMR3L=207
          TMR3L=240
       T3CON=%00000111
    @ INT_RETURN
    CNT:
       T3CON=%00000110
       Wp= Wp & uwp
       Xn.0=ul1
       Xn.1=ul2
       Pull=0
    @      CLRF _PomBroj+1         'PomBroj[1]=0
       Xs=Xn
    @ INT_RETURN
    mainloop:
    if ticks = 0 then
     trisb.7=0
      ' 2 portb.7,84,
    GoTo mainloop       ' Repeat main loop
    Edit:
    With the DT_INT code is twice bigger than it was. Maybe I could try to get rid of arrays.
    But it complicates the rest of my code... But on the other hand we will slightly extend the battery life...
