PBP array in ASM statements
Results 1 to 20 of 20
    Sep 2009
    Default PBP array in ASM statements
    I have defined a variable Counters VAR BYTE [4] bankA, and I'm using it in ISR.
    Instead Counters[0] = Counters[0] +1, I want to use @ INCF _Counters, F because it is faster.
    This is for first byte in array
    @ INCF _Counters, F
    and it works.
    For the second byte in array I tried this:
    @ INCF _Counters+1, F
    But does not work, if I use Counters[1] = Counters[1] +1 then it works.
    How to fix that?
    Default Re: PBP array in ASM statements
    ...nevermind... keep thinking...
    Sep 2009
    The same is happening with @ CLRF _Counter +1.
    And ISR stops, sometimes begins to run, sometimes I have to reset my pic
    I'm tad rusty, for ease... I would bet your should assign your array to BANK0 instead...
    post your PIC model and code, we'll try to help
    Sep 2009
    Here it is ISR
    if PIR2.1=1 then
       T3CON=%00000110
       Wp= Wp & uwp
       Xn.0=IN1
       Xn.1=IN2
       IF (Xn.0<Xs.0 AND Trf=0) OR  (Xn.0<Xs.0 AND Xn.1=1 AND Trf=1) THEN
    @     INCF _Counter,F 'this work
          IF Counter[0] = Mtp2[0] OR (Counter=256 AND Mtp2[0]=0)THEN
    @      CLRF _Counter ' and this
              CNT[0]=CNT[0] + Add[0]
       IF (Xn.1<Xs.1 AND Trf=0) OR (Xn.0<Xs.0 AND Trf=1 AND Xn.1=0) THEN
    @     INCF _Counter+1,F 'Counter[1] = Counter[1] + 1  'won't work
          IF Counter[1] = Mtp2[1] OR (Counter[1]=256 AND Mtp2[1]=0)THEN
    @      CLRF _Counter+1'Counter[1]=0 'won't work
              CNT[1]=CNT[1]+Add[1]
       Xs=Xn
    @  CLRF PIR2
    Pic is 18LF14K50
    EDIT:
    bank0 or bankA is same...
    I tried RTC,it works fine with both.
    weird... a simple loop works here,
    start:
        asm
            incf _MyArray,F
            incf _MyArray+1,F
        endasm
        myvar=myarray[0]
        myvar2=myarray[1]
        goto start
    but as you're using a blend mix of ASM and PBP in an ISR, you must make sure you're always on the good BANK case not, hell yeah it may goes to lalaland... what you could try is to set all variable that goes in the ISR to BANKA.
    And yes I know I miss something
    EDIT: The more I think, the more it looks like a bank switching issue,
        MyArray VAR BYTE[8] BANK1
        MyVar var byte BANK0
        MyVar2 var byte BANK0
        clear
    start:
        asm
            CHK?RP _MyArray
            incf _MyArray,F
            incf _MyArray+1,F
        endasm
        myvar=myarray[0]
        myvar2=myarray[1]
        goto start
    The above work... commentout the CHK?RP line.. and nope... it doesn't.
    And NOPE, BANK0 !=BANKA
    BANKA   $0000, $005F
    BANK0   $0060, $00FF
    Finger crossed before the real ASM/Compiler gurus came here and slap me a good one
