Newbie Compile error
Results 1 to 3 of 3
    chrsyl's Avatar
    chrsyl Guest
    Cool Newbie Compile error
    Windows 7
    Executing: "C:\Program Files (x86)\PBPDEMO\PBPSUITE.DLL" -ampasmwin -k# -p16F690 "pk2_tutorial.bas"
    Could not spawn language tool. Check command-line options. (193)
    How to understand and proceed??
    Default Re: Newbie Compile error
    Are you using Micro Code Studio or MPLAB or ....
    Hi likely MPLAB as per the DLL call.
    I would suggest the OP to double and triple check the Melabs MPLAB tutorial.
    http://melabs.com/support/mplab.htm
    If under Vista/7, always make sure you run and elevate privilege to Admin (which is a really dumb windows feature btw... )
