I at least figured out why this statement wouldn't compile....I forgot to put a comma after the SEROUT2 TX,6 . However, after fixing this and compiling/running it, the factory defaults didn't seem to happen.
I used this statement to try to do this and it won't even compile as if there is a syntax error: SEROUT2 TX,6 [ "AT+iFD",$d ,$a ] 'Set iChip to Factory Defaults
I don't see anything wrong with this. Any ideas why this won't compile?
I may have found part of the problem. I have placed a voltmeter on the pin that is RX going into the iWiFi and it stays at a constant 3.3 volts throughout this program...no fluctuations indicating any serial transmission. Also put it on the TX pin comming out of my MCU...also constant. This tells me that the serial interface from the MCU is not working. That would mean that the AT+iFD message never got to the module, hence no Factory Defaults. However, I don't know why or how to fix it. Any ideas?
