mackrackit's ConnectOne example code
Results 1 to 40 of 92
    Dec 2005
    Default Re: mackrackit's ConnectOne example code
    I should have mentioned that the Mini Socket iWiFi datasheet says for RXD...
    Input - Host Data Receive – Asynchronous serial data received from host.
    anf for TXD...
    Output - Host Data Send – Asynchronous serial data sent to host.
    Mar 2009
    Colorado
    I should have mentioned that the Mini Socket iWiFi datasheet says for RXD...anf for TXD...
    Thanks, Dave. I also got a Tech Support input from OneConnect saying to connect TXD to MCU's RX and RXD to MCU's Tx, -DTR to ground, -DSR unconnected, and -CTS connected to -RTS. So this clarifies the serial interface requirements for their MiniSocket WiFi module with a PIC MCU.
