3x4 keypad scanning problem and others
Results 1 to 5 of 5
    pt3rg's Avatar
    pt3rg Guest
    Unhappy 3x4 keypad scanning problem and others
    I got a couple of questions to ask some of you very smart people here.
    I'm testing a program for scanning a 3x4 keypad and a yellow LED is supposed to light up whenever a key is pressed. The problem is the LED only lights up if i press keys from the 2nd and 3rd column, it doesn't give any response if i press keys from the 1st column (1,4,7,*).
    1st column - RB0
    2nd column - RB1
    3rd column - RB2
    1st row - RB3
    2nd row - RB4
    3rd row - RB5
    4th row - RB6
    2. And how do i set up an administrative password where the password is already in EEPROM location 0 when the system starts up? Do i use the DATA function? If the admin password is 1234, the user has to key in 1234 then only a green LED will light up.
    DEFINE LOADER_USED 1
    i VAR byte
    col VAR byte
    row VAR byte
    num VAR byte
    PIN VAR byte[4]
    ADMIN VAR byte[4]
    GREEN VAR PORTA.2
    YELLOW VAR PORTA.1
    BUZZER VAR PORTA.3
    OPTION_REG.7 = 0
    DATA 0,..............??????? I don't know how to write this part!!!
    SETPIN:
    SETPIN:
    i = 0 WHILE i<4 PIN = 0 GOSUB KEYPAD LET PIN = num i = i + 1
    WEND
    CHKAMD:
    WRITE 1, PIN
    PAUSE 200
    READ 0, ADMIN
    PAUSE 200
    IF PIN4 = ADMIN THEN
    GREEN = 1
    GOTO SETPIN
    KEYPAD:
    PAUSE 50
    NO_KEY:
    TRISB = %01111000
    PORTB = 0
    IF ((PORTB >> 3)!= %1111)THEN GOTO NO_KEY
    PAUSE 50
    GOTKEY:
    FOR col = 0 to 2
    row = 0 TRISB = (dcd col)^%11111111
    PORTB = 1
    row = PORTB>>3
    IF (row!= %1111)THEN CAL_NUM
    NEXT col
    GOTO GOTKEY
    CAL_NUM:
    YELLOW = 1
    SOUND BUZZER,[100,10]
    PAUSE 500
    YELLOW = 0
    num = (col*3) + (ncd (row^$F))
    Please tell me what changes do i have to make to this program.
    Thanks a million!!!
    Tim B's Avatar
    Tim B Guest
    Here is a sample of code that I have written to scan a 4 x 4 keyboard just remove unwanted scans to reduce the no columns / rows
    Pbp does not have clear so replace that with ??? = 0 also it does not have break so replace that with goto label (label would be just after the endif) Dec replace with let x = x - 1
    It is quite a neat routine and debounces with out using pause, but if you want you can delete that section and use pause.
    Have you looked at my password program here ...
    http://users.picbasic.org/index.php?...cts&category=1
    Tim
    DEVICE 16F628A
    DIM KBRD_PORT AS PORTB
    DIM KBRD_PORT_TRIS AS TRISB
    DIM KBRD_PORT_COLUMNS AS %11110000 ' DEFINE THE COLUMN INPUTS
    DIM KBRD_PORT_ROWS AS %00001111 ' DEFINE THE ROW INPUTS
    DIM KBRD_ROWS AS 4 ' NUMBER OF ROWS IN PORT
    DIM DEBOUNCE_CNT_VAL AS 4
    DIM KBRD_TEMP AS BYTE ' TEMP VARS
    DIM KBRD_TEMP2 AS BYTE ' /
    DIM KEY AS BYTE ' KEY RESULT
    DIM LAST_KEY ' KEY READ IN LAST SCAN
    DIM KEY_FLAGS AS BYTE ' KEY SCAN GEN CONTROL FALGS
    DIM DEBOUNCE_CNTR AS BYTE '
    DIM KEY_PRESSED AS KEY_FLAGS.0 ' GENERAL CONTROL FLAGS
    DIM NEW_KEY AS KEY_FLAGS.1
    PORTB_PULLUPS = 1
    KBRD_PORT_TRIS = KBRD_PORT_COLUMNS ' MAKE THE COLUMNS BITS INPUTS
    GOTO START
    KEYSCAN:
    KBRD_PORT = KBRD_PORT_ROWS ^ KBRD_PORT_ROWS ' SEND ROW LINES LOW
    KBRD_TEMP = KBRD_PORT & %11110000 ' READ ALL THE COLUMNS INPUTS
    IF KBRD_TEMP <> $F0 THEN ' ONLY DO THE REST IF A KEY WAS PRESSED
    KBRD_TEMP = KBRD_ROWS ' NO OF ROWS TO SCAN
    KBRD_TEMP2 = %11111110 ' SET UP MASK
    KEY_PRESSED = 0 ' CLEAR THE FLAG TO START WITH
    CLEAR KEY
    REPEAT
    KBRD_PORT = KBRD_TEMP2 ' WRITE TO THE PORT TO SET THE ROW LOW
    INC KEY
    IF KBRD_PORT.4 = 0 THEN KEY_PRESSED = 1: BREAK ' CHECK COLUMN 1
    INC KEY
    IF KBRD_PORT.5 = 0 THEN KEY_PRESSED = 1: BREAK ' CHECK COLUMN 2
    INC KEY
    IF KBRD_PORT.6 = 0 THEN KEY_PRESSED = 1: BREAK ' CHECK COLUMN 3
    INC KEY
    IF KBRD_PORT.7 = 0 THEN KEY_PRESSED = 1: BREAK ' CHECK COLUMN 4
    DEC KBRD_TEMP
    KBRD_TEMP2 = KBRD_TEMP2 << 1 ' ROTATE THE MASK
    SET KBRD_TEMP2.0 ' SET THE BOTTOM BIT
    UNTIL KBRD_TEMP = 0 ' SCAN ALL THE ROWS
    IF KEY_PRESSED = 1 THEN KEY_SCAN_DONE ' HAS A KEY BEEN PRESSED
    CLEAR KEY ' IF WE GET TO HERE NO KEY HAS BEEN PRESSED
    ' SO MAKE IT READ 0
    KEY_SCAN_DONE:
    LAST_KEY = KEY
    IF KEY = 0 THEN DEC DEBOUNCE_CNTR
    IF DEBOUNCE_CNTR = 0 THEN
    DEBOUNCE_CNTR = DEBOUNCE_CNT_VAL
    NEW_KEY = TRUE
    IF KEY <> LAST_KEY THEN
    NEW_KEY = TRUE
    START:
    CLS ' CLEAR THE LCD
    WHILE 1 = 1
    GOSUB KEYSCAN
    PRINT AT 1,1 DEC KEY ' PRINT TO THE LCD
    DELAYMS 10
    WEND
    Arrow
    Hi pt3rg,
    In case you still want to troubleshoot the original post.
    I think the problem with the first column is due to the
    PORTB = 1 in the GOTKEY routine.
    Since an active keypress must pull the input low to register correctly. Holding a column high prevents it from doing so. Removing the statement should work better.
    As for the EEPROM:
    You are showing ADMIN as a four byte array. So you need to store each byte individually.
    DATA @0, 1,2,3,4 will store the value in locations 0 thru 3
    then to read it back:
    for x = 0 to 3
    Read x, ADMIN[x]
    next x
    Then you'll need to test each byte, against each keypress, for a password match.
    HTH,
    Darrel Taylor
    pt3rg's Avatar
    pt3rg Guest
    Talking
    Thanks a million, Tim and Darrel.
    I managed to troubleshoot my original program and WOW!
    There were more flaws than i thought, but now, thanks to Tim and Darrel, it's fully functioning!!!
    Thanks again.
    pt3rg
    Thumbs up
    Sweat!!
    Glad to hear it, and your welcome.
    Darrel
