can you help me with my project (PIC & temperature sensor & LCD)?
Results 1 to 8 of 8
    Mar 2009
    Colorado
    Default Re: can you help me with my project (PIC & temperature sensor & LCD)?
    Quote Originally Posted by voyage View Post
    Like i said, i didn't write the code, but i believe it's written correctly (as i got it from the original author of that project (it was written in MikroBasic)). So checking the code would be the last thing for me to do.
    I don't quite understand how you expect to use a PicKit3 to program your PIC when the source code is written in Mikrobasic. How are you going to compile the code? A PicKit3 won't compile for you....all it does is program the PIC from a hex file that has to be produced by a compiler. If you are using PicBasic, you need a PBP compiler from MeLabs.
    May 2011
    Quote Originally Posted by jellis00 View Post
    Yes, the source code is in Mikrobasic, but I also have the hex file so all I needed to do was to download it to my PIC and I've done it successfully. It works ok.
    Yeah I forgot to tell my project started to work soon after the testing of my LCD and crystal. Still not totally sure what was wrong earlier, but when I replaced my crystal osc with the new one (and move it closer to PIC pins) and played a bit with LCD display contrast, it suddenly started to work. Thanks for your help and suggestions everyone.
    Surely it would have been simpler to tell us ...
    http://www.elektor.com/magazines/201....1673686.lynkx
    ELEKTOR Project IR Thermometer ...
    program IR_Thermometer
    ' * IR_Thermometer
    ' * Copyright C.TAVERNIER- 2010
    ' * for Elektor Magazine
    ' * www.tavernier-c.com
    ' * Microchip PIC16F876A and
    ' * Melexis MLX90614 IR Thermometer
    ' LCD module connections
    ' LCD used in 4 bits mode on Port B
    dim LCD_RS as sbit  at RB2_bit
        LCD_EN as sbit  at RB3_bit
        LCD_D4 as sbit  at RB4_bit
        LCD_D5 as sbit  at RB5_bit
        LCD_D6 as sbit  at RB6_bit
        LCD_D7 as sbit  at RB7_bit
        LCD_RS_Direction as sbit at TRISB2_bit
        LCD_EN_Direction as sbit at TRISB3_bit
        LCD_D4_Direction as sbit at TRISB4_bit
        LCD_D5_Direction as sbit at TRISB5_bit
        LCD_D6_Direction as sbit at TRISB6_bit
        LCD_D7_Direction as sbit at TRISB7_bit
    ' End LCD module connections
    ' Variable definitions
    dim SensorLow as byte       ' Raw temp. low byte
        SensorHigh as byte      ' Raw temp. high byte
        SensorRaw as word       ' Raw temp. word
        SensorRawCur as word    ' Current raw temp.
        SensorRawMax as word    ' Max. raw temp.
        SensorRawMin as word    ' Min. raw temp.
        Sensor as float         ' Real temp (floating point)
        SensorString as string[9]
        DisplayString as string[9]
        PEC as byte             ' Control byte (read but not used)
        com as byte             ' MLX90614 command
        PosDecPoint as byte     ' Decimal point position
        i as byte
    ' Procedure definition
    ' Read Temperature From MLX90614
    ' Input : com specify temp. to read
    ' Output : raw temp as a word
      Sub procedure Read_temp(dim com as byte)
      I2C1_Start()           ' issue I2C start signal
      I2C1_Wr(0x00)          ' send address (device address + W)
      I2C1_Wr(com)           ' send command
      I2C1_Repeated_Start()  ' issue I2C signal repeated start
      I2C1_Wr(0x01)          ' send address (device address + R)
      SensorLow = I2C1_Rd(1) ' Read temp. low byte (acknowledge)
      SensorHigh = I2C1_Rd(1)' Read temp. high byte (acknowledge)
      PEC = I2C1_Rd(1)       ' Read PEC (not used) (acknowledge)
      I2C1_Stop()            ' issue I2C stop signal
      SensorRaw = SensorLow + (SensorHigh << 8)     ' Build temp. word
      End sub
    ' Convert raw data in SensorRaw
    ' to displayable string in DisplayString
      Sub procedure Convert_raw
      Sensor = SensorRaw * 0.02 - 273.15            ' Raw temp to Celsius
      FloatToStr (Sensor, SensorString)             ' Float to string
      PosDecPoint = Strchr (SensorString,".")       ' Search for dec. point
      For i = 0 to PosDecPoint+2                    ' Limit display to two digits
          DisplayString[i] = SensorString[i]        ' after decimal point
      Next i
      DisplayString[PosDecPoint+3]= ""
      DisplayString = DisplayString + " C"
      End sub
    ' Main Program
    ' Initialize I/O
      PORTB = 0
      TRISB = 0                      ' All PORTB lines as output
      ADCON1  = 0x0F                 ' Configure AN pins as digital I/O
    ' Initialize LCD display
      Lcd_Init()                     ' Initialize Lcd
      Lcd_Cmd(_LCD_CLEAR)            ' Clear display
      Lcd_Cmd(_LCD_CURSOR_OFF)       ' Cursor off
    ' Initialize Min and Max object temp.
      SensorRawMax = 0
      SensorRawMin = 0xFFFF
    ' Initialize SMBus
      I2C1_Init(100000)              ' I2C/SMBus Clock speed 100 kHz
      SETBIT (SSPSTAT,6)             ' Force MSSP in SMBus mode
    while true
        Read_temp (0x06)             ' Read ambiant temp.
        Convert_raw
        Lcd_Out(1,1,"T Amb. : ")     ' Write ambiant temp in first row
        Lcd_Out(1,10,DisplayString)
        Read_temp (0x07)             ' Read object temp.
        SensorRawCur = SensorRaw     ' Make obj. temp. current temp.
        If SensorRawCur > SensorRawMax Then ' Is current temp. higher than max. temp.
           SensorRawMax = SensorRawCur      ' Make max. temp. equal current temp.
        End if
        If SensorRawCur < SensorRawMin Then ' Is current temp. lower than min. temp.
           SensorRawMin = SensorRawCur      ' Make min. temp. equal current temp.
        End if
        Convert_raw
        Lcd_Out(2,1,"T Obj. : ")     ' Write object temp in second row
        Lcd_Out(2,10,DisplayString)
        SensorRaw = SensorRawMax
        Convert_raw
        Lcd_Out(3,1,"T Max. : ")     ' Write Max object temp in third row
        Lcd_Out(3,10,DisplayString)
        SensorRaw = SensorRawMin
        Convert_raw
        Lcd_Out(4,1,"T Min. : ")     ' Write Min object temp in fourth row
        Lcd_Out(4,10,DisplayString)
        Delay_ms (1000)
    wend
    end.
    IR_Thermometer Fuses for a PIC 16F876A
    Oscillator : HS
    Watchdog Timer : Disabled
    Power Up Timer : Disabled
    Brown Out Detect : Enabled
    Low Voltage Program : Disabled
    Data EE Protect : Disabled
    In-Circuit Debugger : Disabled
    Code Protect : None
    FLASH Write Enable : Write Protection Off
