Need more space, please...
Results 1 to 27 of 27
    Dec 2008
    Ploiesti, ROMANIA
    Default Re: Need more space, please...
    I try something like this :
    data @0,$FF,$01,$01,$01,$01,_
    $01,$01,$01,$01,$01,$01,$01,$01,$01,$FD,$FD,$FD,$85,$85,$FD,$FD,$79,_
    $01,$01,$FD,$FD,$FD,$01,$01,$79,$FD,$FD,$85,$A5,$ED,$ED,$69,$01,$01,_
    $FD,$FD,$FD,$01,$05,$05,$05,$FD,$FD,$FD,$05,$05,$05,$01,_
    $F9,$FD,$FD,$25,$25,$FD,$FD,$F9,$01,$01,$FD,$FD,$FD,$81,$81,$81,$81,_
    $01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$FF
    This is the first row.
    But there, how must doing :
                    LcdReg  =  %10000000            ' cursor  X
                    call    PrintCtrlLcd
                    LcdReg  =  %01000000            ' cursor  Y
                    call    PrintCtrlLcd
                    read 0, vcx
                    for y = 0 to 83
                    Lookup y,[??????? vcx ???????], LcdReg
                    call    PrintDataLcd
                    next y
    Thanks !
    Dec 2008
    Ploiesti, ROMANIA
    I did it !!!
    BorderLine:                         '
    '=================================== RAND 0
                     for y = 0 to 83
                     call setcursor
                     read y, LcdReg
                     call    PrintDataLcd
                     next y
    setcursor:
                    LcdReg  =  %10000000 + y           ' cursor  X
                   call    PrintCtrlLcd
                   call    PrintCtrlLcd
    ...and this is the result !
    Dec 2008
    Ploiesti, ROMANIA
    The button alternate the two temperatures (small and big). Full working code ! Thanks for support ! Regards !
    Congratulations !
    Looks Great !
    Now tell us all about it, is that a PIC16F648A or PIC16F628A ?
    What kind of display is that ? Where can get one and for about how much ?
    I see the making of an article in this thread.
    Oh to all who read this post, if you are willing, please rename your code from .bas to .txt becauseWindows XP and up requires you to download and rename and will not open it first. That is my experience on 3 different computers. Win 98 does not care unless you have loaded VB and then it too does not like it.
    Ahhhgh: My dumb self, I see nokia 3310, first line of O. P.
    Dec 2008
    Ploiesti, ROMANIA
    Thanks !
    It's PIC 16F628A ("downgrade" from 16F648A - the reason of this topic) ; display it's from Nokia 3310. Regards !
    Dec 2008
    Ploiesti, ROMANIA
    Default Need again help, please, PLEASE ...
    I re-wrote the code, in attempt to having BIGGER numbers on display !
    This is the code :
    @ DEVICE pic16F648A, INTrc_osc, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_OFF, LVP_OFF, CPD_OFF, PROTECT_OFF
    Define  NO_CLRWDT 1
    DEFINE  OSC 4
            TRISB = %00011100                    'portB configuration  0=out 1=in
            TRISA = %10100000                    'portA configuration
            PortA = %11100000
            CMCON = 7
            VRCON = 0
            INTCON = 0
    OPTION_REG=%00000111                       'weak pullups on, TMRO prescale = 256
    DQ2        VAR PORTB.3
    RST         var  PortA.4   'pin 3   Output   reset display
    SDIN        var  PortA.3   'pin 2   Output   master data out
    SCK         var  PortA.2   'pin 1   Output   Spi clock
    DQ          var  PortB.2   'pin 18  I/O      DQ DS18b20
    D_C         var  PortB.0   'pin 6   Output   command/data sel. register
    Temperature     Var     Word
    TempC           Var     Word
    Sign            Var     Word
    Float           Var     Word
    Dummy           Var     Byte
                LcdReg          var  byte
                x               var  byte
                y               var  byte
                z               var  byte
                Offset          var  byte
                Char            var  byte
                a               var  byte
                PosX            VAR  Byte
                PosY            VAR  Byte
                Chr             VAR  Byte
                LcdData         VAR  Byte
     Cursor          Var  Byte
        Data @0,$FC, $FE, $FE, $06, $00,_
            $00, $06, $FE, $FE, $FC,_
            $7F, $FF, $FF, $C0, $00,_
            $00, $C0, $FF, $FF, $7F,_    ; //0
               $00, $00, $18, $1C, $FE,_
              $FE, $FE, $00, $00, $00,_
            $00, $00, $00, $C0, $FF,_
              $FF, $FF, $C0, $00, $00,_    ; //1
               $00, $3C, $3E, $3E, $06,_
            $86, $FE, $FE, $7C, $00,_
            $00, $E0, $F0, $FC, $FF,_
            $CF, $C7, $C1, $C0, $00,_     ; //2
               $00, $1C, $1E, $9E, $86,_
             $86, $FE, $FE, $FC, $00,_
            $00, $78, $F8, $F9, $C1,_
            $C1, $FF, $FF, $7E, $00,_     ; //3
               $00, $00, $F0, $FE, $7E,_
            $FE, $FE, $FE, $00, $00,_
            $00, $3F, $3F, $37, $30,_
             $FF, $FF, $FF, $30, $00     ; //4
     Data @101, $00, $FE, $FE, $FE, $C6,_
                $00, $C6, $C6, $C6, $86,_
            $71, $F1, $F1, $C0, $00,_
            $00, $C0, $FF, $FF, $7F,_    ; //5
            $00, $FC, $FE, $FE, $C6,_
            $C6, $DE, $DE, $9C, $00,_
            $00, $7F, $FF, $FF, $C0,_
            $C0, $FF, $FF, $7F, $00,_    ; //6
            $00, $06, $06, $06, $86,_
            $E6, $FE, $7E, $1E, $00,_
            $00, $80, $F0, $FE, $3F,_
            $07, $01, $00, $00, $00,_    ; //7
            $00, $7C, $FE, $FE, $86,_
            $00, $7E, $FF, $FF, $C1,_
            $C1, $FF, $FF, $7E, $00,_    ; //8
            $00, $FC, $FE, $FE, $86,_
            $00, $78, $F9, $F9, $C1,_
            $C1, $FF, $FF, $7F, $00        ; //9
                    RST = 1
                    PortB = 0
                    LcdReg  =  %00100001          'LCD Extended Commands.
                    call    PrintCtrlLcd
                    LcdReg  =  $C5                'Set LCD Vop (Contrast).
                    call    PrintCtrlLcd
                    LcdReg  =  %00000110          'Set Temp coefficent.
                    call    PrintCtrlLcd
                    LcdReg  =  %00010011          'LCD bias mode 1:48.
                    call    PrintCtrlLcd
                    LcdReg  =  %00100000          'LCD Standard Commands, Horizontal addressing mode.
                    call    PrintCtrlLcd
                    LcdReg  =  %00001100          'LCD in normal mode
                    call    PrintCtrlLcd
    call CursorHome
    Gosub LCD_Clear
    ' Sensor 1
     OWOut DQ, 1, [$CC, $44]
     OWOut DQ, 1, [$CC, $BE]
     OWIn DQ, 2, [temperature.byte0, temperature.byte1]
    If Temperature.15 then
      Temperature= ~Temperature +1
      sign="-"
    Endif
    Dummy = 625 * Temperature
    TempC = DIV32 10
    TempC = (Temperature & $7FF) >> 4
    Float = ((Temperature.Lowbyte & $0F ) * 25 )>>2
    Temperature = TempC*100 + Float
     call    PrintCtrlLcd
     call    PrintCtrlLcd
                    Char = (temperature dig 1)
                    Call    PrintChar
    LcdReg  =  %10000000  + 5       ' cursor  X
     call    PrintCtrlLcd
     call    PrintCtrlLcd
                    Char = (temperature dig 1 )+ 1
                    Call    PrintChar
     call    PrintCtrlLcd
    LcdReg  =  %01000001            ' cursor  Y
     call    PrintCtrlLcd
                    Char = (temperature dig 1 )+ 2
                    Call    PrintChar
     call    PrintCtrlLcd
     call    PrintCtrlLcd
                    Char = (temperature dig 1 )+ 3
                    Call    PrintChar
    goto Main
    CursorHome:     LcdReg  =  %10000000            ' cursor Home
                    call    PrintCtrlLcd
                    LcdReg  =  %01000000            ' cursor Home
                    call    PrintCtrlLcd
    PrintChar:   offset = Char * 5
                    for a = 1 to 5
                        read offset, LcdReg
                        call  PrintDataLcd
                        offset = offset + 1
                    next a
                    LcdReg = 0
                    call    PrintDataLcd
    PrintCtrlLcd:   D_C = 0
    PrintDataLcd:   for x = 1 to 8
                        SDIN = LcdReg.7
                        SCK = 1
                        LcdReg = LcdReg << 1
                        SCK = 0
                    next x
                    D_C = 1
    Lcd_Clear:
        FOR Cursor = 0 TO 5
            PosX=0:PosY=Cursor:GOSUB Lcd_GotoXY
            HIGH D_C
            LcdData = 0
            FOR Chr = 1 TO 84
                GOSUB LCD_ByteOut
            NEXT Chr
        NEXT Cursor
    LCD_GotoXY:
      LOW D_C
      LcdData=%01000000 | PosY :GOSUB LCD_ByteOut
      LcdData=%10000000 | PosX :GOSUB LCD_ByteOut
    LCD_ByteOut:
      SHIFTOUT SDIN,SCK,1,[LcdData]
    Each number is made - in FastLCD- like in this example :
    But the results are...strange, like this :
    Please, need advice...Thanks in advance !!!
    LE : I use now 16F648A (more EEprom). Attaching ISIS simulating.
    Dec 2008
    Ploiesti, ROMANIA
    Based on this post : http://www.picbasic.co.uk/forum/show...7847#post87847 - Thank You, scalerebotics !!! I re-x-wrote the code. Now I have good results ! But.... HOW can I display all the three digits of var.temperature ?!? Give me a clue, please !!!
    ;             BIG FONTS - need improvements !!!
    @ DEVICE pic16F628A, INTRC_OSC, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_ON, LVP_OFF, CPD_OFF, PROTECT_OFF
    Define  NO_CLRWDT 1
    DEFINE  OSC 4
            PortA = %11100000
            CMCON = 7
            VRCON = 0
            INTCON = 0
    Lcd_DC      var PortB.0
    Lcd_SDA     var PortA.3
    Lcd_RST     var PortA.4
    Lcd_CLK     var PortA.2
    DQ          var PortB.2
    i           var Byte
    j           var Word
    k           var Byte
    Nc          var Byte
    PosX        var Byte
    PosY        var Byte
    LcdStr      var Byte [28]
    Lcd_Data    var Byte
    CharNum     var Byte
    FA VAR BYTE[5] 'upper left of character
    FB VAR BYTE[5] 'upper right of character
    FC VAR BYTE[5] 'lower left of character
    FD VAR BYTE[5] 'lower right of character
    LcdReg          var  Byte
    x               var  Byte
    y               var  Byte
    cursor          var  Byte
    TempC           Var     Word
    Sign            Var     Word
    Float           Var     Word
    Dummy           Var     Byte
    DS18B20_12bit    CON %01111111       ' 750ms,   0.0625°C
    'initialize display-----------------------------------------------
    pause 250
                                                    'Initialize LCD, run 1st this!
        Low Lcd_RST                                 'Reset LCD (HW reset)
        High Lcd_RST                                'Release Reset
        Low Lcd_DC                                  'Command/Data
      Lcd_Data= $21: GOSUB Lcd_SentByte       ' LCD EXTENDED COMMANDS
      Lcd_Data= $c2: GOSUB Lcd_SentByte       ' SET LCD Vop (CONTRAST) era c8
      Lcd_Data= $06: GOSUB Lcd_SentByte       ' SET TEMP COEFFICENT
      Lcd_Data= $13: GOSUB Lcd_Sentbyte       ' LCD BIAS MODE
      Lcd_Data= $20: GOSUB Lcd_Sentbyte       ' LCD STANDARD COMMANDS
      Lcd_Data= $09: GOSUB Lcd_Sentbyte       ; all on
      Lcd_data= $08: gosub lcd_sentbyte       ' lcd blank
      Lcd_Data= $0c: GOSUB Lcd_sentbyte       ' LCD IN NORMAL MODE
    gosub Lcd_Clear                     'Clear contents of screen
    Low Lcd_DC
    Pause 100
    ' Init Sensor 1
     OWOUT DQ, 1, [$CC, $4E, 0, 0, DS18B20_12bit]
     OWOut DQ, 1, [$CC, $48]                   ' Start temperature conversion
     OWOut DQ, 1, [$CC, $B8]
     Pause 50
    sign = " "
    ' Start temp.conv.Sensor1
      sign="-"
    Endif
    TempC = DIV32 10
    LcdStr(2) = 48 + TEMPERATURE dig 1
    LcdStr(1) = 48 + TEMPERATURE dig 2
    LcdStr(0) = 48 + TEMPERATURE dig 3
    Nc=2
    Gosub Lcd_SentString
    gosub afisare
    afisare:
        High Lcd_DC
     call    PrintCtrlLcd
     call    PrintCtrlLcd
        SHiftOUT Lcd_SDA , Lcd_CLK , 1, [ FA(0),FA(1),FA(2),FA(3),FA(4)] 'upper left
     call    PrintCtrlLcd
     call    PrintCtrlLcd
        SHiftOUT Lcd_SDA , Lcd_CLK , 1, [ FB(0),FB(1),FB(2),FB(3),FB(4)] 'upper right
     call    PrintCtrlLcd
     call    PrintCtrlLcd
        SHiftOUT Lcd_SDA , Lcd_CLK , 1, [ FC(0),FC(1),FC(2),FC(3),FC(4)] 'lower left
     call    PrintCtrlLcd
     call    PrintCtrlLcd
        SHiftOUT Lcd_SDA , Lcd_CLK , 1, [ FD(0),FD(1),FD(2),FD(3),FD(4)] 'lower right
        Low Lcd_DC
    Lcd_Clear:
    For cursor = 0 to 5
        PosX=0:PosY=Cursor:Gosub Lcd_GotoXY
        High Lcd_DC
        For i= 1 to 84
              Lcd_Data=0:Gosub Lcd_SentByte
        Next i
    Next cursor
    Lcd_GotoXY:
    Low Lcd_DC
    Lcd_Data=%01000000 | PosY :Gosub Lcd_SentByte    'Y
    Lcd_Data=%10000000 | PosX :Gosub Lcd_SentByte    'X
    Lcd_SentByte:
    SHiftOUT Lcd_SDA , Lcd_CLK , 1, [ Lcd_Data ]
    Lcd_SentString:
    ;For k=0 to Nc-1
    FOR K=0 TO NC
        Lcd_Data=LcdStr(k)
        Gosub Lcd_SentChar
    next k
    Lcd_SentChar:
        lookdown Lcd_data,[" !\#$%&'()*+,-./0123456789:;<=>?@ABCDEFGHIJKLMNOPQRSTUVWXYZ[\]^_`abcdefghijklmnopqrstuvwxyz{|}~"],CharNum
        Lcd_data = CharNum + 32
        SELECT CASE lcd_data
        Case 48 ' a zero
            FA(0)=$00:FA(1)=$FC:FA(2)=$FE:FA(3)=$FE:FA(4)=$06 ' // 0
            FB(0)=$06:FB(1)=$FE:FB(2)=$FE:FB(3)=$FC:FB(4)=$00 ' // 0
            FC(0)=$00:FC(1)=$7F:FC(2)=$FF:FC(3)=$FF:FC(4)=$C0 ' // 0
            FD(0)=$C0:FD(1)=$FF:FD(2)=$FF:FD(3)=$7F:FD(4)=$00 ' // 0
        Case 49 ' a one
            FA(0)=$00:FA(1)=$00:FA(2)=$18:FA(3)=$1C:FA(4)=$FE ' // 1
            FB(0)=$FE:FB(1)=$FE:FB(2)=$00:FB(3)=$00:FB(4)=$00 ' // 1
            FC(0)=$00:FC(1)=$00:FC(2)=$00:FC(3)=$C0:FC(4)=$FF ' // 1
            FD(0)=$FF:FD(1)=$FF:FD(2)=$C0:FD(3)=$00:FD(4)=$00 ' // 1
        Case 50 ' a TWO
            FA(0)=$00:FA(1)=$3C:FA(2)=$3E:FA(3)=$3E:FA(4)=$06 ' // 2
            FB(0)=$86:FB(1)=$FE:FB(2)=$FE:FB(3)=$7C:FB(4)=$00 ' // 2
            FC(0)=$00:FC(1)=$E0:FC(2)=$F0:FC(3)=$FC:FC(4)=$FF ' // 2
            FD(0)=$CF:FD(1)=$C7:FD(2)=$C1:FD(3)=$C0:FD(4)=$00 ' // 2
        Case 51 ' a THREE
            FA(0)=$00:FA(1)=$1C:FA(2)=$1E:FA(3)=$9E:FA(4)=$86 ' // 3
            FB(0)=$86:FB(1)=$FE:FB(2)=$FE:FB(3)=$FC:FB(4)=$00 ' // 3
            FC(0)=$00:FC(1)=$78:FC(2)=$F8:FC(3)=$F9:FC(4)=$C1 ' // 3
            FD(0)=$C1:FD(1)=$FF:FD(2)=$FF:FD(3)=$7E:FD(4)=$00 ' // 3
        Case 52 ' a FOUR
            FA(0)=$00:FA(1)=$00:FA(2)=$F0:FA(3)=$FE:FA(4)=$7E ' // 4
            FB(0)=$FE:FB(1)=$FE:FB(2)=$FE:FB(3)=$00:FB(4)=$00 ' // 4
            FC(0)=$00:FC(1)=$3F:FC(2)=$3F:FC(3)=$37:FC(4)=$30 ' // 4
            FD(0)=$FF:FD(1)=$FF:FD(2)=$FF:FD(3)=$30:FD(4)=$00 ' // 4
        Case 53 ' a FIVE
            FA(0)=$00:FA(1)=$FE:FA(2)=$FE:FA(3)=$FE:FA(4)=$C6 ' // 5
            FB(0)=$C6:FB(1)=$C6:FB(2)=$C6:FB(3)=$86:FB(4)=$00 ' // 5
            FC(0)=$00:FC(1)=$71:FC(2)=$F1:FC(3)=$F1:FC(4)=$C0 ' // 5
            FD(0)=$C0:FD(1)=$FF:FD(2)=$FF:FD(3)=$7F:FD(4)=$00 ' // 5
        Case 54 ' a SIX
            FA(0)=$00:FA(1)=$FC:FA(2)=$FE:FA(3)=$FE:FA(4)=$C6 ' // 6
            FB(0)=$C6:FB(1)=$DE:FB(2)=$DE:FB(3)=$9C:FB(4)=$00 ' // 6
            FC(0)=$00:FC(1)=$7F:FC(2)=$FF:FC(3)=$FF:FC(4)=$C0 ' // 6
            FD(0)=$C0:FD(1)=$FF:FD(2)=$FF:FD(3)=$7F:FD(4)=$00 ' // 6
        Case 55 ' a SEVEN
            FA(0)=$00:FA(1)=$06:FA(2)=$06:FA(3)=$06:FA(4)=$86 ' // 7
            FB(0)=$E6:FB(1)=$FE:FB(2)=$7E:FB(3)=$1E:FB(4)=$00 ' // 7
            FC(0)=$00:FC(1)=$80:FC(2)=$F0:FC(3)=$FE:FC(4)=$3F ' // 7
            FD(0)=$07:FD(1)=$01:FD(2)=$00:FD(3)=$00:FD(4)=$00 ' // 7
        Case 56 ' a EIGHT
            FA(0)=$00:FA(1)=$7C:FA(2)=$FE:FA(3)=$FE:FA(4)=$86 ' // 8
            FB(0)=$86:FB(1)=$FE:FB(2)=$FE:FB(3)=$7C:FB(4)=$00 ' // 8
            FC(0)=$00:FC(1)=$7E:FC(2)=$FF:FC(3)=$FF:FC(4)=$C1 ' // 8
            FD(0)=$C1:FD(1)=$FF:FD(2)=$FF:FD(3)=$7E:FD(4)=$00 ' // 8
        Case 57 ' a NINE
            FA(0)=$00:FA(1)=$FC:FA(2)=$FE:FA(3)=$FE:FA(4)=$86 ' // 9
            FB(0)=$86:FB(1)=$FE:FB(2)=$FE:FB(3)=$FC:FB(4)=$00 ' // 9
            FC(0)=$00:FC(1)=$78:FC(2)=$F9:FC(3)=$F9:FC(4)=$C1 ' // 9
            FD(0)=$C1:FD(1)=$FF:FD(2)=$FF:FD(3)=$7F:FD(4)=$00 ' // 9
        end SELECT
    High Lcd_DC
    PrintCtrlLcd:   LCD_DC = 0
                        LCD_SDA = LcdReg.7
                        LCD_CLK = 1
                        LCD_CLK = 0
                    next x
                    LCD_DC = 1
    Now I have only dig 1 on display ....
