Need more space, please...
Results 1 to 27 of 27
    Dec 2008
    Ploiesti, ROMANIA
    Default Need more space, please...
    I wrote the code for thermometer with two sensors DS18B20 and Nokia 3310 display. Works fine, but...only in 16F648A. I want to use with 16F628A (easier to buy in my location). It' s possible to "minimize" the code ? I think maybe can make something with 'BorderLine:" ...
    Thanks in advance !
    ;              Termo with BIG fonts
    ;                  2 x DS18B20
    ;                Thanks to Gusse !
    ;                    may 2011
    ;                ATTENTION ON SCHEMATIC !!!
    ;                        .oooO
    ;                        (   )   Oooo.
    ;                          \_)    ) /
    ;                                (_/
    @ DEVICE pic16F648A, INTRC_OSC, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_ON, LVP_OFF, CPD_OFF, PROTECT_OFF
    INCLUDE "modedefs.bas"
    Define  NO_CLRWDT 1
    DEFINE  OSC 4
            TRISB = %00011100                    'portB configuration  0=out 1=in
            TRISA = %10100000                    'portA configuration
            PortA = %11100000
            CMCON = 7
            VRCON = 0
            INTCON = 0
    OPTION_REG=%00000111                       'weak pullups on, TMRO prescale = 256
    Lcd_DC      var PortB.0
    Lcd_SDA     var PortA.3
    Lcd_RST     var PortA.4
    Lcd_CLK     var PortA.2
    DQ          var PortB.2
    DQ2        VAR PORTB.3
    buton       var portb.4
    Ts          VAR BIT         ' TYPE Of SPACE, variable / constante
    Tc          VAR byte        ' TYPE Of Charater, normal / big
    Ic          var bit         ' Inverted Char
    i           var Byte
    j           var Word
    k           var Byte
    Tv          var byte        ' Tipo de Variavel que se vai receber
    Nc          var byte        ' Numero de Carateres recebidos no Serin
    PosX        var Byte
    PosY        var Byte
    Letra       var Byte [9]
    LetraA      var byte
    LetraB      var byte
    LcdStr      var Byte [28]
    Lcd_Data    var Byte
    Temperature     Var     Word bank0        : Temperature2    Var     Word bank0
    TempC           Var     Word bank0        : TempC2          Var     Word bank0
    Sign            Var     Word bank0        : Sign2           Var     Word bank0
    Float           Var     Word bank0        : Float2          Var     Word bank0
    V            Var     Word bank0        : V2              Var     Word bank0
    Dummy           Var     Byte bank0        : Dummy2          Var     Byte bank0
                Flag            var  Byte
                SignBit         var  Flag.0
                LcdReg          var  Byte bank0
                x               var  Byte bank0
                y               var  Byte bank0
                Busy            VAR  BIT  bank0
              Cursor        var  Byte bank0
    DS18B20_12bit    CON %01111111       ' 750ms,   0.0625°C
    DS18B20_12bit2   CON %01111111       ' 750ms,   0.0625°C
      Low Lcd_RST
      High Lcd_RST
      Low Lcd_DC
      Lcd_Data= %00100001: Gosub Lcd_SentByte        'LCD EXTENDED COMMANDS
      Lcd_Data= $E4      : Gosub Lcd_SentByte        'SET LCD Vop (CONTRAST)
      Lcd_Data= %00000100: Gosub Lcd_SentByte        'SET TEMP COEFFICENT
      Lcd_Data= %00010000: Gosub Lcd_SentByte        'LCD BIAS MODE 1:48
      Lcd_Data= %00100000: Gosub Lcd_SentByte        'LCD STANDARD COMMANDS
      Lcd_Data= %00001100: Gosub Lcd_SentByte        'LCD IN NORMAL MODE
      Ts = 0                                        'Space constante
      Ic = 0                                        'Blinking OFF
      Gosub Lcd_Clear
    'set contrast
      Low Lcd_DC
      Lcd_Data= %10100100: Gosub Lcd_SentByte          'Set Vop Register
    ' Init Sensor 1
     OWOUT DQ, 1, [$CC, $4E, 0, 0, DS18B20_12bit]
     OWOut DQ, 1, [$CC, $48]                   ' Start temperature conversion
     OWOut DQ, 1, [$CC, $B8]
     OWOut DQ, 1, [$CC, $BE]
     Pause 50
     OWIn DQ, 2, [temperature.byte0, temperature.byte1]
    ' Init Sensor 2
     OWOUT DQ2, 1, [$CC, $4E, 0, 0, DS18B20_12bit2]
     OWOut DQ2, 1, [$CC, $48]                   ' Start temperature conversion
     OWOut DQ2, 1, [$CC, $B8]
     OWOut DQ2, 1, [$CC, $BE]
     Pause 50
     OWIn DQ2, 2, [temperature2.byte0, temperature2.byte1]
     Pause 100
    Call BorderLine
    Part1:
    ' Start temp.conv.Sensor1
     OWOut DQ, 1, [$CC, $44]
    If Temperature.15 then
      Temperature= ~Temperature +1
      Sign  = 1
    Endif
    Dummy = 625 * Temperature
    TempC = DIV32 10
    TempC = (Temperature & $7FF) >> 4
    Float = ((Temperature.Lowbyte & $0F ) * 25 )>>2
    Temperature = TempC*100 + Float
    If Sign=1 then
      V= 10000 - Temperature
      V= 10000 + Temperature
    EndIf
    If V >= 10000 then
      Temperature=V-10000
      sign = " "
      Temperature=10000-V
      sign = "-"
    EndIf
    Part2 :
     OWOut DQ2, 1, [$CC, $44]
    If Temperature2.15 then
      Temperature2= ~Temperature2 +1
      Sign2  = 1
    Endif
    Dummy2 = 625 * Temperature2
    TempC2 = DIV32 10
    TempC2 = (Temperature2 & $7FF) >> 4
    Float2 = ((Temperature2.Lowbyte & $0F ) * 25 )>>2
    Temperature2 = TempC2*100 + Float2
    If Sign2=1 then
      V2= 10000 - Temperature2
      V2= 10000 + Temperature2
    EndIf
    If V2 >= 10000 then
      Temperature2=V2-10000
      sign2 = " "
      Temperature2=10000-V2
      sign2 = "-"
    EndIf
    if buton = 0 then
    gosub buton_on
    gosub buton_off
    buton_on:
    LcdStr(5) = 59                            ' simbol for degree
    LcdStr(4) = 48 + Temperature dig 1
    LcdStr(3) = "."
    LcdStr(2) = 48 + Temperature dig 2
    if Temperature dig 3=0 then
    LcdStr(1) = 32
    LcdStr(1) = 48 + Temperature dig 3
    LcdStr(0) = Sign
    Tc=0
    Nc=6
    PosX=3
    PosY=2
    Gosub Lcd_GotoXY : Gosub Lcd_SentString
    LcdStr(4) = 48 + Temperature2 dig 1
    LcdStr(3) = "."
    LcdStr(2) = 48 + Temperature2 dig 2
    if Temperature2 dig 3=0 then
    LcdStr(1) = 32
    LcdStr(1) = 48 + Temperature2 dig 3
    LcdStr(0) = Sign2
    Tc=2
    Nc=6
    PosX=11
    PosY=3
    Tc=3
    Nc=6
    PosX=11
    PosY=4
    buton_off:
    LcdStr(3) = "."
    LcdStr(1) = 32
    LcdStr(0) = Sign2
    Tc=0
    Nc=6
    PosX=3
    PosY=2
    LcdStr(3) = "."
    LcdStr(1) = 32
    LcdStr(0) = Sign
    Tc=2
    Nc=6
    PosX=11
    PosY=3
    Tc=3
    Nc=6
    PosX=11
    PosY=4
    Lcd_Clear:
    For cursor = 0 to 5
        PosX=0:PosY=Cursor:Gosub Lcd_GotoXY
        High Lcd_DC
        For i= 1 to 84
              Lcd_Data=0:Gosub Lcd_SentByte
        Next i
    Next cursor
    Lcd_GotoXY:
    Low Lcd_DC
    Lcd_Data=%01000000 | PosY :Gosub Lcd_SentByte    'Y
    Lcd_Data=%10000000 | PosX :Gosub Lcd_SentByte    'X
    Lcd_SentByte:
    SHiftOUT Lcd_SDA , Lcd_CLK , MSBFIRST, [ Lcd_Data ]
    Lcd_SentString:
    For k=0 to Nc-1
        Lcd_Data=LcdStr(k)
        Gosub Lcd_SentChar
    next k
    Lcd_SentChar:
    Letra(0)=$00:Letra(1)=$00:Letra(2)=$00:Letra(3)=$00:Letra(4)=$00:Letra(5)=$00
    SELECT CASE lcd_data
    ' CAPITAL LETTERS
    CASE 32
    Tv=1        '
    CASE 42
    Tv=5:Letra(0)=$14: Letra(1)=$08:Letra(2)=$3E:Letra(3)=$08: Letra(4)=$14        '*
    CASE 43
    ;Tv=5:Letra(0)=$10: Letra(1)=$10:Letra(2)=$7C:Letra(3)=$10: Letra(4)=$10        '+
    Tv=5:Letra(0)=$08: Letra(1)=$08:Letra(2)=$3E:Letra(3)=$08: Letra(4)=$08        '+
    CASE 45
    Tv=5:Letra(0)=$08: Letra(1)=$08:Letra(2)=$08:Letra(3)=$08: Letra(4)=$08        '-
    CASE 46
    ;Tv=3:Letra(1)=$C0: Letra(2)=$C0                                               '.
    Tv=1:Letra(1)=$60 : Letra(2)=$60                                              '.
    case 47
    Tv=4:Letra(0)=96 : Letra(1)=48 :Letra(2)=24    :Letra(3)=12 : Letra(4)=06  '/
    CASE 48
    ;Tv=5:Letra(0)=$7E: Letra(1)=$A1:Letra(2)=$91:Letra(3)=$89: Letra(4)=$7E        '0
    Tv=5:Letra(0)=$3E: Letra(1)=$51:Letra(2)=$49:Letra(3)=$45: Letra(4)=$3E        '0
    CASE 49
    ;Tv=4:Letra(1)=$82: Letra(2)=$FF:Letra(3)=$80                                        '1
    Tv=4:Letra(1)=$42: Letra(2)=$7F:Letra(3)=$40                                '1
    CASE 50
    ;Tv=5:Letra(0)=$86: Letra(1)=$C1:Letra(2)=$A1:Letra(3)=$91: Letra(4)=$8E        '2
    Tv=5:Letra(0)=$42: Letra(1)=$61:Letra(2)=$51:Letra(3)=$49: Letra(4)=$46        '2
    CASE 51
    ;Tv=5:Letra(0)=$62: Letra(1)=$81:Letra(2)=$89:Letra(3)=$89: Letra(4)=$76        '3
    Tv=5:Letra(0)=$21: Letra(1)=$41:Letra(2)=$45:Letra(3)=$4B: Letra(4)=$31        '3
    CASE 52
    ;Tv=5:Letra(0)=$38: Letra(1)=$24:Letra(2)=$22:Letra(3)=$FF: Letra(4)=$20        '4
    Tv=5:Letra(0)=$18: Letra(1)=$14:Letra(2)=$12:Letra(3)=$7F: Letra(4)=$10        '4
    CASE 53
    ;Tv=5:Letra(0)=$4F: Letra(1)=$89:Letra(2)=$89:Letra(3)=$89: Letra(4)=$71        '5
    Tv=5:Letra(0)=$27: Letra(1)=$45:Letra(2)=$45:Letra(3)=$45: Letra(4)=$39        '5
    CASE 54
    ;Tv=5:Letra(0)=$7E: Letra(1)=$89:Letra(2)=$89:Letra(3)=$89: Letra(4)=$72              '6
    Tv=5:Letra(0)=$3C: Letra(1)=$4A:Letra(2)=$49:Letra(3)=$49: Letra(4)=$30     '6
    CASE 55
    ;Tv=5:Letra(0)=$01: Letra(1)=$E1:Letra(2)=$11:Letra(3)=$09: Letra(4)=$07        '7
    Tv=5:Letra(0)=$01: Letra(1)=$71:Letra(2)=$09:Letra(3)=$05: Letra(4)=$03        '7
    CASE 56
    ;Tv=5:Letra(0)=$76: Letra(1)=$89:Letra(2)=$89:Letra(3)=$89: Letra(4)=$76        '8
    Tv=5:Letra(0)=$36: Letra(1)=$49:Letra(2)=$49:Letra(3)=$49: Letra(4)=$36        '8
    CASE 57
    ;Tv=5:Letra(0)=$46: Letra(1)=$89:Letra(2)=$89:Letra(3)=$89: Letra(4)=$7E        '9
    Tv=5:Letra(0)=$06: Letra(1)=$49:Letra(2)=$49:Letra(3)=$29: Letra(4)=$1E        '9
    CASE 58
    Tv=3:Letra(1)=$36: Letra(2)=$36                                             ':
    CASE 59
    Tv=5:Letra(0)=$02: Letra(1)=$05: Letra(2)=$32: Letra(3)=$48: Letra(4)=$48   'simbol grade
    end select
    High Lcd_DC
    If Tc = 0 Then              ' Normal Charater
        iF Ts = 0 tHEN
            j = 5               ' CONSTANTE SPACE (6)
        Else
            j = Tv              ' VARIABLE SPACE
            for I=0 to j
                If Ic=0 Then    ' Normal Charater
                ShiftOUT Lcd_SDA , Lcd_CLK , 1 , [ Letra(I)]
                else            ' Inverted Charater
                ShiftOUT Lcd_SDA , Lcd_CLK , 1 , [ (127-Letra(I))+128 ]
            next I
    Endif                   ' Double Charater
    ' Tc = 1   Nothing to change       2 x 1
    If Tc = 2  Then         ' 1ª time of 2x2
       for i = 0 to 5
            LetraA = Letra(i)
            LetraB.0 = LetraA.0
            LetraB.1 = LetraA.0
            LetraB.2 = LetraA.1
            LetraB.3 = LetraA.1
            LetraB.4 = LetraA.2
            LetraB.5 = LetraA.2
            LetraB.6 = LetraA.3
            LetraB.7 = LetraA.3
            Letra(i) = LetraB
        next i
    ENdif
    If TC = 3 then      ' 2ª time of 2x2
        for i = 0 to 5
            LetraA = Letra(i)
            LetraB.0 = LetraA.4
            LetraB.1 = LetraA.4
            LetraB.2 = LetraA.5
            LetraB.3 = LetraA.5
            LetraB.4 = LetraA.6
            LetraB.5 = LetraA.6
            LetraB.6 = LetraA.7
            LetraB.7 = LetraA.7
            Letra(i) = LetraB
        next i
        iF Ts = 0 tHEN
        Else
            for I=0 to j
    ShiftOUT Lcd_SDA , Lcd_CLK , 1 , [ Letra(I), Letra(i) ]
    ShiftOUT Lcd_SDA , Lcd_CLK , 1 , [ (127-Letra(I))+128, (127-Letra(I))+128 ]
            next I
    BorderLine:                         '
    '=================================== RAND 0
                    LcdReg  =  %10000000            ' cursor  X
                   call    PrintCtrlLcd
                    LcdReg  =  %01000000            ' cursor  Y
                   call    PrintCtrlLcd
                     for y = 0 to 83
                      LOokup y, [$FF,$01,$01,$01,$01,_
                                 $01,$01,$01,$01,$01,$01,$01,$01,$01,$FD,$FD,$FD,$85,$85,$FD,$FD,$79,_        'D
                                 $01,$01,$FD,$FD,$FD,$01,$01,$79,$FD,$FD,$85,$A5,$ED,$ED,$69,$01,$01,_        'IG
                                 $FD,$FD,$FD,$01,$05,$05,$05,$FD,$FD,$FD,$05,$05,$05,$01,_                    'IT
                                 $F9,$FD,$FD,$25,$25,$FD,$FD,$F9,$01,$01,$FD,$FD,$FD,$81,$81,$81,$81,_        'AL
                                 $01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$FF] ,LcdReg
                       call    PrintDataLcd
                        next y
    '===================================  RAND 1
                   call    PrintCtrlLcd
                    LcdReg  =  %01000001                ' cursor  Y
                   call    PrintCtrlLcd
                   LOokup 0, [$FF] , LcdReg
                   call    PrintDataLcd
                    LcdReg  =  %10000000 + 83                ' cursor  X
                   call    PrintCtrlLcd
                   call    PrintCtrlLcd
                   call    PrintDataLcd
    '===================================  RAND 2
                   call    PrintCtrlLcd
                    LcdReg  =  %01000010                ' cursor  Y
                   call    PrintCtrlLcd
                   call    PrintDataLcd
                   call    PrintCtrlLcd
                   call    PrintCtrlLcd
                   call    PrintDataLcd
    '===================================  RAND 3
                   call    PrintCtrlLcd
                    LcdReg  =  %01000011                ' cursor  Y
                   call    PrintCtrlLcd
                   call    PrintDataLcd
                   call    PrintCtrlLcd
                   call    PrintCtrlLcd
                   call    PrintDataLcd
    '===================================  RAND 4
                   call    PrintCtrlLcd
                    LcdReg  =  %01000100                ' cursor  Y
                   call    PrintCtrlLcd
                   call    PrintDataLcd
                   call    PrintCtrlLcd
                   call    PrintCtrlLcd
                   call    PrintDataLcd
    '===================================  JOS
                    call    PrintCtrlLcd
                    LcdReg  =  %01000101            ' cursor  Y
                    call    PrintCtrlLcd
                    for y = 0 to 83
        LOokup y, [$FF,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,_
                 $80,$80,$80,$80,$81,$81,$81,$BF,$BF,$BF,$81,$81,$81,$80,$BF,$BF,$BF,$A9,_
                 $A9,$A9,$A1,$80,$BF,$BF,$BF,$89,$89,$99,$A6,$80,$BF,$BF,$BF,$82,_
                 $84,$82,$BF,$BF,$BF,$80,$9E,$BF,$BF,$A1,$A1,$BF,$BF,$9E,$80,_
                 $80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,_
               $80,$80,$80,$80,$FF] ,LcdReg
                    call    PrintDataLcd
                    next y
    PrintCtrlLcd:   LCD_DC = 0
    PrintDataLcd:   for x = 1 to 8
                        LCD_SDA = LcdReg.7
                        LCD_CLK = 1
                        LcdReg = LcdReg << 1
                        LCD_CLK = 0
                    next x
                    LCD_DC = 1
    END           ' of program
    Default Re: Need more space, please...
    Have you considered using two 16F628A?
    Use 1 as master to control sensor, use the other as slave to control the LCD, communicate between the 2 using USART?
    That would split the burden.
    Dec 2008
    Ploiesti, ROMANIA
    Thanks...but... NO WAY ! I try to make it "low cost" ...
    Bombay, India
    You might be able to save a little space if you can SUB the digit conversion routines that are repeated in some places. It may gain you some words of space, but, beyond that, you may need to forego the borderline routine altogether(just a guess) or convert it into a code based border function rather than table driven.
    Quote Originally Posted by fratello View Post
    Hi Fratello,
    You are not the first person to mention this about this chip or that chip. I am just curious about the hardships of getting a part as old as the PIC16F648A in quantity? I can see it being a hardship if you can't get it at the local vendor, and don't want to order abroad for low numbers. But is it really that hard (or expensive) to get them by 25 or more? It sounds like your project is going to be marketed.
    Maybe I am just spoiled by being able to get things from any country, pretty easily.
    Again, just curious. Not doubting you, just wondering "easier to get" means.
    Dec 2008
    Ploiesti, ROMANIA
    I live in one small city from Romania ! Even one resistor must be purchased by e-commerce . at e-vendors the 16F648A have double price from 16F628A. And one great vendor (TME.EU) don't sell to persons, just company , from april, this year...
    So, I try to make the best I can with limited resources. Thanks again for support !
    I think you can save a little space by not including "modedefs.bas"
    You will need to change this line.
    To:
    SHiftOUT Lcd_SDA , Lcd_CLK , 1, [ Lcd_Data ]
    Dec 2008
    Ploiesti, ROMANIA
    Still " address limit of 7ffh exceeded" ...
    Fratello,
    check your pm please
    Best Regards,
    Bogdan Pitic
    Dec 2008
    Ploiesti, ROMANIA
    I have results...
      sign="-"
    Endif
    and removing older parts refering to "sign" and "sign2".
    Now it's ok, but still wonder if can I store some "graphical elements" into eeprom...
    . . . And one great vendor (TME.EU) don't sell to persons, just company. . . !
    Hmmmm . . . Fratello International, Fratello Engineering , Fratello Imports , Fratello Enterprises, Hot Ziggidy those roses smell great . . . oops . . . Fratello Technologies.EU
    Dec 2008
    Ploiesti, ROMANIA
    Sorry for off-topic...My salary it's about 350 euro/month ; so, it's important if one IC cost 1 or 2 euro - it's just hobby !
    And "Fratello Enterprise(s)" it's verry cool ... I love Star Trek !!!
    Business' often request and receive FREE samples. You are a small prototype company are you not ? You do develop products for others ? No employees required. No lies told. No money made ? That's a trade secret.
    Dec 2008
    Ploiesti, ROMANIA
    I try something like this :
    data @0,$FF,$01,$01,$01,$01,_
    This is the first row.
    But there, how must doing :
                    call    PrintCtrlLcd
                    call    PrintCtrlLcd
                    read 0, vcx
                    for y = 0 to 83
                    Lookup y,[??????? vcx ???????], LcdReg
                    call    PrintDataLcd
                    next y
    Thanks !
    Dec 2008
    Ploiesti, ROMANIA
    I did it !!!
    BorderLine:                         '
                     for y = 0 to 83
                     call setcursor
                     read y, LcdReg
                     call    PrintDataLcd
                     next y
    setcursor:
                    LcdReg  =  %10000000 + y           ' cursor  X
                   call    PrintCtrlLcd
                   call    PrintCtrlLcd
    ...and this is the result !
    Dec 2008
    Ploiesti, ROMANIA
    The button alternate the two temperatures (small and big). Full working code ! Thanks for support ! Regards !
    Congratulations !
    Looks Great !
    Now tell us all about it, is that a PIC16F648A or PIC16F628A ?
    What kind of display is that ? Where can get one and for about how much ?
    I see the making of an article in this thread.
    Oh to all who read this post, if you are willing, please rename your code from .bas to .txt becauseWindows XP and up requires you to download and rename and will not open it first. That is my experience on 3 different computers. Win 98 does not care unless you have loaded VB and then it too does not like it.
    Ahhhgh: My dumb self, I see nokia 3310, first line of O. P.
    Dec 2008
    Ploiesti, ROMANIA
    Thanks !
    It's PIC 16F628A ("downgrade" from 16F648A - the reason of this topic) ; display it's from Nokia 3310. Regards !
    Dec 2008
    Ploiesti, ROMANIA
    Default Need again help, please, PLEASE ...
    I re-wrote the code, in attempt to having BIGGER numbers on display !
    This is the code :
    @ DEVICE pic16F648A, INTrc_osc, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_OFF, LVP_OFF, CPD_OFF, PROTECT_OFF
    Define  NO_CLRWDT 1
    DEFINE  OSC 4
            PortA = %11100000
            CMCON = 7
            VRCON = 0
            INTCON = 0
    DQ2        VAR PORTB.3
    RST         var  PortA.4   'pin 3   Output   reset display
    SDIN        var  PortA.3   'pin 2   Output   master data out
    SCK         var  PortA.2   'pin 1   Output   Spi clock
    DQ          var  PortB.2   'pin 18  I/O      DQ DS18b20
    D_C         var  PortB.0   'pin 6   Output   command/data sel. register
    TempC           Var     Word
    Sign            Var     Word
    Float           Var     Word
    Dummy           Var     Byte
                LcdReg          var  byte
                x               var  byte
                y               var  byte
                z               var  byte
                Offset          var  byte
                Char            var  byte
                a               var  byte
                PosX            VAR  Byte
                PosY            VAR  Byte
                Chr             VAR  Byte
                LcdData         VAR  Byte
     Cursor          Var  Byte
        Data @0,$FC, $FE, $FE, $06, $00,_
            $00, $06, $FE, $FE, $FC,_
            $7F, $FF, $FF, $C0, $00,_
            $00, $C0, $FF, $FF, $7F,_    ; //0
               $00, $00, $18, $1C, $FE,_
              $FE, $FE, $00, $00, $00,_
            $00, $00, $00, $C0, $FF,_
              $FF, $FF, $C0, $00, $00,_    ; //1
               $00, $3C, $3E, $3E, $06,_
            $86, $FE, $FE, $7C, $00,_
            $00, $E0, $F0, $FC, $FF,_
            $CF, $C7, $C1, $C0, $00,_     ; //2
               $00, $1C, $1E, $9E, $86,_
             $86, $FE, $FE, $FC, $00,_
            $00, $78, $F8, $F9, $C1,_
            $C1, $FF, $FF, $7E, $00,_     ; //3
               $00, $00, $F0, $FE, $7E,_
            $FE, $FE, $FE, $00, $00,_
            $00, $3F, $3F, $37, $30,_
             $FF, $FF, $FF, $30, $00     ; //4
     Data @101, $00, $FE, $FE, $FE, $C6,_
                $00, $C6, $C6, $C6, $86,_
            $71, $F1, $F1, $C0, $00,_
            $00, $C0, $FF, $FF, $7F,_    ; //5
            $00, $FC, $FE, $FE, $C6,_
            $C6, $DE, $DE, $9C, $00,_
            $00, $7F, $FF, $FF, $C0,_
            $C0, $FF, $FF, $7F, $00,_    ; //6
            $00, $06, $06, $06, $86,_
            $E6, $FE, $7E, $1E, $00,_
            $00, $80, $F0, $FE, $3F,_
            $07, $01, $00, $00, $00,_    ; //7
            $00, $7C, $FE, $FE, $86,_
            $00, $7E, $FF, $FF, $C1,_
            $C1, $FF, $FF, $7E, $00,_    ; //8
            $00, $FC, $FE, $FE, $86,_
            $00, $78, $F9, $F9, $C1,_
            $C1, $FF, $FF, $7F, $00        ; //9
                    RST = 1
                    PortB = 0
                    LcdReg  =  %00100001          'LCD Extended Commands.
                    call    PrintCtrlLcd
                    LcdReg  =  $C5                'Set LCD Vop (Contrast).
                    call    PrintCtrlLcd
                    LcdReg  =  %00000110          'Set Temp coefficent.
                    call    PrintCtrlLcd
                    LcdReg  =  %00010011          'LCD bias mode 1:48.
                    call    PrintCtrlLcd
                    LcdReg  =  %00100000          'LCD Standard Commands, Horizontal addressing mode.
                    call    PrintCtrlLcd
                    LcdReg  =  %00001100          'LCD in normal mode
                    call    PrintCtrlLcd
    call CursorHome
    Gosub LCD_Clear
    ' Sensor 1
      sign="-"
    Endif
    TempC = DIV32 10
     call    PrintCtrlLcd
     call    PrintCtrlLcd
                    Char = (temperature dig 1)
                    Call    PrintChar
    LcdReg  =  %10000000  + 5       ' cursor  X
     call    PrintCtrlLcd
     call    PrintCtrlLcd
                    Char = (temperature dig 1 )+ 1
                    Call    PrintChar
     call    PrintCtrlLcd
     call    PrintCtrlLcd
                    Char = (temperature dig 1 )+ 2
                    Call    PrintChar
     call    PrintCtrlLcd
     call    PrintCtrlLcd
                    Char = (temperature dig 1 )+ 3
                    Call    PrintChar
    goto Main
    CursorHome:     LcdReg  =  %10000000            ' cursor Home
                    call    PrintCtrlLcd
                    LcdReg  =  %01000000            ' cursor Home
                    call    PrintCtrlLcd
    PrintChar:   offset = Char * 5
                    for a = 1 to 5
                        read offset, LcdReg
                        call  PrintDataLcd
                        offset = offset + 1
                    next a
                    LcdReg = 0
                    call    PrintDataLcd
    PrintCtrlLcd:   D_C = 0
                        SDIN = LcdReg.7
                        SCK = 1
                        SCK = 0
                    next x
                    D_C = 1
    Lcd_Clear:
        FOR Cursor = 0 TO 5
            PosX=0:PosY=Cursor:GOSUB Lcd_GotoXY
            HIGH D_C
            LcdData = 0
            FOR Chr = 1 TO 84
                GOSUB LCD_ByteOut
            NEXT Chr
        NEXT Cursor
    LCD_GotoXY:
      LOW D_C
      LcdData=%01000000 | PosY :GOSUB LCD_ByteOut
      LcdData=%10000000 | PosX :GOSUB LCD_ByteOut
    LCD_ByteOut:
      SHIFTOUT SDIN,SCK,1,[LcdData]
    Each number is made - in FastLCD- like in this example :
    But the results are...strange, like this :
    Please, need advice...Thanks in advance !!!
    LE : I use now 16F648A (more EEprom). Attaching ISIS simulating.
    Dec 2008
    Ploiesti, ROMANIA
    Based on this post : http://www.picbasic.co.uk/forum/show...7847#post87847 - Thank You, scalerebotics !!! I re-x-wrote the code. Now I have good results ! But.... HOW can I display all the three digits of var.temperature ?!? Give me a clue, please !!!
    ;             BIG FONTS - need improvements !!!
    @ DEVICE pic16F628A, INTRC_OSC, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_ON, LVP_OFF, CPD_OFF, PROTECT_OFF
    Define  NO_CLRWDT 1
    DEFINE  OSC 4
            PortA = %11100000
            CMCON = 7
            VRCON = 0
            INTCON = 0
    Lcd_DC      var PortB.0
    Lcd_SDA     var PortA.3
    Lcd_RST     var PortA.4
    Lcd_CLK     var PortA.2
    DQ          var PortB.2
    i           var Byte
    j           var Word
    k           var Byte
    Nc          var Byte
    PosX        var Byte
    PosY        var Byte
    Lcd_Data    var Byte
    CharNum     var Byte
    FA VAR BYTE[5] 'upper left of character
    FB VAR BYTE[5] 'upper right of character
    FC VAR BYTE[5] 'lower left of character
    FD VAR BYTE[5] 'lower right of character
    LcdReg          var  Byte
    x               var  Byte
    y               var  Byte
    cursor          var  Byte
    TempC           Var     Word
    Sign            Var     Word
    Float           Var     Word
    Dummy           Var     Byte
    'initialize display-----------------------------------------------
    pause 250
                                                    'Initialize LCD, run 1st this!
        Low Lcd_RST                                 'Reset LCD (HW reset)
        High Lcd_RST                                'Release Reset
        Low Lcd_DC                                  'Command/Data
      Lcd_Data= $21: GOSUB Lcd_SentByte       ' LCD EXTENDED COMMANDS
      Lcd_Data= $c2: GOSUB Lcd_SentByte       ' SET LCD Vop (CONTRAST) era c8
      Lcd_Data= $06: GOSUB Lcd_SentByte       ' SET TEMP COEFFICENT
      Lcd_Data= $13: GOSUB Lcd_Sentbyte       ' LCD BIAS MODE
      Lcd_Data= $20: GOSUB Lcd_Sentbyte       ' LCD STANDARD COMMANDS
      Lcd_Data= $09: GOSUB Lcd_Sentbyte       ; all on
      Lcd_data= $08: gosub lcd_sentbyte       ' lcd blank
      Lcd_Data= $0c: GOSUB Lcd_sentbyte       ' LCD IN NORMAL MODE
    gosub Lcd_Clear                     'Clear contents of screen
    Low Lcd_DC
    Pause 100
    ' Init Sensor 1
     Pause 50
    sign = " "
      sign="-"
    Endif
    TempC = DIV32 10
    LcdStr(2) = 48 + TEMPERATURE dig 1
    LcdStr(1) = 48 + TEMPERATURE dig 2
    LcdStr(0) = 48 + TEMPERATURE dig 3
    Nc=2
    gosub afisare
    afisare:
        High Lcd_DC
     call    PrintCtrlLcd
     call    PrintCtrlLcd
        SHiftOUT Lcd_SDA , Lcd_CLK , 1, [ FA(0),FA(1),FA(2),FA(3),FA(4)] 'upper left
     call    PrintCtrlLcd
     call    PrintCtrlLcd
        SHiftOUT Lcd_SDA , Lcd_CLK , 1, [ FB(0),FB(1),FB(2),FB(3),FB(4)] 'upper right
     call    PrintCtrlLcd
     call    PrintCtrlLcd
        SHiftOUT Lcd_SDA , Lcd_CLK , 1, [ FC(0),FC(1),FC(2),FC(3),FC(4)] 'lower left
     call    PrintCtrlLcd
     call    PrintCtrlLcd
        SHiftOUT Lcd_SDA , Lcd_CLK , 1, [ FD(0),FD(1),FD(2),FD(3),FD(4)] 'lower right
        Low Lcd_DC
    Lcd_Clear:
    For cursor = 0 to 5
        High Lcd_DC
        For i= 1 to 84
        Next i
    Next cursor
    Lcd_GotoXY:
    Low Lcd_DC
    Lcd_SentByte:
    Lcd_SentString:
    ;For k=0 to Nc-1
    FOR K=0 TO NC
        Lcd_Data=LcdStr(k)
        Gosub Lcd_SentChar
    next k
    Lcd_SentChar:
        lookdown Lcd_data,[" !\#$%&'()*+,-./0123456789:;<=>?@ABCDEFGHIJKLMNOPQRSTUVWXYZ[\]^_`abcdefghijklmnopqrstuvwxyz{|}~"],CharNum
        Lcd_data = CharNum + 32
        Case 48 ' a zero
            FA(0)=$00:FA(1)=$FC:FA(2)=$FE:FA(3)=$FE:FA(4)=$06 ' // 0
            FB(0)=$06:FB(1)=$FE:FB(2)=$FE:FB(3)=$FC:FB(4)=$00 ' // 0
            FC(0)=$00:FC(1)=$7F:FC(2)=$FF:FC(3)=$FF:FC(4)=$C0 ' // 0
            FD(0)=$C0:FD(1)=$FF:FD(2)=$FF:FD(3)=$7F:FD(4)=$00 ' // 0
        Case 49 ' a one
            FA(0)=$00:FA(1)=$00:FA(2)=$18:FA(3)=$1C:FA(4)=$FE ' // 1
            FB(0)=$FE:FB(1)=$FE:FB(2)=$00:FB(3)=$00:FB(4)=$00 ' // 1
            FC(0)=$00:FC(1)=$00:FC(2)=$00:FC(3)=$C0:FC(4)=$FF ' // 1
            FD(0)=$FF:FD(1)=$FF:FD(2)=$C0:FD(3)=$00:FD(4)=$00 ' // 1
        Case 50 ' a TWO
            FA(0)=$00:FA(1)=$3C:FA(2)=$3E:FA(3)=$3E:FA(4)=$06 ' // 2
            FB(0)=$86:FB(1)=$FE:FB(2)=$FE:FB(3)=$7C:FB(4)=$00 ' // 2
            FC(0)=$00:FC(1)=$E0:FC(2)=$F0:FC(3)=$FC:FC(4)=$FF ' // 2
            FD(0)=$CF:FD(1)=$C7:FD(2)=$C1:FD(3)=$C0:FD(4)=$00 ' // 2
        Case 51 ' a THREE
            FA(0)=$00:FA(1)=$1C:FA(2)=$1E:FA(3)=$9E:FA(4)=$86 ' // 3
            FB(0)=$86:FB(1)=$FE:FB(2)=$FE:FB(3)=$FC:FB(4)=$00 ' // 3
            FC(0)=$00:FC(1)=$78:FC(2)=$F8:FC(3)=$F9:FC(4)=$C1 ' // 3
            FD(0)=$C1:FD(1)=$FF:FD(2)=$FF:FD(3)=$7E:FD(4)=$00 ' // 3
        Case 52 ' a FOUR
            FA(0)=$00:FA(1)=$00:FA(2)=$F0:FA(3)=$FE:FA(4)=$7E ' // 4
            FB(0)=$FE:FB(1)=$FE:FB(2)=$FE:FB(3)=$00:FB(4)=$00 ' // 4
            FC(0)=$00:FC(1)=$3F:FC(2)=$3F:FC(3)=$37:FC(4)=$30 ' // 4
            FD(0)=$FF:FD(1)=$FF:FD(2)=$FF:FD(3)=$30:FD(4)=$00 ' // 4
        Case 53 ' a FIVE
            FA(0)=$00:FA(1)=$FE:FA(2)=$FE:FA(3)=$FE:FA(4)=$C6 ' // 5
            FB(0)=$C6:FB(1)=$C6:FB(2)=$C6:FB(3)=$86:FB(4)=$00 ' // 5
            FC(0)=$00:FC(1)=$71:FC(2)=$F1:FC(3)=$F1:FC(4)=$C0 ' // 5
            FD(0)=$C0:FD(1)=$FF:FD(2)=$FF:FD(3)=$7F:FD(4)=$00 ' // 5
        Case 54 ' a SIX
            FA(0)=$00:FA(1)=$FC:FA(2)=$FE:FA(3)=$FE:FA(4)=$C6 ' // 6
            FB(0)=$C6:FB(1)=$DE:FB(2)=$DE:FB(3)=$9C:FB(4)=$00 ' // 6
            FC(0)=$00:FC(1)=$7F:FC(2)=$FF:FC(3)=$FF:FC(4)=$C0 ' // 6
            FD(0)=$C0:FD(1)=$FF:FD(2)=$FF:FD(3)=$7F:FD(4)=$00 ' // 6
        Case 55 ' a SEVEN
            FA(0)=$00:FA(1)=$06:FA(2)=$06:FA(3)=$06:FA(4)=$86 ' // 7
            FB(0)=$E6:FB(1)=$FE:FB(2)=$7E:FB(3)=$1E:FB(4)=$00 ' // 7
            FC(0)=$00:FC(1)=$80:FC(2)=$F0:FC(3)=$FE:FC(4)=$3F ' // 7
            FD(0)=$07:FD(1)=$01:FD(2)=$00:FD(3)=$00:FD(4)=$00 ' // 7
        Case 56 ' a EIGHT
            FA(0)=$00:FA(1)=$7C:FA(2)=$FE:FA(3)=$FE:FA(4)=$86 ' // 8
            FB(0)=$86:FB(1)=$FE:FB(2)=$FE:FB(3)=$7C:FB(4)=$00 ' // 8
            FC(0)=$00:FC(1)=$7E:FC(2)=$FF:FC(3)=$FF:FC(4)=$C1 ' // 8
            FD(0)=$C1:FD(1)=$FF:FD(2)=$FF:FD(3)=$7E:FD(4)=$00 ' // 8
        Case 57 ' a NINE
            FA(0)=$00:FA(1)=$FC:FA(2)=$FE:FA(3)=$FE:FA(4)=$86 ' // 9
            FB(0)=$86:FB(1)=$FE:FB(2)=$FE:FB(3)=$FC:FB(4)=$00 ' // 9
            FC(0)=$00:FC(1)=$78:FC(2)=$F9:FC(3)=$F9:FC(4)=$C1 ' // 9
            FD(0)=$C1:FD(1)=$FF:FD(2)=$FF:FD(3)=$7F:FD(4)=$00 ' // 9
        end SELECT
    High Lcd_DC
                        LCD_SDA = LcdReg.7
                        LCD_CLK = 1
                        LCD_CLK = 0
                    next x
                    LCD_DC = 1
    Now I have only dig 1 on display ....
    Dec 2008
    Ploiesti, ROMANIA
    Dec 2008
    Ploiesti, ROMANIA
    Default Me, again...
    Hope not disturb !
    This is my last variant of dual thermometer.
    Last edited by fratello; - 1st June 2011 at 19:30. Reason: ...maybe someone want the code...
    Default Re: Me, again...
    Hope not disturb !
    Fratello,
    This is your thread.
    You can post anything you consider relevant to this subject; more info on components, ideas about schematic, or more questions on code.
    And congratulations on achieving your objectives!
    Dec 2008
    Ploiesti, ROMANIA
    Thank You so much for support !
    ...another fonts...
    Dec 2008
    Ploiesti, ROMANIA
    Instead :
    BorderLine:                         '
                     for y = 0 to 83
                     call setcursor
                     read y, LcdReg
                     call    PrintDataLcd
                     next y
                   call    PrintCtrlLcd
                   call    PrintCtrlLcd
                   call    PrintDataLcd
                   call    PrintCtrlLcd
                   call    PrintCtrlLcd
                   call    PrintDataLcd
                   call    PrintCtrlLcd
                   call    PrintCtrlLcd
                   call    PrintDataLcd
                   call    PrintCtrlLcd
                   call    PrintCtrlLcd
                   call    PrintDataLcd
                   call    PrintCtrlLcd
                   call    PrintCtrlLcd
                   call    PrintDataLcd
                   call    PrintCtrlLcd
                   call    PrintCtrlLcd
                   call    PrintDataLcd
                   call    PrintCtrlLcd
                   call    PrintCtrlLcd
                   call    PrintDataLcd
                   call    PrintCtrlLcd
                   call    PrintCtrlLcd
                   call    PrintDataLcd
                    call    PrintCtrlLcd
                    call    PrintCtrlLcd
                    for y = 0 to 83
                    call    PrintDataLcd
                    next y
    I use now :
    GotoXY:
    LcdReg = %01000000 | Posy : call    PrintCtrlLcd    'Y
    LcdReg = %10000000 | Posx : call    PrintCtrlLcd    'X
    BorderLine:                         '
    '=================================== up
    posx=0
    posy=0
    gosub GotoXY
                     for y = 0 to 83
                     read y, LcdReg
                     call    PrintDataLcd
                     next y
    '===================================  raw all
    for i= 1 to 4
    posx=0
    posy=i
    gosub GotoXY
                   lcdReg= $FF
                   call    PrintDataLcd
    next i
    for i = 1 to 4
    posx=83
    posy=i
    gosub GotoXY
                   lcdReg= $FF
                   call    PrintDataLcd
    next i
    posx=0
    posy=5
    gosub GotoXY
                    for y = 0 to 83
        LOokup y,  [$FF,$80,$81,$81,$BF,$BF,$BF,$81,$81,$80,$BF,$BF,_
    $BF,$A9,$A9,$A9,$80,$BF,$BF,$BF,$89,$89,$99,$A6,$80,$BF,$BF,$BF,_
    $82,$84,$82,$BF,$BF,$BF,$80,$9E,$BF,$BF,$A1,$BF,$BF,$9E,$80,$80,_
    $80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,_
    $80,$80,$80,$80,$80,$9C,$A2,$A2,$A2,$9C,$80,$9E,$A0,$A0,$A0,$9E,_
    $80,$82,$82,$BE,$82,$82,$80,$FF] ,LcdReg
                    call    PrintDataLcd
                    next y
    I attach the code from termometer with two differents fonts : small and big. Enjoy !
    Dec 2008
    Ploiesti, ROMANIA
    The hex file for #16 schematic (bas in #17), for "unumic" user. Just remove the ".txt" extension. Enjoy !
    Aug 2003
    Got any RAM left?
    Tc=2
    Nc=6
    PosX=11
    PosY=3
    Tc=3
    Nc=6
    PosX=11
    PosY=4
    bla var byte : blabla var byte
    bla = 2 : blabla = 3
    gosub loop
    bla = bla + 1
    blabla = blabla + 1
    gosub loop
    loop:
    Tc=bla
    Nc=6
    PosX=11
    PosY=blabla
    plenty of potential for stuff like that,
    & you did this exact same thing twice:
    LcdStr(3) = "."
    LcdStr(1) = 32
    but looks like you fit it in anyways
