Need more space, please...
Results 1 to 27 of 27
    Dec 2008
    Ploiesti, ROMANIA
    Default Need more space, please...
    I wrote the code for thermometer with two sensors DS18B20 and Nokia 3310 display. Works fine, but...only in 16F648A. I want to use with 16F628A (easier to buy in my location). It' s possible to "minimize" the code ? I think maybe can make something with 'BorderLine:" ...
    Thanks in advance !
    ;              Termo with BIG fonts
    ;                  2 x DS18B20
    ;                Thanks to Gusse !
    ;                    may 2011
    ;                ATTENTION ON SCHEMATIC !!!
    ;                        .oooO
    ;                        (   )   Oooo.
    ;                          \_)    ) /
    ;                                (_/
    @ DEVICE pic16F648A, INTRC_OSC, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_ON, LVP_OFF, CPD_OFF, PROTECT_OFF
    INCLUDE "modedefs.bas"
    Define  NO_CLRWDT 1
    DEFINE  OSC 4
            TRISB = %00011100                    'portB configuration  0=out 1=in
            TRISA = %10100000                    'portA configuration
            PortA = %11100000
            CMCON = 7
            VRCON = 0
            INTCON = 0
    OPTION_REG=%00000111                       'weak pullups on, TMRO prescale = 256
    Lcd_DC      var PortB.0
    Lcd_SDA     var PortA.3
    Lcd_RST     var PortA.4
    Lcd_CLK     var PortA.2
    DQ          var PortB.2
    DQ2        VAR PORTB.3
    buton       var portb.4
    Ts          VAR BIT         ' TYPE Of SPACE, variable / constante
    Tc          VAR byte        ' TYPE Of Charater, normal / big
    Ic          var bit         ' Inverted Char
    i           var Byte
    j           var Word
    k           var Byte
    Tv          var byte        ' Tipo de Variavel que se vai receber
    Nc          var byte        ' Numero de Carateres recebidos no Serin
    PosX        var Byte
    PosY        var Byte
    Letra       var Byte [9]
    LetraA      var byte
    LetraB      var byte
    LcdStr      var Byte [28]
    Lcd_Data    var Byte
    Temperature     Var     Word bank0        : Temperature2    Var     Word bank0
    TempC           Var     Word bank0        : TempC2          Var     Word bank0
    Sign            Var     Word bank0        : Sign2           Var     Word bank0
    Float           Var     Word bank0        : Float2          Var     Word bank0
    V            Var     Word bank0        : V2              Var     Word bank0
    Dummy           Var     Byte bank0        : Dummy2          Var     Byte bank0
                Flag            var  Byte
                SignBit         var  Flag.0
                LcdReg          var  Byte bank0
                x               var  Byte bank0
                y               var  Byte bank0
                Busy            VAR  BIT  bank0
              Cursor        var  Byte bank0
    DS18B20_12bit    CON %01111111       ' 750ms,   0.0625°C
    DS18B20_12bit2   CON %01111111       ' 750ms,   0.0625°C
      Low Lcd_RST
      High Lcd_RST
      Low Lcd_DC
      Lcd_Data= %00100001: Gosub Lcd_SentByte        'LCD EXTENDED COMMANDS
      Lcd_Data= $E4      : Gosub Lcd_SentByte        'SET LCD Vop (CONTRAST)
      Lcd_Data= %00000100: Gosub Lcd_SentByte        'SET TEMP COEFFICENT
      Lcd_Data= %00010000: Gosub Lcd_SentByte        'LCD BIAS MODE 1:48
      Lcd_Data= %00100000: Gosub Lcd_SentByte        'LCD STANDARD COMMANDS
      Lcd_Data= %00001100: Gosub Lcd_SentByte        'LCD IN NORMAL MODE
      Ts = 0                                        'Space constante
      Ic = 0                                        'Blinking OFF
      Gosub Lcd_Clear
    'set contrast
      Low Lcd_DC
      Lcd_Data= %10100100: Gosub Lcd_SentByte          'Set Vop Register
    ' Init Sensor 1
     OWOUT DQ, 1, [$CC, $4E, 0, 0, DS18B20_12bit]
     OWOut DQ, 1, [$CC, $48]                   ' Start temperature conversion
     OWOut DQ, 1, [$CC, $B8]
     OWOut DQ, 1, [$CC, $BE]
     Pause 50
     OWIn DQ, 2, [temperature.byte0, temperature.byte1]
    ' Init Sensor 2
     OWOUT DQ2, 1, [$CC, $4E, 0, 0, DS18B20_12bit2]
     OWOut DQ2, 1, [$CC, $48]                   ' Start temperature conversion
     OWOut DQ2, 1, [$CC, $B8]
     OWOut DQ2, 1, [$CC, $BE]
     Pause 50
     OWIn DQ2, 2, [temperature2.byte0, temperature2.byte1]
     Pause 100
    Call BorderLine
    Part1:
    ' Start temp.conv.Sensor1
     OWOut DQ, 1, [$CC, $44]
    If Temperature.15 then
      Temperature= ~Temperature +1
      Sign  = 1
    Endif
    Dummy = 625 * Temperature
    TempC = DIV32 10
    TempC = (Temperature & $7FF) >> 4
    Float = ((Temperature.Lowbyte & $0F ) * 25 )>>2
    Temperature = TempC*100 + Float
    If Sign=1 then
      V= 10000 - Temperature
      V= 10000 + Temperature
    EndIf
    If V >= 10000 then
      Temperature=V-10000
      sign = " "
      Temperature=10000-V
      sign = "-"
    EndIf
    Part2 :
     OWOut DQ2, 1, [$CC, $44]
    If Temperature2.15 then
      Temperature2= ~Temperature2 +1
      Sign2  = 1
    Endif
    Dummy2 = 625 * Temperature2
    TempC2 = DIV32 10
    TempC2 = (Temperature2 & $7FF) >> 4
    Float2 = ((Temperature2.Lowbyte & $0F ) * 25 )>>2
    Temperature2 = TempC2*100 + Float2
    If Sign2=1 then
      V2= 10000 - Temperature2
      V2= 10000 + Temperature2
    EndIf
    If V2 >= 10000 then
      Temperature2=V2-10000
      sign2 = " "
      Temperature2=10000-V2
      sign2 = "-"
    EndIf
    if buton = 0 then
    gosub buton_on
    gosub buton_off
    buton_on:
    LcdStr(5) = 59                            ' simbol for degree
    LcdStr(4) = 48 + Temperature dig 1
    LcdStr(3) = "."
    LcdStr(2) = 48 + Temperature dig 2
    if Temperature dig 3=0 then
    LcdStr(1) = 32
    LcdStr(1) = 48 + Temperature dig 3
    LcdStr(0) = Sign
    Tc=0
    Nc=6
    PosX=3
    PosY=2
    Gosub Lcd_GotoXY : Gosub Lcd_SentString
    LcdStr(4) = 48 + Temperature2 dig 1
    LcdStr(3) = "."
    LcdStr(2) = 48 + Temperature2 dig 2
    if Temperature2 dig 3=0 then
    LcdStr(1) = 32
    LcdStr(1) = 48 + Temperature2 dig 3
    LcdStr(0) = Sign2
    Tc=2
    Nc=6
    PosX=11
    PosY=3
    Tc=3
    Nc=6
    PosX=11
    PosY=4
    buton_off:
    LcdStr(3) = "."
    LcdStr(1) = 32
    LcdStr(0) = Sign2
    Tc=0
    Nc=6
    PosX=3
    PosY=2
    LcdStr(3) = "."
    LcdStr(1) = 32
    LcdStr(0) = Sign
    Tc=2
    Nc=6
    PosX=11
    PosY=3
    Tc=3
    Nc=6
    PosX=11
    PosY=4
    Lcd_Clear:
    For cursor = 0 to 5
        PosX=0:PosY=Cursor:Gosub Lcd_GotoXY
        High Lcd_DC
        For i= 1 to 84
              Lcd_Data=0:Gosub Lcd_SentByte
        Next i
    Next cursor
    Lcd_GotoXY:
    Low Lcd_DC
    Lcd_Data=%01000000 | PosY :Gosub Lcd_SentByte    'Y
    Lcd_Data=%10000000 | PosX :Gosub Lcd_SentByte    'X
    Lcd_SentByte:
    SHiftOUT Lcd_SDA , Lcd_CLK , MSBFIRST, [ Lcd_Data ]
    Lcd_SentString:
    For k=0 to Nc-1
        Lcd_Data=LcdStr(k)
        Gosub Lcd_SentChar
    next k
    Lcd_SentChar:
    Letra(0)=$00:Letra(1)=$00:Letra(2)=$00:Letra(3)=$00:Letra(4)=$00:Letra(5)=$00
    SELECT CASE lcd_data
    ' CAPITAL LETTERS
    CASE 32
    Tv=1        '
    CASE 42
    Tv=5:Letra(0)=$14: Letra(1)=$08:Letra(2)=$3E:Letra(3)=$08: Letra(4)=$14        '*
    CASE 43
    ;Tv=5:Letra(0)=$10: Letra(1)=$10:Letra(2)=$7C:Letra(3)=$10: Letra(4)=$10        '+
    Tv=5:Letra(0)=$08: Letra(1)=$08:Letra(2)=$3E:Letra(3)=$08: Letra(4)=$08        '+
    CASE 45
    Tv=5:Letra(0)=$08: Letra(1)=$08:Letra(2)=$08:Letra(3)=$08: Letra(4)=$08        '-
    CASE 46
    ;Tv=3:Letra(1)=$C0: Letra(2)=$C0                                               '.
    Tv=1:Letra(1)=$60 : Letra(2)=$60                                              '.
    case 47
    Tv=4:Letra(0)=96 : Letra(1)=48 :Letra(2)=24    :Letra(3)=12 : Letra(4)=06  '/
    CASE 48
    ;Tv=5:Letra(0)=$7E: Letra(1)=$A1:Letra(2)=$91:Letra(3)=$89: Letra(4)=$7E        '0
    Tv=5:Letra(0)=$3E: Letra(1)=$51:Letra(2)=$49:Letra(3)=$45: Letra(4)=$3E        '0
    CASE 49
    ;Tv=4:Letra(1)=$82: Letra(2)=$FF:Letra(3)=$80                                        '1
    Tv=4:Letra(1)=$42: Letra(2)=$7F:Letra(3)=$40                                '1
    CASE 50
    ;Tv=5:Letra(0)=$86: Letra(1)=$C1:Letra(2)=$A1:Letra(3)=$91: Letra(4)=$8E        '2
    Tv=5:Letra(0)=$42: Letra(1)=$61:Letra(2)=$51:Letra(3)=$49: Letra(4)=$46        '2
    CASE 51
    ;Tv=5:Letra(0)=$62: Letra(1)=$81:Letra(2)=$89:Letra(3)=$89: Letra(4)=$76        '3
    Tv=5:Letra(0)=$21: Letra(1)=$41:Letra(2)=$45:Letra(3)=$4B: Letra(4)=$31        '3
    CASE 52
    ;Tv=5:Letra(0)=$38: Letra(1)=$24:Letra(2)=$22:Letra(3)=$FF: Letra(4)=$20        '4
    Tv=5:Letra(0)=$18: Letra(1)=$14:Letra(2)=$12:Letra(3)=$7F: Letra(4)=$10        '4
    CASE 53
    ;Tv=5:Letra(0)=$4F: Letra(1)=$89:Letra(2)=$89:Letra(3)=$89: Letra(4)=$71        '5
    Tv=5:Letra(0)=$27: Letra(1)=$45:Letra(2)=$45:Letra(3)=$45: Letra(4)=$39        '5
    CASE 54
    ;Tv=5:Letra(0)=$7E: Letra(1)=$89:Letra(2)=$89:Letra(3)=$89: Letra(4)=$72              '6
    Tv=5:Letra(0)=$3C: Letra(1)=$4A:Letra(2)=$49:Letra(3)=$49: Letra(4)=$30     '6
    CASE 55
    ;Tv=5:Letra(0)=$01: Letra(1)=$E1:Letra(2)=$11:Letra(3)=$09: Letra(4)=$07        '7
    Tv=5:Letra(0)=$01: Letra(1)=$71:Letra(2)=$09:Letra(3)=$05: Letra(4)=$03        '7
    CASE 56
    ;Tv=5:Letra(0)=$76: Letra(1)=$89:Letra(2)=$89:Letra(3)=$89: Letra(4)=$76        '8
    Tv=5:Letra(0)=$36: Letra(1)=$49:Letra(2)=$49:Letra(3)=$49: Letra(4)=$36        '8
    CASE 57
    ;Tv=5:Letra(0)=$46: Letra(1)=$89:Letra(2)=$89:Letra(3)=$89: Letra(4)=$7E        '9
    Tv=5:Letra(0)=$06: Letra(1)=$49:Letra(2)=$49:Letra(3)=$29: Letra(4)=$1E        '9
    CASE 58
    Tv=3:Letra(1)=$36: Letra(2)=$36                                             ':
    CASE 59
    Tv=5:Letra(0)=$02: Letra(1)=$05: Letra(2)=$32: Letra(3)=$48: Letra(4)=$48   'simbol grade
    end select
    High Lcd_DC
    If Tc = 0 Then              ' Normal Charater
        iF Ts = 0 tHEN
            j = 5               ' CONSTANTE SPACE (6)
        Else
            j = Tv              ' VARIABLE SPACE
            for I=0 to j
                If Ic=0 Then    ' Normal Charater
                ShiftOUT Lcd_SDA , Lcd_CLK , 1 , [ Letra(I)]
                else            ' Inverted Charater
                ShiftOUT Lcd_SDA , Lcd_CLK , 1 , [ (127-Letra(I))+128 ]
            next I
    Endif                   ' Double Charater
    ' Tc = 1   Nothing to change       2 x 1
    If Tc = 2  Then         ' 1ª time of 2x2
       for i = 0 to 5
            LetraA = Letra(i)
            LetraB.0 = LetraA.0
            LetraB.1 = LetraA.0
            LetraB.2 = LetraA.1
            LetraB.3 = LetraA.1
            LetraB.4 = LetraA.2
            LetraB.5 = LetraA.2
            LetraB.6 = LetraA.3
            LetraB.7 = LetraA.3
            Letra(i) = LetraB
        next i
    ENdif
    If TC = 3 then      ' 2ª time of 2x2
        for i = 0 to 5
            LetraA = Letra(i)
            LetraB.0 = LetraA.4
            LetraB.1 = LetraA.4
            LetraB.2 = LetraA.5
            LetraB.3 = LetraA.5
            LetraB.4 = LetraA.6
            LetraB.5 = LetraA.6
            LetraB.6 = LetraA.7
            LetraB.7 = LetraA.7
            Letra(i) = LetraB
        next i
        iF Ts = 0 tHEN
        Else
            for I=0 to j
    ShiftOUT Lcd_SDA , Lcd_CLK , 1 , [ Letra(I), Letra(i) ]
    ShiftOUT Lcd_SDA , Lcd_CLK , 1 , [ (127-Letra(I))+128, (127-Letra(I))+128 ]
            next I
    BorderLine:                         '
    '=================================== RAND 0
                    LcdReg  =  %10000000            ' cursor  X
                   call    PrintCtrlLcd
                    LcdReg  =  %01000000            ' cursor  Y
                   call    PrintCtrlLcd
                     for y = 0 to 83
                      LOokup y, [$FF,$01,$01,$01,$01,_
                                 $01,$01,$01,$01,$01,$01,$01,$01,$01,$FD,$FD,$FD,$85,$85,$FD,$FD,$79,_        'D
                                 $01,$01,$FD,$FD,$FD,$01,$01,$79,$FD,$FD,$85,$A5,$ED,$ED,$69,$01,$01,_        'IG
                                 $FD,$FD,$FD,$01,$05,$05,$05,$FD,$FD,$FD,$05,$05,$05,$01,_                    'IT
                                 $F9,$FD,$FD,$25,$25,$FD,$FD,$F9,$01,$01,$FD,$FD,$FD,$81,$81,$81,$81,_        'AL
                                 $01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$FF] ,LcdReg
                       call    PrintDataLcd
                        next y
    '===================================  RAND 1
                   call    PrintCtrlLcd
                    LcdReg  =  %01000001                ' cursor  Y
                   call    PrintCtrlLcd
                   LOokup 0, [$FF] , LcdReg
                   call    PrintDataLcd
                    LcdReg  =  %10000000 + 83                ' cursor  X
                   call    PrintCtrlLcd
                   call    PrintCtrlLcd
                   call    PrintDataLcd
    '===================================  RAND 2
                   call    PrintCtrlLcd
                    LcdReg  =  %01000010                ' cursor  Y
                   call    PrintCtrlLcd
                   call    PrintDataLcd
                   call    PrintCtrlLcd
                   call    PrintCtrlLcd
                   call    PrintDataLcd
    '===================================  RAND 3
                   call    PrintCtrlLcd
                    LcdReg  =  %01000011                ' cursor  Y
                   call    PrintCtrlLcd
                   call    PrintDataLcd
                   call    PrintCtrlLcd
                   call    PrintCtrlLcd
                   call    PrintDataLcd
    '===================================  RAND 4
                   call    PrintCtrlLcd
                    LcdReg  =  %01000100                ' cursor  Y
                   call    PrintCtrlLcd
                   call    PrintDataLcd
                   call    PrintCtrlLcd
                   call    PrintCtrlLcd
                   call    PrintDataLcd
    '===================================  JOS
                    call    PrintCtrlLcd
                    LcdReg  =  %01000101            ' cursor  Y
                    call    PrintCtrlLcd
                    for y = 0 to 83
        LOokup y, [$FF,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,_
                 $80,$80,$80,$80,$81,$81,$81,$BF,$BF,$BF,$81,$81,$81,$80,$BF,$BF,$BF,$A9,_
                 $A9,$A9,$A1,$80,$BF,$BF,$BF,$89,$89,$99,$A6,$80,$BF,$BF,$BF,$82,_
                 $84,$82,$BF,$BF,$BF,$80,$9E,$BF,$BF,$A1,$A1,$BF,$BF,$9E,$80,_
                 $80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,_
               $80,$80,$80,$80,$FF] ,LcdReg
                    call    PrintDataLcd
                    next y
    PrintCtrlLcd:   LCD_DC = 0
    PrintDataLcd:   for x = 1 to 8
                        LCD_SDA = LcdReg.7
                        LCD_CLK = 1
                        LcdReg = LcdReg << 1
                        LCD_CLK = 0
                    next x
                    LCD_DC = 1
    END           ' of program
    Default Re: Need more space, please...
    Have you considered using two 16F628A?
    Use 1 as master to control sensor, use the other as slave to control the LCD, communicate between the 2 using USART?
    That would split the burden.
    Dec 2008
    Ploiesti, ROMANIA
    Thanks...but... NO WAY ! I try to make it "low cost" ...
    Bombay, India
    You might be able to save a little space if you can SUB the digit conversion routines that are repeated in some places. It may gain you some words of space, but, beyond that, you may need to forego the borderline routine altogether(just a guess) or convert it into a code based border function rather than table driven.
    Quote Originally Posted by fratello View Post
    Hi Fratello,
    You are not the first person to mention this about this chip or that chip. I am just curious about the hardships of getting a part as old as the PIC16F648A in quantity? I can see it being a hardship if you can't get it at the local vendor, and don't want to order abroad for low numbers. But is it really that hard (or expensive) to get them by 25 or more? It sounds like your project is going to be marketed.
    Maybe I am just spoiled by being able to get things from any country, pretty easily.
    Again, just curious. Not doubting you, just wondering "easier to get" means.
    Dec 2008
    Ploiesti, ROMANIA
    I live in one small city from Romania ! Even one resistor must be purchased by e-commerce . at e-vendors the 16F648A have double price from 16F628A. And one great vendor (TME.EU) don't sell to persons, just company , from april, this year...
    So, I try to make the best I can with limited resources. Thanks again for support !
    I think you can save a little space by not including "modedefs.bas"
    You will need to change this line.
    To:
    SHiftOUT Lcd_SDA , Lcd_CLK , 1, [ Lcd_Data ]
    Dec 2008
    Ploiesti, ROMANIA
    Still " address limit of 7ffh exceeded" ...
    Fratello,
    check your pm please
    Best Regards,
    Bogdan Pitic
    . . . And one great vendor (TME.EU) don't sell to persons, just company. . . !
    Hmmmm . . . Fratello International, Fratello Engineering , Fratello Imports , Fratello Enterprises, Hot Ziggidy those roses smell great . . . oops . . . Fratello Technologies.EU
    Dec 2008
    Ploiesti, ROMANIA
    Sorry for off-topic...My salary it's about 350 euro/month ; so, it's important if one IC cost 1 or 2 euro - it's just hobby !
    And "Fratello Enterprise(s)" it's verry cool ... I love Star Trek !!!
    Business' often request and receive FREE samples. You are a small prototype company are you not ? You do develop products for others ? No employees required. No lies told. No money made ? That's a trade secret.
