Thanks Walter!
And please do join the fun!
Perhaps we should emphasise, in case that isn't 100% clear, that it's not needed to have an AMICUS18 board and Ethernet shield, it just happens to be my personal development setup. As long as you have a W5100 connected to a PIC via SPI you're all set - like a WIZ811MJ and your favourite PIC on a piece of perfboard.
You can even re-write the Read_W5100 and Write_W5100 subroutines if you want to use shiftout/shiftin instead (it'll be kind of slow though....) or if you want to go to the more traditional adress/data interface (requires a boatload of I/O). That's all you'd need to change, all the other routines go "thru" those two so should work just the same.
What I'm not happy with so far is that all posted code has been hardcoded for socket 0. I have changed it, as discussed in an earlier post, but decided to keep these initial examples hardcoded to keep it easier. Also, I'm NOT happy with the way ArrayWrite literally EATS the codespace, we'd have to come up with a SD card routine or perhaps one of the strings in codespace routines mixed with a couple of ArrayWrite for the dynamic data.
Oh well, one step at a time...
PS. DHCP is now working nicely, with proper handling of leasetime and renewal of lease. Very cool but it adds about 3kB and 42 bytes of RAM to the total footprint when included, I'll try to get that down a bit further.
