A/D interrupt
Results 1 to 5 of 5
Thread: A/D interrupt
    Feb 2010
    Default Re: A/D interrupt
    Thanks for the replay.
    HenrikOlsson,
    That's what i was think excatelly, but it didn't hurt to ask.
    HankMcSpank,
    When a key is pressed AN0 go from 0-5v depend on the key pressed(ie; if 0 is pressed 0<AN0<.5V, if 1 is pressed .6<AN0<1.0V......).
    Thank you,
    Any other ideas or suggestions are appreciated.
    Mar 2009
    Quote Originally Posted by starwick View Post
    HenrikOlsson,
    HankMcSpank,
    Oh, now I see.
    Then what Henrik said....set a comparator to 'trip' (toggle) at anything higher than 0.4V... use that 'toggling' level to generate a comparator interrupt......do your ADC inside the comparator interrupt routine.
    Which PIC are you using? You can likely use the PIC's own internal comparator & DT's CMP_int interrupt....
    (http://darreltaylor.com/DT_INTS-14/intro.html )
