You really should visit the forum for the compiler you are using. I know it's confusing but there are several different BASIC-compilers for PICs and they are all slightly different from each other in syntax etc so you'll get much better help on a forum where everybody else is using the same compiler as you are - which isn't the case here. There's a link to the PROTON forum in second post in the thread.
With that said the line......looks a bit odd to me. I'd try FOR SONY_LP = 0 to 11 instead. But then again your syntax may be perfectly valid for the PROTON compiler you're using, I don't know since I'm not using it.Code:for SONY_LP=0 TO SONY_LP=11
