problem with ir code.using pulsin
Results 1 to 9 of 9
    Aug 2010
    Maryland, USA
    Default Re: problem with ir code.using pulsin
    I am sorry, I am not familar with PICBASIC Plus or with:
    Set_Defaults PROTON_4
    -Bert
    Mar 2011
    archangel sir i checked.there is no problem with the declarations.in this compiler one can declare the variables both ways.may be something wrong with the logic....
    IF P_VAL>=600 THEN PACKET.11=1 ENDIF
    maybe something wrong in this line.maybe my calculations are abit off???
    You really should visit the forum for the compiler you are using. I know it's confusing but there are several different BASIC-compilers for PICs and they are all slightly different from each other in syntax etc so you'll get much better help on a forum where everybody else is using the same compiler as you are - which isn't the case here. There's a link to the PROTON forum in second post in the thread.
    With that said the line...
    for SONY_LP=0 TO SONY_LP=11
    ...looks a bit odd to me. I'd try FOR SONY_LP = 0 to 11 instead. But then again your syntax may be perfectly valid for the PROTON compiler you're using, I don't know since I'm not using it.
    Quote Originally Posted by engineer7 View Post
    I never really thought there was, I am pretty sure you are using Proton, THIS IS NOT THE PROTON FORUM. I did not want to just blow you off if you are using M E Labs P Basic.
    Mar 2011
    Smile Re: problem with ir code.using pulsin
    ok thanks everyone.4 pointing me in the right direction!
