U2270B/Manchester code
Results 1 to 14 of 14
    zx81's Avatar
    zx81 Guest
    Default U2270B/Manchester code
    I'm trying to use a U2270B to read a trasponder. This chip uses Manchester code, I don't have doubts about the decoding process, but, how can I read the pulses? I don't know how to read the signal, pulse duration, etc.
    Anybody has experience with that chip? I'm using a 16F628A, but the pcb is designed for a 12C672P.
    Salutatous's Avatar
    Salutatous Guest
    Talking I do that like this
    in VAR BIT
    InTrs VAR PORTB.1 'On Out of U2270b
    Read:
    PauseUS 130 'for Osc 8
    in=Intrs
    If in=1 Then
    if in=0 Then
    etc..
    zx81's Avatar
    zx81 Guest
    Thanks!!
    So I suppose that a complete pulse of the code (Manchester) uses 260 microseconds.
    Is this correct?
    In your sample you use PAUSEUS 130 for OSC 8, but if I use the internal resonator and don't use the OSC statement on my code (or if I use a 4Mhz external resonator), I suppose that the 130 value would still correct, isn't it? I don't know if you are adjusted the value for a 8Mhz resonator instead that picbasic adjust it via OSC statement.
    Salutatous's Avatar
    Salutatous Guest
    Cool Hello!
    in manchester code:
    T=560µs and T/2=280µs
    and i read 64 bits
    my beta prog read ok the transponder but it need to be optimized!
    i can send it if you need but comments are in french
    zx81's Avatar
    zx81 Guest
    Of course, your code will help me, if you can send me to [email protected] it would be great.
    If you want I can test the code on my board and colaborate with you in the optimization of the read process.
    ct82's Avatar
    ct82 Guest
    Default I need it also!!
    Can you send the code to me as well? I need it for my project. Thanks!!
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 18:23
