My 12lf1822 ADC won't read zero (lowest reading is 008)
Results 1 to 12 of 12
Threaded View
  1. #3
    Mar 2009
    Default Re: My 12lf1822 ADC won't read zero (lowest reading is 008)
    There is (PIN 6 12LF1822) , but I've turned the compartators off...
    @ __CONFIG _CONFIG1, _FCMEN_OFF & _FOSC_INTOSC & _WDTE_OFF & _MCLRE_OFF & _CP_ON & _IESO_OFF & _BOREN_OFF & _PWRTE_OFF
    @ __CONFIG _CONFIG2, _LVP_OFF
    DEFINE  OSC 8
    INCLUDE "DT_INTS-14.bas"     '
    DEFINE HSER_SPBRG 16  ' 115200 Baud @ 8MHz, 2.12%
    SPBRGH = 0
    APFCON.2 = 1          ' PUT HSEROUT ON PIN 3 (ra4)
    APFCON.0 = 0          ' PUT CCP1 onto RA2 Pin5
    Osccon = %01110010     'sets the internal oscillator to 8Mhz
    DEFINE ADC_BITS  8     ' ADCIN resolution  (Bits)
    DEFINE ADC_CLOCK 1     ' ADC clock source  (Fosc/8)
    CM1CON0 = 0   ' COMPARATORS OFF
    CM1CON1 = 0   ' COMPARATORS OFF
    ADCON0 = %00000010     'AN0 Enabled (Pin 5) + ADC On
    ADCON1 = %00000000     'set ADC +ve ref to internal VREF (00 is VCC)
    'FVRCON = %11000001     ' turn fixed internal voltage reference on & set it to 4.096V (last two bits set the voltage ...01 =1.024V,10=2.048
    OPTION_REG = 0   'WEAK PULLUPS ENABLED
    WPUA.3 = 1    ' RA3 pin 4 enabled (SW1)
    IOCAN.3 = 1    'interrupt on -ve going edge (SW1
    cpscon0 = 0             'turn off capacititve touch
    'HPWM SETTINGS (MANUAL SETTING OF THE REGISTERS VS THE PICBASIC HPWM COMMAND)
    CCP1CON    = %00001100   ' Turn HPWM on on CCP1
    TRISA.2 =1               ' Disable the CCP2 pin output driver by setting the bit
    CCPR1L.6 = 0             'I'm only using 8 bit PWM so clear the top two bits
    CCPR1L.7 = 0             'I'm only using 8 bit PWM so clear the top two bits
    PR2= 63                  'THIS SETS THE PWM PERIOD (FREQUENCY) to 15.625KHZ @4MHZ (I hope - not scoped it!)
    T2CON = %00000100        'TIMER2 ON 1:1 PRESCALER 1:1 POSTSCALER
    TRISA.2 = 0              'Enable the CCP2 pin output driver by setting the bit
    OPAMP VAR PortA.5
    SW1 VAR PortA.3
    latest_sample var byte
    TEST1:
    adcin 1, latest_sample
    hserout [dec latest_sample,13,10]
    PAUSE 200
    GOTO TEST1
    ADC +Vref is set to be VCC.
    (Not sure what's going with the formatting - when I copied/pasted there were heaps of line breaks in my code - to make it easier on the eye!)
