calling subroutine triggers interrupt
Results 1 to 8 of 8
    Default Re: calling subroutine triggers interrupt
    Without INTCON.7 set before ON INTERRUPT, it's going to jump to your interrupt vector all the time in any code section where interrupt code is inserted. If you just set INTCON.7 it should never jump there until the hardware interrupt clears INTCON.7 automatically.
    INTCON = %10000 doesn't set INTCON.7 - so the ON INTERRUPT code inserted always assumes an interrupt condition exists.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Dec 2009
    Canada
    Smile Re: calling subroutine triggers interrupt
    Darrel, Bruce,
    Thank you!
    I tried to move "On interrupt goto" to the very top and also check flag in the interrupt handler, either one works just fine.
    Will play with INTCON.7 tomorrow morning.
    Thanks again, the problem seems to be solved
    Alexey
