calling subroutine triggers interrupt
Results 1 to 8 of 8
    Dec 2009
    Canada
    Unhappy calling subroutine triggers interrupt
    Hello All,
    Please advise if this is a known issue: I programmed PIC16F688 for interrupt on A2/INT on dropping edge which works fine, but I got a problem - every time I call any subroutine, it triggers the interrupt, even if the subroutine is empty like this:
    SBRTN:
    every call to any subroutine (gosub ...) results execution of my interrupt handler subroutine.
    Is this something known and caused by a common mistake?
    Thank you,
    Alexey
    Default Re: calling subroutine triggers interrupt
    don't post any code just in case we could find the mistake in
    Dec 2009
    Canada
    Hi Steve,
    I thought this may be a known thing - did not want to bother gurus with long garbage code some pieces of which do not make sense until the rest is written. The line GOSUB VOLTMTR IS A PROBLEM - causes interrupt and execution of code of interrupt handler BTN_CHECK before code of VOLTMTR is executed
         @ DEVICE pic16F688, WDT_OFF, INTOSCIO, PWRT_ON, MCLR_ON, BOD_OFF
         @ DEVICE CPD_OFF, PROTECT_OFF 'DATA AND CODE MEMORY PROTECTION
         INTCON = 0
         DISABLE
         define OSC 4
         clear
    ;---------INPUTS AND OUTPUTS-------------
          'PORTA.0 ICSPDAT,           CONF AS OUTPUT
          'PORTA.1 ICSPCLK,           CONF AS OUTPUT
          'PORTA.2 ON/OFF BUTTON            INPUT, WEAK PULL UP
          'PORTA.3 VPP, CONF AS MCLR,        CONF AS MCLR, WEAK PULL-UP
          'PORTA.4 AN2 VOLTAGE METER      INPUT, NO WEAK PULL UP
          'PORTA.5 EXT ACTIVATION         INPUT, WEAK PULL UP
          'PORTC.0  DIAG OUT                  OUTPUT
          'PORTC.1  DIAGNOSTIC INPUT     INPUT
          'PORTC.2  YELLOW WIRE            OUTPUT
          'PORTC.3  NOT USED                 OUTPUT, ZERO
          'PORTC.4  RED LED                    OUTPUT
          'PORTC.5  GREEN LED                OUTPUT
         ;---------VARIABLES----------------------
              BTN VAR PORTA.2
              YW VAR PORTC.2
              REDLED VAR PORTC.4
              GREENLED VAR PORTC.5
            FCODE       VAR BYTE
            COUNTER     VAR byte
            COUNTER2     VAR BYTE
            COUNTER3    VAR BYTE
            N         VAR BYTE
                CALC     VAR BYTE
                NF         VAR BYTE
                F        VAR BYTE[5]    'AF,F1,F2,F3,F4,F5
                POWER     VAR BIT
                 VOLT      VAR BYTE       'VOLTAGE IN 0.1294 V UNITS
                  LVCOUNT   VAR BYTE       'COUNTER FOR LOW TIME
                  VTR       VAR BYTE       'VOLTAGE TRESHOLD
    '--------------------DEFINITIONS-----------
    'FOR SERIAL INPUT:
                 dEFINE DEBUGIN_REG PORTC 'GPIO  ' Debugin pin port
            DEFINE DEBUGIN_BIT 1     ' Debugin pin bit
                 DEFINE DEBUGIN_MODE 0    ' Debugin mode: 0 = True, 1 = Inverted
            DEFINE DEBUG_BAUD 1200   ' Debug baud rate
    '-----------PORTS CONFIGURATION------------
         CMCON0 = 7          'TURN COMPARATORS OFF
         VRCON = 0           'VOLTAGE REFERENCE OFF TO SAVE POWER OPTION_REG.7 = 0
         OPTION_REG = 0
         ANSEL = %1000       'PORTA4/AN3 IS ANALOG
         WPUA = %100100      'PULL UPS ON A.2 AND A.5  (BUTTON AND EXT SWITCH)
         PORTA = 0           'OUTPUTS ON PORTA LOW (ALL UNUSED)
         TRISA = %111100     'SET PORT A FOR OUTPUTS ON PINS 0,1 (UNUSED) ALL OTHER INPUTS
         PORTC=0             'yellow wire low, LEDs OFF, DIAG WIRE UP
         TRISC = %000010     'SET PORT C FOR INPUT ON PIN 1 (DIAG IN) ALL OTHER OUTPUTS
    '-----DETECTING IF THE SYSTEM IS 12 OR 24 VOLTS----
         ADCON0=%00001101       'LEFT JUSTIFIED(0),VDD ref(0),not used,AN3 USED(011),NO START NOW,STAY ON
         ADCON1=%00010000       'CONVERSION CLOCK SELECT FOSC/32
         ANSEL=%1000              'USE AN3
         GOSUB VOLTMTR        'THIS CALL TRIGGERS INTERRUPT EVEN WHEN SUBROUTINE VOLTMTR IS EMPTY
         'ADCIN 3,VOLT           'this option works OK
         IF VOLT < 124 THEN  'IF VOLTAGE < 16 V
             GREENLED = 1
             VTR = 97
                      VTR = 210
             REDLED = 1
         PAUSE 1000     'TO DEBUG
         PORTC = 0      'TO DEBUG
         PAUSE 1000
         FCODE = VOLT
         ENABLE
    '---------INTERRUPTS CONFIG-----------
         OPTION_REG.6 = 0    'INTERRUPTS ON FAILING EDGE (BUTTON PRESSED)
         INTCON = %10000    'ENABLES RA2 (1,) OTHER INTERRUPTS ON PORTA ARE OFF (BIT 3)
         IOCA = %100         'ENABLES INTERRUPT ON PORTA.2
        ON INTERRUPT GOTO BTN_CHECK     '  CHECK ON/OFF BUTTON
    START:      if yw = 0 then NAP 7  'THIS REDUCES CURRENT FROM 6 TO 4 mA
            GOSUB PAUSE_60
               IF YW = 1 THEN GOSUB VOLTAGE
    GOTO START     'WAIT HERE TILL INTERRUPTED
    ''''--------------SUBROUTINES--------------------------
    '----------READ VOLTAGE---------------
    VOLTAGE:
         GOSUB VOLTMTR
         IF VOLT < VTR THEN
              LVCOUNT = LVCOUNT +1
              REDLED = 1          'TURN RED ON SO THE LIGHT BECOMES YELLOW
              IF LVCOUNT > 0 THEN LVCOUNT = LVCOUNT - 1
              IF LVCOUNT = 0 THEN REDLED = 0
         IF LVCOUNT = 5 THEN
              PORTC=0
              lvcount = 0
    '-----------PAUSE 60 sec--------------
         N2 VAR BYTE
    PAUSE_60:
         FOR N2 = 1 TO 60
              PAUSE 100'0
         NEXT N2
    TEST:
         N = PORTA        'READ PORT A TO CLEAR MISMUTCH, NOTHING ELSE
        ' INTCON.0=0       'CLEAR INTERRUPT FLAG AFTER READING PORT  (RAIF FLAG) not needed
         INTCON.1 = 0     'CLEAR INTF FLAG FOR PORT RA2
    '---------VOLTMETER ROUTINE----------
    VOLTMTR:
         PAUSE 1
         ADCON0 = %1111       'LEFT JUSTIFIED,VDD ref,not used,not used,AN3 USED(011),STARTS IMMEDIATELY,STAY ON
    ADCONV:
         pauseus 50              'allow time for ADC calculation
         IF ADCON0.1 = 1 THEN GOTO ADCONV
         volt = ADRESH
    SHOW_RESULT:
           IF FCODE =0 THEN
            GREENLED = 1 'IF AF=0 -> GREEN LED ON REDLED OFF
            REDLED = 0
            PAUSE 10000 'STAY ON 10 SEC
            GREENLED = 0    'GPIO = 0    'TURN LED OFF
            CALC = FCODE/10   'CALCULATE BLINKS
            GOSUB BLINKING    'BLINK 10S
               GREENLED = 1
            PAUSE 50
            GREENLED = 0
            PAUSE 1500
            CALC=FCODE//10
            GOSUB BLINKING  'BLINK 1S
    BLINKING:
        for COUNTER3 = 1 TO CALC
              REDLED = 1
              PAUSE 1000
              REDLED = 0
              PAUSE 350
            NEXT COUNTER3
            PAUSE 1500      'DIVIDER BETWEEN 10s, 1s AND CONTINUING
         DISABLE 'INTERRUPT
    BTN_CHECK:
         IF YW = 0 THEN
              GREENLED = 1
              yw = 1
              PORTC=0
         PAUSE  1000     'ANTI VIBRATION
     RESUME
         ENABLE 'INTERRUPT
    Thanks again,
    Alexey
    weird, may need to sleep on that one, what if you clear the INT flag before that gosub?
    INTCON.1 = 0
    Dec 2009
    Canada
    Hi Mister_E,
    Unfortunately this does not help. I removed all irrelevant code from the program to make it more clear, sorry for not doing this before. The code I have now for test is below. When it starts, calling empty Test subroutine always triggers interrupt so the GREENLED is ON. If I disable the GOSUB TEST, then it starts with GREENLED OFF (interrupt handler did not run)
    This is the first time I play with interrupt - most likely do something wrong. The MCU is PIC16F688
    define OSC 4
    clear
    BTN VAR PORTA.2
    YW VAR PORTC.2
    REDLED VAR PORTC.4
    N VAR BYTE
    OPTION_REG = 0
    'THE FOLLOWING DID NOT HELP
    N=PORTA 'JUST TO READ PORTA
    INTCON.1=0 'CLEAR INTF FLAG FOR PORT RA2
    PORTC=0 'GREENLED SHOULD STAY OFF
    GOSUB TEST 'THIS SUBROUTINE ALWAYS CAUSES INTERRUPT!!!
    'NOW GREENLED ON PORT C5 IS ON !!!
    INTCON.1=0
    START:
    TEST: 'NO CODE IN THIS SUBROUTINE
    DISABLE
    BTN_CHECK:
    IF GREENLED = 0 THEN
    GREENLED = 1
    PORTC=0
    '' PAUSE 1000 'ANTI VIBRATION
    RESUME
    ENABLE
    I think Steve meant to clear the flag before the GOSUB TEST, not before the ON INTERRUPT GOTO.
    It GOSUB's from an area that is DISABLEd to one that is ENABLED.
    If the flag is set, it will jump to the ISR.
    It may jump, even if it's not set.
    The ISR should verify that the flag is set before doing anything.
