INTERRUPT on RB5
Results 1 to 10 of 10
    Samuel's Avatar
    Samuel Guest
    Quote Originally Posted by Bruce
    Assuming you have your PORTE A/D turned off, it should work fine.
    How do i do that and how does it make a difference? Is it the ADCON register you are talking about?
    depending the PIC you're using it can be ADCON, ADCON0, ADCON1 refer to the datasheet.
    How can it make difference... roughly, you're checking a digital signal, if your analog converter are not turned off, you can have some odd/erratic results. a close to be low level signal can be considered as a high level and so on for the close to be high or high level. digital is digital, analog is analog. It's a common problem like some others, let's say RA4 to drive a source on many PIC
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  2. Can't ID interrupt source with this IntHandler??
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
  4. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 03:59
