Measurement time of a peace of code
Results 1 to 12 of 12
    Aug 2008
    Portugal
    Default Measurement time of a peace of code
    Hi Everyone;
    How do you guys measyre the time that takes to execute a piece of code.
    I have a piece of code, of a PI outine, and i want to measure how much time it takes to complete so a can achive a good sample rate, howaver i don't know how much time it takes to complete. Can somebody help here;
    Here is the code
    PI:
    GetADC:
    K var byte: K = 0
    for K = 1 to 20
    ADCIN 0,actual_speed
    sample = actual_speed + sample
    next K
    actual_speed = sample/20
    sample=0
    calculate_error:
    error = setPOINT - actual_speed
    calculate_proportional:
    P = Kp * error
    calculate_integral:
    error_sum = error_sum + error
    sign = error_sum
    GOSUB SetSign
    IF ABS error_sum > (250*Ki) THEN error_sum = sign * (250*Ki)
    I = ABS error_sum / Ki
    I = sign * I
    calculate_drive:
    power = P + I
    sign = power
    GOSUB SetSign
    IF sign = 1 THEN
    IF power > 255 THEN power = 255
    power = 0
    HPWM 1,power,30000
    SetSign:
    IF sign.Bit15 = 0 THEN
    sign = 1
    sign = -1
    Thanks and Regards;
    Gadelhas
    Default Re: Measurement time of a peace of code
    I just use a timer.
    Time VAR WORD
    TMR1L = 0
    TMR1H = 0
    T1CON.0 = 1  'Start TMR1
    'code here
    'code here
    T1CON.0 = 0  'Stop TMR1
    Time.HighByte = TMR1H
    Time.LowByte = TMR1L
    HSEROUT ["Execution time in cycles: ", DEC Time,13]
    Something like that though I'm sure I've missed a bracket somewhere.... :-)
    MPLAB stopwatch also do the trick pretty well
    If you have a Scope, set a pin high before the section of code you want measure, and clear it at thye end. not as accurate as Timer or StopWatch but easy easy easy
    Aug 2008
    Portugal
    Ehehe, this time i don't think so!!! Can you tell me hoe do i do the math so i can have a value in seconds or miliseconds.
    I'm using a 8Mhz osc, so with Fosc/a i get 2Mhz, so 0.5uS for cycle. I must multiply this value for the value that i've got in the time var?
    Thank you Henrik
    I'm using MCS, i'm not used to use MPLAB, i think that way with the scope its better. Thank you Steve
    Thanks and Regards;
    Gadelhas
    Aug 2008
    Portugal
    Update;
    I made this code
        if Bmais = 0 then
            pause 50
            Time VAR WORD
            TMR1L = 0
            TMR1H = 0
            'Inserir rotina a medir
                GOSUB PI
        lcdout $FE, 1, " Medidor ciclos "
        lcdout $FE,$C0,"N. Ciclos: ", #time
        Pause 100
    GOTO Main
    When i press Bmais, i get always 7203 cycles, so multiply by 0.5uS, i get 0.003602 S, or 3.6mS. Is this calculations correct?
    Thanks and Regards;
    Gadelhas
    maybe... replace the gosub by a pause 10, and see what happen
    Aug 2008
    Portugal
    I get always 20009 cycles, so multiply by 0.5uS, i get 0.010005S, or 10mS. So i assume that is correct, and works great.
    Thank you Henrik and Steve!
    Thanks and Regards;
    Gadelhas
    Yes exactly, in this case it's just a matter of multiplying the value you get with 0.5 to get the answer in uS.
    If you want to do that in PBP then perhaps:
    ' In us
    LCDOUT $FE, 1, ["Timer ticks: ", DEC Time]
    LCDOUT $FE, $C0, ["Execution time: ", DEC Time/2, "." DEC Time//2, "us",13]
    I think that should do it.
    DT has a nice example here: http://www.picbasic.co.uk/forum/show...=1272#post1272
    Something else to consider is where the code you're timing is located. See the 1st paragraph.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Aug 2008
    Portugal
    I got it. Thank you all, once again!
    Thanks and Regards;
    Gadelhas
    SteveB had a nice include file called codetimer.bas from here: http://www.picbasic.co.uk/forum/show...7197#post27197 for PIC18 devices.
    Aug 2008
    Portugal
    WoW, thast awesome, very good indeed!
    Thanks and Regards;
    Gadelhas
