Warning & Error Messages
Results 1 to 17 of 17
    Apr 2003
    Cambridge - UK
    Default Re: Warning & Error Messages
    Users that wish to contribute can request contributor status by emailing or PM'ing me or a moderator.
    We can elevate the user status to contributor and the user can create articles.
    HOWEVER we will moderate and check articles before they go live to prevent abuse and spam
    Sep 2010
    Here's one that took me a while to figure out:
    Warning is:
    "Warning Line 23: Command line overrides statement. (18F4550.BAS)"
    Solution was:
    Change the compiler from PBPW to PBPL by: View->Compile and Program Options-> Compiler->Select Check Box by "Use PBPL".
    Quote Originally Posted by cc1984 View Post
    Warning is:
    Solution was:
    What was the code number?
    Sep 2010
    No code number is returned. I get exactly what I typed in. What category do these "non-assigned" error codes fall into? It is definitely a fatal error, since it will not compile.
    Interesting.
    When I forget to use PBPL I get:
    "....ERROR line 20: Bad data type."
    That is with MCS. What are you using as a code editor/IDE?
    Dave,
    Does MPLAB give the same error messages than MCSP? Are there alternative IDEs?
    I would think that error code numbers are IDE specific. Unless they all got together and came up with a standardized list, but that would surprise me greatly. It might be a good idea to separate the wiki by IDE product.
    (I don't use MPLAB so can't comment on that)
    Pic Basic Pro has codes of its own as MPASM does. The errors are saved to error files in your project directory. The IDE reads thos files.
    As far as I know anyways.
    Sep 2010
    Interesting.
    I am using MicroCode Studio. What shipped on the PBP installation disk.
