Only moderators and contributors can make changes. We are working on content for this new section.
In the meantime if you have content to add post it here and it will be added. We like user input!!!
Users that wish to contribute can request contributor status by emailing or PM'ing me or a moderator.
We can elevate the user status to contributor and the user can create articles.
HOWEVER we will moderate and check articles before they go live to prevent abuse and spam
Here's one that took me a while to figure out:
Warning is:
"Warning Line 23: Command line overrides statement. (18F4550.BAS)"
Solution was:
Change the compiler from PBPW to PBPL by: View->Compile and Program Options-> Compiler->Select Check Box by "Use PBPL".
Dave,
Does MPLAB give the same error messages than MCSP? Are there alternative IDEs?
I would think that error code numbers are IDE specific. Unless they all got together and came up with a standardized list, but that would surprise me greatly. It might be a good idea to separate the wiki by IDE product.
(I don't use MPLAB so can't comment on that)
