Mtouch switch using PIC 12F510
Results 1 to 16 of 16
    May 2011
    Arrow Re: Mtouch switch using PIC 12F510
    Hey is this code true for the 220V light bulb ? I don't mention the syntax just the algorithm.(I familiar with C language )
    While (1) do  'this creates an infinity loop'
    repeat
            Generator = 1            ' enable sensor power
            Sensor = GPIO           ' read sensor
            Generator = 0            ' disable sensor power
            Sensor = Sensor & 7   ' keep only Sensor bits
    until Sensor != 7                    '
    ' If the light bulb is lighting we will turn off it when we touch
    ' else we will turn on.
        if (LED == 1)
        LED = 0;
        else if (LED == 0)
        LED = 1;
    May 2011
    Default Re: Mtouch switch using PIC 12F510
    Nobody helps me check the code ?
    If you understand C, I would suggest to look for answers in C forums.
    Here we all do Basic and specifically Melabs Pic Basic.
    May 2011
    No I just ask about the algorithm not about the language. So plz help me check the algorithm whether it's true or not?
    I changed mister's code in order to use that code for turning on or off the 220v light bulb.
    Plz help me answer the misunderstanding and answer whether my code right or wrong ?
    I'd answer to your post here, but ONCE AGAIN SOMEONE DELETE MY POST...
    It really play on my nerves. If at very least MOD could warn the user before deleting a post with a good reason, life would be good... BUT NO... ?%#$??&@%$%@%$
    May 2011
    Plz help me.
    I don't understand the value "7" in the code above what does that mean ?
