Mtouch switch using PIC 12F510
Results 1 to 16 of 16
    Default Re: Mtouch switch using PIC 12F510
    Taken directly out of Mister_es sample code:
        ' Short explanation of the whole thing.
        '       1. Send a high level to all sensor input => GPIO<2:0>
        '       2. Read GPIO port
        '       3. Send a low level to all sensor input
        '       4. Keep only GPIO<2:0> bits
        '       5. Test result
        ' If no sensor has been touched, the result will be 7 => 0000 0111, case
        ' else, the body capacitance will introduce sufficient delay between
        ' step 1 and 2 wich will keep the according bit to 0.
        ' Results will be as follow
        '               NoSensor => 0000 0111 => 7
        '               GPIO.0   => 0000 0110 => 6
        '               GPIO.1   => 0000 0101 => 5
        '               GPIO.2   => 0000 0011 => 3
    Seem like a pretty good description. If you are more specific, I am sure someone here can answer your question.
    May 2011
    What if I just use 1 sensor ? Is this the same ?
    May 2011
    And what is the role of these resistors ?
    1,2,3,4,5,6,100, 100 000 sensor solution is the same.
    Rough explanation, your body act as a capacitor between the sensor and the circuit ground. By the time the Pin is low, if you add an small capacitance on the pin, set the pin high the read then pin, the pin will read low because the capacitor haven't got time to "charge"... period. simple. Really old way to do it.
    You can also do it with a spare CMOS input,Darlington transistor, FET, OpAmp... etc etc etc.
    Plug your home theater sound system, set it to line input, crank the volume to the max, insert a needle in the RCA center pin woohoo you got a signal!!!
    mTouch use ADC reading, probably more accurate and versatile... no real extra parts.... on both solution, you need a fairly good PCB design.
    May 2011
    Hey mister,
    I almost understood what you did however there are some places I still don't really understand:
    data @3,3,0,2,1 ' table to convert 'Sensor' variable result to according
    ' LED blink. See Result list bellow
    => I don't really understand this code? what is the meaning of value: 3,3,0,2,1 ? is this loop variable will get this value ?
    ' 4. Keep only GPIO<2:0> bits => what is the meaning of keep only GPIO<2:0> bits ? Does it mean that we just read the value of GPIO bits?
    repeat
    Generator = 1 ' enable sensor power
    Sensor = GPIO ' read sensor
    Generator = 0 ' disable sensor power => this is send low level right ?
    Sensor = Sensor & 7 ' keep only Sensor bits => don't understand this is this the comparison ? and what value will sensor get?
    until Sensor != 7 ' redo the test untill one sensor is touch
    ' Now we will flash an LED to confirm wich sensor has been touch
    ' GPIO.0 => 1 Blink
    ' GPIO.1 => 2 Blink
    ' GPIO.2 => 3 Blink
    read sensor,loop ' convert result to blink
    repeat
    LED = 1
    PAUSE 200
    lED = 0
    PAUSE 200
    loop = loop - 1
    until loop = 0
    => if in this case I use 220v light bulb and I want it lights until we touch again what should I do ?
    May 2011
    Arrow Re: Mtouch switch using PIC 12F510
    Hey is this code true for the 220V light bulb ? I don't mention the syntax just the algorithm.(I familiar with C language )
    While (1) do  'this creates an infinity loop'
    repeat
    until Sensor != 7                    '
    ' If the light bulb is lighting we will turn off it when we touch
    ' else we will turn on.
        if (LED == 1)
        LED = 0;
        else if (LED == 0)
        LED = 1;
    May 2011
    Nobody helps me check the code ?
