Hi Guys,
I'm a newbie. I am having trouble using the "POT" command with my 12F675. It simply doesn't work on any port (neither does RCTIME). I have had success using ADCIN using a voltage divider which worked fine but not POT or RCTIME? Why?
Next question, I have a variable that I want to scale from say 50% up to 105%. How can I do this in code? When I try to multiply or divide large numbers from the ADCIN (say 1023) the result is usually 1 or 0 and nothing in between. I'm guessing its a bit limitation thing. Please help. Thanks.
P.S... I'm using an external XT as I stuffed up the internal calibration value.
