U2 programmer problem - Saleae Logic Probe measurements, SOLVED
Results 1 to 13 of 13
    Default Re: U2 programmer problem - Saleae Logic Probe measurements
    Disconnect any extra hardware attached to your computer (camera, printer & plah plah plah)
    Clean the USB driver with UsbDeview, reconnect your U2 programmer, wash & rinse again.
    BTW, is the Saelig probe able to handle the 13V (or so) on the MCLR pin?!?
    Get rid of it while programming.
    I only have mouse and keyboard attached.
    Cleaned with Usbdeview, uninstalled programmer, rebooted, reinstalled v4.32 from CD and everything works ok!
    Merci le Bleuet!
    Default Re: U2 programmer problem - Saleae Logic Probe measurements, SOLVED
    [Insert Big Grin here]
