Hey RDavid,
At this point, if I were you, I would drop back to some trouble shooting techniques.
How about using debug to send the adval to a serial port or if you are using the PICkit programmer it has that feature available.
Below is a sample program for the 16F690 so you will have to adapt it for your PIC, but you can see how to set up debug.
' 16F690
'*  Notice  : Copyright (c) 2007 [select VIEW...EDITOR OPTIONS] *
'*  Date    : 12/4/2007                                         *
' 10-bit A/D conversion
' Connect analog input to channel-2 (RA2)
' -----[ I/O Definitions ]-------------------------------------------------
 DEFINE DEBUG_REGG PORTA        'set debug port to porta
 DEFINE DEBUG_BIT 0             'use pin a0 of porta for debug
 DEFINE DEBUG_BAUD 2400         'set baud rate to 2400
 DEFINE DEBUG_MODE 0            'communicate in true mode
' Define ADCIN parameters
' Set number of bits in result
DEFINE  ADC_BITS        10
' Set clock source (3=rc)
DEFINE  ADC_CLOCK       3
' Set sampling time in microseconds
DEFINE  ADC_SAMPLEUS    50
adcVar  VAR WORD ' Create variable to store result
' Set PORTA to all input
'TRISA = %11111111
' Set up AD
ANSEL  = %00000100  'enable AN2, ALL THE REST DIGITAL
ANSELH = %00000000  'AN8-11 DIGITAL
ADCON0 = %10001000   ' RIGHT JUSTIFIED
ADCON1 = %00010000  'fOSC/8
Pause 500               ' Wait .5 second
  ADCIN 2, adcVar ' Read channel 0
  ' do something with adVar here
  debug DEC adcvar,"  ",BIN adcVar,$0D,$0A
  Pause 100              ' Wait.01 second
GoTo main                   ' Do it forever
