Processor Speed Test?
Results 1 to 5 of 5
    Mar 2011
    Los Angeles, California
    Default Processor Speed Test?
    Anyone ever written something to tell you the actual speed the PIC's processor is really running at?
    Default Re: Processor Speed Test?
    No, not really but depending on what type of accuracy you need it may be as simple as blinking a LED.
    TRISB.0 = 0
      PortB.0 = 1
      PauseUs 250
      PortB.0 = 0
      PauseUs 250
    Goto Main
    Now put the scope or frequency counter on PortB.0, you should get a 2kHz signal, if you don't the PIC isn't running at 4MHz.
    May 2007
    Sounds like the OP wants to do something like this:
    cpu_speed = ........     ' compute actual CPU speed
    if cpu_speed = 5 then
      ' do something
      ' do somethingelse
    end if
    Quote Originally Posted by Ramius View Post
    an external integrated oscillator feeding Timer1 in capture mode ???
    using mains rectified to get a precise 100 ( or 120 ! ) Hz signal and measure the supposed 10 or 8.33 ms period ??? - "Pulsin" can be used here.
    one could even think to an auto-adjustment through the OSCTUNE register ... if intosc used.
    if only a rough idea is needed ... some RC external ladder with RC Time function ...
    You might be able to use something like this
    http://www.picbasic.co.uk/forum/showthread.php?t=9350
