Defining COM-2
Results 1 to 5 of 5
Thread: Defining COM-2
    Mar 2011
    Los Angeles, California
    Default Defining COM-2
    There is a demo program that sends serial data out on COM-1. I would love to see what data this program is sending. Is it possible to somehow define COM-2 as a file of sometype to record the data being sent?
    Default Re: Defining COM-2
    You'll need to be more specific in your requirement.
    Do you already heard of some Serial Port Sniffer software? That's what I would use, assuming I understand your requirement. http://www.hhdsoftware.com/serial-monitor
    you could also build your own, just grab the Data, display it on a LCD,...or sending it on a USB port, and create your own software... does it really worth it knowing it cost 60$ ish for a decent really to go version?!? It's up to you to decide.
    Or, if you know that it sends ASCII you can simply wire COM1 to COM2 with a crossed cable and capture it with the terminal emulator of choice. You may find an emulator that can display in HEX or whatever.
    the main advantage of the sniffer is you don't need to bother with the COM settings, it will even display the one in use.
    Mar 2011
    Thanks!
