I have defined a variable Counters VAR BYTE [4] bankA, and I'm using it in ISR.
Instead Counters[0] = Counters[0] +1, I want to use @ INCF _Counters, F because it is faster.
This is for first byte in array
@ INCF _Counters, F
and it works.
For the second byte in array I tried this:
@ INCF _Counters+1, F
But does not work, if I use Counters[1] = Counters[1] +1 then it works.
How to fix that?
