Unstable sine PWM output
Results 1 to 30 of 30
    Default Re: Unstable sine PWM output
    Hi, Pxidr84
    Something caught my attention ... in the reloading, you use DIV32; are you sure there's no possible interrupt while DIV32 works ???
    as timer0 is a low priority interrupt ... I'd check that two or three times.
    ... just an idea after a very quick browse ...
    Timer0 interrupt is used for the calculation of the inverter paramaters (like the V/F ratio, the timer reload variable, etc.) It's a low priority interrupt because the Timer1 interrupt (used for the PWM generation) is very critical and must be
    executed all of the time.
    The DIV32 is used for calculate the timer reload value (the timer routine is from Henrik). However this routine is needed for output the desired sine frequency. This routine directly controls the Timer1 interrupt frequency. It is possible to avoid this DIV32 command (because it seems to take a LOT of ressources)?
    Maybe it's better to use Timer0 as a high priority interrupt?
    Maybe a PWM register is misconfigured?
    I don't know
    No ideas for this problem?
    Aug 2010
    Maryland, USA
    Not sure of a solution yet, but from watching the posted video, I am guessing the problem is some kind of timing issue. I don't think you have things configured wrong as the output looks great most of the time. Rather I think there are some times when a counter gets reset of an interrupt gets interrupted. It glitches then goes right back to perfect wave.
    If you watch it and don't alter the frequency, does the glitch happen at regular intervals, or is it random in nature?
    -Bert
    I think Alain may have a point, I would try to skip the DIV32... let's say assign a fixed value there and let it run idle to see if the problem persist.
    I don't know if DT-Ints have any impact on DIV32, I'd guess no but I don't know. The manual says that it's not recomended to have interrupts enbles if using ON INTERRUPT because the system variables that DIV32 relies on might get changed by the ISR. But DT-Ints saves the system variables so I don't think it should be an issue.
    With that said I don't see the reason for calculating the interrupt frequency "all the time". If I read your code correctly your TMR0 interrupt executes at around 38Hz so it calculates the reload values 38 times per second. As long as the desired frequency isn't changed the reload value for TMR1 doesn't change so why keep calculating it?
    Instead, do it in your Main-loop and even better calculatie it only when the desired frequency have changed.
    Now, I think you think that you AREN'T calculating it "all the time" but look closely at your TMR0 interrupt service routine:
    ' PWM calculation interrupt (Timer 0)
    calcint:
    ' Recalculations
    if flag=%1 THEN             '<----Calculate only when Flag=1
       ' Reload timer calculation
      dum=dum1*dum2
      reload=Div32 freq
      reload=(65535-reload)+8
      ' U/F calculation
      if freq<=500 then
         amp=(freq*131)+35
          AMP=65535
      flag=%0
    ' Frequency reference control by potentiometer
    potsense=((potsense<<6)**maxfreq)+5
    if potsense<>freq then freq=potsense:flag=%1
    ' Frequency limits
    if freq<minfreq then freq=minfreq
    if freq>maxfreq then freq=maxfreq
    @ INT_RETURN
    That flag=%1 is NOT part of the IF-THEN statement so flag will get set every interrupt no matter if the frequency have changed or not and therfor the calculations of the reload values will get executed every interrupt.
    Thanks for your help.
    So I've tried first to set a fixed reload value (64594) without calculations (to obtain 120Hz sine, the max. frequency). The sine wave was perfectly stable on the oscilloscope.
    This :
    dum=dum1*dum2
    reload=DIV32 freq
    was removed and replaced with :
    reload=64594
    I've also applied Henrik tips, like this :
    potsense=(potsense<<6)**maxfreq
    IF potsense<>freq THEN
    freq=potsense
    flag=%1
    And set the reload calculation routine into the main loop.
    Results : it's more stable, but the glitches still appears when I change the frequency of the sine (so the reload calculation routine is executed during this time).
    I'm pretty sure that the problem is caused by DIV32. However this routine is needed :
    dum=dum1*dum2
    reload=DIV32 freq
    How to replace the "DIV32" by an another thing? It is possible to use that : http://melabs.com/resources/fp.htm ? Or anything else?
    It might be the DIV32, we'll have to get Darrel to answer that or have someone dig into the ASM code and figure out if the PBP registers used by DIV32 are being saved by DT-Ints or not (I still think they are).
    My guess is that it isn't actually DIV32 that is causing it but something else with the way the frequency is changed. Why not try constantly ramping the frequency up and down in your main loop? Don't use DIV32, just "sweep" the reload value up and down between your MIN and MAX values. Does it still glitch? If so we know that it's not DIV32 that's causing it but something else.
    If it turns out that it IS DIV32 then we can look at other solutions. The DIV32 thing was in response to your request of directly calculating the reload value based on the desired output frequency scaled in Hz. Simply rescaling to some arbitrary "unit" might allow the calculations to be done without DIV32 but it comes with a couple of commitments which I won't go into until we know that that DIV32 is the problem.
    Can you explain to me where the values 34696 and 32 comes from?
