Incrementing Help
Results 1 to 5 of 5
    Mar 2005
    Mandalay,Myanmar
    Lightbulb
    Hi Srigopal
    As value $01=01=%01,so what you write $01 or 01 is no difference.
    Compiler only know bit ,byte,word(data type). No more Hex or Dec.
    Mcus work only on binary.
    Your output (eg.serout,lcd out)can be binary,ASCII,Decimal and Hex.
    a.majid
    from_myanmar
    Jul 2004
    CA
    Post
    Now I have another question! What about the result. Will that be in hex form or a decimal representation of the hex value.
    for example lets say do the following
    counter = counter + $01 will the result in counter variable now have the HEX representation. or will it have the decimal representation.
    Also lets say I do the following
    PORTB = 128 'which is 1000000 in binary.
    this means that PORTB.7= 1 while the rest of the pins in portB = 0
    if I am not mistaken this is the same thing as saying PORTB = $80.
    So basically it does not matter if you are incrementing in HEX form or Decimal form because the output will eventually be converted back to binary form.
    peterwi's Avatar
    peterwi Guest
    It doesn't matter how you "view" the number (hex, binary, or decimal), the value is still the same. So, adding one is the same, whether you add one "in hex" ($01) or "in binary" (%00000001) or "in decimal" (1). You still just have "a number".
    One thing that might help clarify this for you is to use the Calculator in Windows (if you're using Windows). Using the "Scientific View" (View >> Scientific), type in a number, then change the radio buttons to Hex, or Bin, or Dec. The VALUE hasn't changed, just the way it's represented.
  1. Automatically incrementing version counter/variable
    By skimask in forum PBP Wish List
    Last Post: - 5th December 2008, 06:00
  2. Time delay by incrementing a variable using incoming pulse
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 28th October 2005, 04:50
  3. 32 bit addition
    By ice in forum mel PIC BASIC Pro
    Last Post: - 16th May 2005, 12:23
