Code speed and execution time
Results 1 to 12 of 12
    Apr 2011
    NSW, Australia
    Default Re: Code speed and execution time
    Thanks for the replies, and how to put the code in.
    Amoque,
    Thanks, a slip of the finger, I have now changed that with no change in speed.
    Tenaja
    I dont know the differerence between I2C hardware and I2C read write, can you enlighten me?
    Addressing with STARTS etc outside the loop. A brief example would be great.
    As you can no doubt tell this is all new to me.
    There was a request from cncmachineguy for 'configs'.
    I have a few books on programming PICs and they tell you 'to set it to this' or 'set it to that', but no real explanation of why you do it. Does anyoneone know of a book that has all the real basic info that the other books expect you to already know?
    Any comment on the 9000+ lines of code assembled. does this seem resonable?
    aajgss
    Sep 2007
    USA, CA
    Unfortunately your chosen PIC does not have hardware implementation of i2c Master. If you want to use h/w i2c, you'll have to change PICs.
    For start/stop, etc, you have to read the datasheet of the slave. They usually show graphical timing charts that show when the individual pins must be driven high or low. For a typical eeprom, like the 24LC08b for instance, a START is this...
    eeprom_start:
    high data
    high clock
    low data
    Now those are states, not commands. While you can use the command, it is not recommended for several reasons. First, i2c should have pullups, and you are supposed to turn the pin into an input to let it get pulled high. Second, you have to wait for the pin to get pulled high, and third, my preference is to avoid PBP's High and Low commands because they turn the pin into an output then set it high...and that takes too many instructions. I like to manually set the Tris register myself, and manually set the port pins--but that is personal preference.
    ...and eeprom_stop is this...
    low data
    high clock
    high data
    Ack is the slave acknowledging the data; usually it is pulling the data line low...
    Eeprom_Ack:
    repeat
    until SDA_Pin = 0
    After you get that worked out, you look at the byte write (for instance) timing chart. My eeprom d/s shows this timing...
    Eeprom_Start
    i2cout Control
    Ack
    i2cout Address
    ack
    LoopStart:
    i2cout YourData
    ack
    If NotDoneSendingData goto LoopStart
    Eeprom_Stop
    If sticking with the s/w commands, you'd probably want to make your own i2c command, too. The ones built in to PBP are painfully slow because they are designed to be idiot-proof. You can see the timing charts of the d/s to learn when to pull the clock and data pins low.
    It can be done and is easy for the experienced...but this is not a trivial undertaking for a newbie. TIming charts in datasheets may be initially intimidating, but once you get it it's simple.
    Apr 2011
    NSW, Australia
    tenaja
    Thanks for the great explanation
    As far as the PIC goes, I have the following
    18F14K50
    16C745
    12F675dsPIC 33FJ120P
    16F84
    16F676
    24FJ64GA002
    16F81930F2010
    16HV785
    If any of these pop out as ones you know would be suitable, please let me know, otherwise I will go searching.
    It is not critical that I use the 16F690, its just that it is installed on the LPC demo board.
    My project is (what I thought in the start would be simple - now I know otherwise) to save a sinewave in an EEprom and get a value and send it out to the DAC. Then a switch to change the speed of the loop to give 50 or 60 hertz.
    aajgss
    Sep 2007
    USA, CA
    I don't have your list of PICs memorized, so you'll have to read the datasheets. Just search for "master" in the i2c section and make sure it is not implemented in firmware.
    GIven your 50/60hz output, I'm guessing a dc/ac converter? Most dc/ac converters use a "modified sine wave" that only has two or three steps in each direction. You should be fine with a lookup table...you can probably squeeze in a decent curve in the same space the s/w i2c commands consume, and save the hassle of the eeprom.
    Apr 2011
    NSW, Australia
    OK, Checked all my PIC's and find that the 18F14K50 is listed in the data sheet as having a Master Sync Serial Port.
    I have tried the I2Cread and I2Cwrite with this and never got it to work. Could this be because it is hardware and not software?
    I shall continue and report back at the next hurdle!!
    aajgss
