Can you confirm that the PIC does indeed work at 40MHz? Maybe you are having a hardware problem with the oscillator (I had something similar once using a breadboard).
Can you add a simple test, maybe blink an LED at a fixed interval?
Sayzer,
After checking the program, going through the math, compiling for an 18F @ 40mhz and not finding anything wrong ... I put together a breadboard with an 18F4620 running at 40Mhz with a 10Mhz crystal and 24 LED's.
It works fine.
BAM_INFO says ...
Message[301]: MESSAGE: ('BAM_INFO' - MinPeriod= 173 inst, Cycle= 22774 inst, Pins= 24, FREQ= 219 Hz)
Thank you very much Darrel.
I also went through the hardware, and found nothing wrong.
10Mhz xtall, 15pf caps, HSPLL (DEF. OSC 40) does not work.
20Mhz xtall, 15pf caps, HS_OSC (DEF. OSC 20) works.
Testing it with 40Mhz using a test code (without MIBAM) is ok.
Sayzer was using an 18F452, not an 18F4620, maybe it's a problem with a particular chipset and not the 18F family?
One thought, Sayzer, did you try with another 18F452? That would rule out a defective unit.
And if you want to rule out the breadboard, try it on another one. I've had only one breadboard so far with a defective track in it.
And a really dumb question, did you confirm that power to the circuit was good? Forgetting to readjust the voltage or current on a variable power supply like the one I use could make for freaky results; not saying that I ever did that noob mistake.![]()
