Is it possibly a Windows XP Pro Problem?
Results 1 to 11 of 11
    Mar 2011
    Los Angeles, California
    Default Re: Is it possibly a Windows XP Pro Problem?
    Sorry serious brain craps!
    ' Name : HELLOX3.pbp
    ' Compiler : PICBASIC PRO Compiler 2.6
    ' Assembler : PM or MPASM
    ' Target PIC : PIC16F628A or similar 18-pin type compatible with LAB-X3 board
    ' Hardware : LAB-X3 Experimenter Board
    ' Oscillator : 4MHz external crystal
    ' Keywords : SEROUT
    ' Description : PICBASIC PRO program to send "Hello World" on serial port.
    Include "modedefs.bas" ' Mode definitions for Serout
    Define LOADER_USED 1
    Define osc 20
    mainloop:
    Serout PORTB.3, T2400, ["Hello", 10, 13] ' Display "Hello", next line
    Pause 500 ' Wait .5 second
    Serout PORTB.3, T2400, ["World", 10, 13, 10, 13] ' Display "World", skip a line
    Goto mainloop ' Do it forever
    Your code looks OK with the exception , I think, that it is PORTB.2 that goes to the MAX232.
    If I am wrong on that try the Serial Communicator built into MCS.
    Mar 2011
    Thank you and inquiring minds would like to know why B.2?
    Isn't Port B.2 the TX-in for the Max 232 on a 16F628A or am I looking for a specific type of port?
    Thanks, Ed
    B.2 is the TX and B.1 is the RX from the 628.
    Just a matter of looking at it as out from the PIC and in to the MAX.
    Are you up and running now?
    Mar 2011
    Hi, no sadly I am not able to get it to work. I am using Microcode Studio plus, MPLAB IDE, and a Picstart Plus programmer. Somewhere within these three I have made the wrong choices and being perfectly honest, not knowing what options to chose. I think it will probably take a phone call to/from someone to go through the setups. Thanks though, Ed
    Sorry that I could not help.
    But a call to MeLabs and a talk with Darrell should fix you up.
    Let us know how it goes.
    I don't think the 628a is capable of writing to its own memory. So I don't think it is possible for you to use a bootloader for that chip. So what happens if you take this out of your code?
    Also, you could try out the sample hex file code on MeLabs website (but it is made for the 4 Mhz crystal that comes with the hardware), just to make sure the hardware is working as you thought. http://melabs.com/doclist.htm#X3
    When you define the osc, you must use capitals! DEFINE OSC 20. PBP is proably defaulting to 4 mhz.
    Also, the MeLabs example program for that hardware uses PortB.2, like Dave mentioned. Here is their example:
    loop: Serout PORTB.2,T2400,["Hello",10,13] ' Display "Hello", next line
    Serout PORTB.2,T2400,["World",10,13,10,13] ' Display "World", skip a line
    Goto loop ' Do it forever
    Last edited by ScaleRobotics; - 2nd May 2011 at 14:55. Reason: added hex file idea
    Hi Ed,
    Ok so I gotta ask, is anything working, have you verified the code got in the PIC? Did you preprogram it with the bootloader? Did you get any errors when loading any of the code / bootloader ? What is going on inside my mind right now is I am seeing you define OSC 20, and I am wondering what config fuse got programmed into the chip, HS, XT, or other . . . Will a boot loaded program even run at 20 ? I don't know, as I have NEVER used a bootloader. Those are my thoughts.
    HTH
    JS
