PBPro Maths Help
Results 1 to 9 of 9
    Default Re: PBPro Maths Help
    Hi, Retep ...
    first you have to declare a dummy var ... and a Div flag
    then ...
    IF Local > 32767 then    ' see PBP manual ... for the Why ???
       Local = Local/2
       Div = 1
    Else
       Div = 0
    Dummy = 11
    Dummy = Dummy*7908 ; operation needed by PBP ...
    ActualSpeed = DIV32  Local
    IF Div THEN ActualSpeed = Actualspeed / 2    ' Ooops ! not *2 ...
    ActualSpeed = ActualSpeed + 1
    Thanks for the help so far, here is a different formula though.
    How to convert that to use max resolution and div 32 command etc.
    3600sph / (count * 0.000005 * 4550)
    Count will be a maximum of 10,000
    Does this code look correct to implement the formula?
    'Formula Speed = 3600 / (Local * 0.000005 * 4550)
    Dummy = Local * 5
    Local = 10000
    Dummy = Dummy * 4550
    Dummy = DIV32 Local
    Count1 = 36000
    Local = Count1 * 10000
    Speed = div32 Dummy
    Speed = Speed / 1000
