PBPro Maths Help
Results 1 to 9 of 9
    Default Re: PBPro Maths Help
    Still hoping for some guidance on the div32 type maths to improve the accuracy of my current 16 bit maths
    Hi, Retep ...
    first you have to declare a dummy var ... and a Div flag
    then ...
    IF Local > 32767 then    ' see PBP manual ... for the Why ???
       Local = Local/2
       Div = 1
    Else
       Div = 0
    Dummy = 11
    Dummy = Dummy*7908 ; operation needed by PBP ...
    ActualSpeed = DIV32  Local
    IF Div THEN ActualSpeed = Actualspeed / 2    ' Ooops ! not *2 ...
    ActualSpeed = ActualSpeed + 1
    Thanks for the help so far, here is a different formula though.
    How to convert that to use max resolution and div 32 command etc.
    3600sph / (count * 0.000005 * 4550)
    Count will be a maximum of 10,000
    Does this code look correct to implement the formula?
    'Formula Speed = 3600 / (Local * 0.000005 * 4550)
    Dummy = Local * 5
    Local = 10000
    Dummy = Dummy * 4550
    Dummy = DIV32 Local
    Count1 = 36000
    Local = Count1 * 10000
    Speed = div32 Dummy
    Speed = Speed / 1000
