PIC18 timer0 interrupt handler, still not getting it
Results 1 to 5 of 5
    Aug 2010
    Maryland, USA
    Default Re: PIC18 timer0 interrupt handler, still not getting it
    Are you sure you are in the correct bank when you try to BCF and BSF the port? When you are setting them in the setup, PBP is tending to the banks. but when you BCF or BSF, YOU must ensure the correct bank.
    PBP will leave you in bank 0, so if the LAT is not (highly likely) you are setting and clearing something else.
    -Bert
    Apr 2010
    Walnut Creek, CA
    Default Re: PIC18 timer0 interrupt handler sort of working, whoops! My mistake, of course.
    Interrupts are now occurring! I discovered that I was clearing the TMR0 interrupt enable elsewhere in my code. Now interrupts are occurring but at the wrong rate, 7ms between interrupts instead of 25us. Hopefully that'll be a simple fix. Sorry!
    Where's the embarrassed icon when I need it? ( :$ )
    Aug 2010
    Maryland, USA
    We will surely need more info for that. I would still check the banks. What 18 are you using at a min. OSC settinmgs? things going on in other parts that we can't see?
    -Bert
