Trapping a flag/state change (rapidly)
Results 1 to 10 of 10
    Mar 2009
    Default Trapping a flag/state change (rapidly)
    So, I'm learning about HPWM...and for this project just using a few LEDs to set some simple patterns running.
    I'm using DT's interrupts to trap a button being pressed, in the interrupt routine I increment a 'pattern' variable for each button press. This bit all works fine, so no problems there.
    So the interrupt returns to the main program loop ....but the variable (flag) change is not trapped until the program gets to the point where it tests the variable. Once it tests the variable, it jumps to a new loop (to change the LEDS sequence).
    Ok, here's the problem....
    For the sake of example, lets say Pattern 1 is a chaser (leds lighting up/extinguishing in sequence) & pattern is all LEDS on. What's happening here is that Pattern1 is running (leds sequencing),then the button gets pressed....but after the button is realeased it takes a finite time for the variable change to be picked up upon (trapped) in the main loop ...so the LEDs still continue to 'sequence' until the pattern change is trapped in the main loop - it then jumps to the new Pattern routine (all LEDS on) just fine. It's this lag between the button being pressed & the main loop picking up on it, that's causing me troubles...it's not a huge lag, but it is discernible & I'm sure there a slicker way
    I'm conscious that I'm still very much in the n00b camp & there must be a better way of having a program act in a zippy way to variable/flag changes.
    Default Re: Trapping a flag/state change (rapidly)
    Hi Hank,
    I'm not sure I can give you a general way of doing it.
    One (obvious but not elegant) way is to simply check the flag several times as you go thru the main loop.
    Another way, assuming you're using some kind of counter/index variable to "step" thru the individual states of each pattern, is to also reset that counter in the ISR thus forcing the "cycle" to start over. If the first thing you do in the "cycle" is to check the "pattern variable" then you'll get an imidiate switch of patterns.
    I'm sure there are several other ways of handling it.
    Mar 2009
    Hi Hank,
    Hi Henrik,
    That's the way I'm doing it now, but it eats up program space!
    Previously, (to save repetition) I made the mistake of using a GOSUB to check the 'pattern' variable regularly throught all my program segments & if it had changed, to point it to a different part of the program ....whoah schoolboy error, my pic started reseting (becuase I wasn't returning cleanly out of the gosub).
    I'm not sure I'm understanding your other recommendation.
    For anyone not sure what my issue is, here's a high level flow of what's going on
    pattern1:
    HIGH LED1
    PAUSE 100
    LOW LED1
    PAUSE 100
    HIGH LED2
    PAUSE 100
    LOW LED2
    PAUSE 100
    rinse, repeat....
    if pattern = 2 then goto pattern2
    goto pattern1
    pattern2:
    flash some other LED pattern
    if pattern = 1 then goto pattern1
    goto pattern2
    ISR:
    If a Switch is pressed in increment pattern variable
    you can clearly see that in pattern1, unless I check the variable called 'pattern' after every LED state change, that -especially with a few LEDS in play - it could be a while before the pattern variable change is picked up.
    Aug 2010
    Maryland, USA
    Hank, I think the hangup for you is how you generate the pattern.
    If you use some counters to "decide" when and what led to light up, instead of hanging your program for .4 seconds, you will see the flag check much faster.
    Maybe have your interrupt be a time base, like .1mS or something. Then while in the ISR, check for button press and inc your "led counters"
    I know this is vague, but all I have time for right now.
    -Bert
    There are many different ways of doing it and the "right" one depends on what you'll actually intend to do with it - in the end.... It's not uncommon to post something that does what's currently 'at hand' only to get something like OK, that works, now I want it to do this and that which, if it had been known from the start might have warranted another solution.
    Anyway, here's an example of what I was trying to explain earlier:
    Pattern VAR BYTE
    StepInPattern VAR BYTE
    Select Case Pattern
        Case 0 : Goto Pattern1
        Case 1 : Goto Pattern2
    Goto Main
    ' ------ Subroutine for pattern 1 ------
    Pattern1:
    Select Case StepInPattern
        Case 0
            High LED1
            StepInPattern = 1   'Next time, next step
        Case 1
            LOW LED2
            StepInPattern = 2
        Case 2
            HIGH LED2
            StepInPattern = 3
        Case 3
            LOW LED 2
            StepInPattern = 0   'Next time, start over
    END SELECT
    Pause 100
    Goto Main
    ' ------ Subroutine for pattern 2 ------
    Pattern2:
        Case 0
            HIGH LED1
            LOW LED2
        Case 1
            LOW LED1
            HIGH LED2
    END SELECT
    Pause 50
    Goto Main
    Basically it's two statemachines "driven" by the Pattern and StepInPattern variables. In your interrupt routine you can simply reset the StepInPattern variable and set Pattern to what ever pattern you want and it will start that pattern from the beginning. There will be a delay up to the longest Pause time that you've got in there but it won't have to complete the full cycle.
    This is not very code effective but it illustrates what I meant.
    On a project of mine I have single LED indicating various states of the device. I have a set of patterns defined something like this:
    Status_LED_Pattern_OK  CON %0000000011111111
    Status_LED_Pattern_Fault CON %1010101010101010
    Status_LED_Pattern_Wait CON %1111000011110000
    I can then select which pattern I want by doing:
    Pattern = Status_LED_Pattern_OK
    And in my main interrupt I have counter (PatternPointer) incrementing every 1/10th of a second which "points into" the pattern variable and sets the output driving the LED to the state of that bit, like:
    PortB.0 = Pattern.0[PatternPointer]
    Obviosuly the interrupt code needs to make sure that "pointer" only counts from 0-15 and then starts over or strange things WILL happen.
    Disclaimer: The above is from the top of my head to illustrate the tecnique, it may or may not work exactly as written.
    Mar 2009
    Hi Bert,
    You're bang on ...using pauses is not optimum, as obviously while it's erhm pausing it ain't doing anything else.
    the problem here is I'm already using two timers in my same testbed program here (one for a special event trigger & another to control HPWM) ...ok, so I've 3 timers left (16f1824 has 5 timers) , but I need a whole heap of different pauses (& some quite longish...I've always had an epic fail when I've tried to use timers for long pauses!) ....now I realise I could just reset the timer preload value accordingly each time I need a different pause, but ....aaargh ....brainache. I guess that's what it comes down to... a solution that avoids brainache ...it's a fair cop, I'll get me coat!
    Henrik,
    Many thanks for the comprehensive examples...I shall study them later tonight.
    Cheers,
    Hank
    Aug 2010
    Maryland, USA
    Henrik, I LOVE THAT!!!!!
    Hank, I think I like Henrik's idea better, but may or may not work for your app. Are any of the current 2 timers you have ISR's or are they just being used? Cuz if either of them have ISR, you can use that for the timebase. Increment counters there and check for button.
    -Bert
    May 2007
    Quote Originally Posted by HankMcSpank View Post
    ...You're bang on ...using pauses is not optimum, as obviously while it's erhm pausing it ain't doing anything else.
    If you want to use a PIC (or any MCU for that matter) efficiently, one of the most important things to learn to do - after you have accomplished your first blinky program - is to wean yourself off using pause (blocking) type commands completely.
